[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1145-g759da8e7f
Wed Jul 5 11:47:23 PDT 2023
the project "PostGIS".
       via  759da8e7f4ca4dc58dad317f6df9011f751c5722 (commit)
      from  dc1fe8fa7a66586ec51463fb65a40c47b31e5e24 (commit)
revisions in full, below.
commit 759da8e7f4ca4dc58dad317f6df9011f751c5722
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Jul 5 11:46:11 2023 -0700
    Add ST_LineExtend for users who want slightly longer lines.
    Supports things like extending for noding and so on.
    Closes #5267
diff --git a/doc/reference_editor.xml b/doc/reference_editor.xml
index 529e084e5..b67916a71 100644
--- a/doc/reference_editor.xml
+++ b/doc/reference_editor.xml
@@ -1244,6 +1244,72 @@ SELECT ST_AsText(ST_Multi('POLYGON ((10 30, 30 30, 30 10, 10 10, 10 30))'));
 			<para><xref linkend="ST_AsText" /></para>
 		</refsection>
 	</refentry>
+    <refentry id="ST_LineExtend">
+          <refnamediv>
+            <refname>ST_LineExtend</refname>
+            <refpurpose>Returns a line with the last and first segments extended the specified distance(s).</refpurpose>
+          </refnamediv>
+          <refsynopsisdiv>
+            <funcsynopsis>
+              <funcprototype>
+                <funcdef>geometry <function>ST_LineExtend</function></funcdef>
+                <paramdef><type>geometry </type>
+                <parameter>line</parameter></paramdef>
+                <paramdef><type>float </type>
+                <parameter>distance_forward</parameter></paramdef>
+                <paramdef choice="opt"><type>float</type> <parameter>distance_backward=0.0</parameter></paramdef>
+              </funcprototype>
+            </funcsynopsis>
+          </refsynopsisdiv>
+          <refsection>
+            <title>Description</title>
+            <para>Returns a line with the last and first segments extended the specified distance(s). Distance of zero carries out no extension. Only non-negative distances are allowed. The first (and last) two distinct points in a line are used to determine the direction of projection, duplicate points are ignored.</para>
+            <para role="availability" conformance="3.4.0">Availability: 3.4.0</para>
+          </refsection>
+          <refsection>
+            <title>Example: Projected point at 100,000 meters and bearing 45 degrees </title>
+<programlisting>
+SELECT ST_AsText(ST_Project('POINT(0 0)'::geography, 100000, radians(45.0)));
+ POINT(0.635231029125537 0.639472334729198)
+</programlisting>
+          </refsection>
+          <refsection>
+            <title>See Also</title>
+            <para><xref linkend="ST_LocateAlong" />, <xref linkend="ST_Project" /></para>
+          </refsection>
+    </refentry>
 	<refentry id="ST_Normalize">
 		<refnamediv>
@@ -1308,6 +1374,99 @@ SELECT ST_AsText(ST_Normalize(ST_GeomFromText(
 		</refsection>
 	</refentry>
+    <refentry id="ST_Project">
+          <refnamediv>
+            <refname>ST_Project</refname>
+            <refpurpose>Returns a point projected from a start point by a distance and bearing (azimuth).</refpurpose>
+          </refnamediv>
+          <refsynopsisdiv>
+            <funcsynopsis>
+              <funcprototype>
+                <funcdef>geometry <function>ST_Project</function></funcdef>
+                <parameter>g1</parameter></paramdef>
+                <parameter>distance</parameter></paramdef>
+                <parameter>azimuth</parameter></paramdef>
+              </funcprototype>
+              <funcprototype>
+                <parameter>g2</parameter></paramdef>
+              </funcprototype>
+              <funcprototype>
+                <funcdef>geography <function>ST_Project</function></funcdef>
+                <paramdef><type>geography </type>
+              </funcprototype>
+              <funcprototype>
+              </funcprototype>
+            </funcsynopsis>
+          </refsynopsisdiv>
+          <refsection>
+            <para>Returns a point projected from a point along a geodesic using a given distance and azimuth (bearing). This is known as the direct geodesic problem.</para>
+            <para>The two-point version uses the path from the first to the second point to implicitly define the azimuth and uses the distance as before.</para>
+            <para>The distance is given in meters.  Negative values are supported.</para>
+            <para>The azimuth (also known as heading or bearing) is given in radians.
+            It is measured clockwise from true north.</para>
+            <itemizedlist>
+                <listitem><para>North is azimuth zero (0 degrees)</para></listitem>
+                <listitem><para>East is azimuth &#x03C0;/2 (90 degrees)</para></listitem>
+                <listitem><para>South is azimuth &#x03C0; (180 degrees)</para></listitem>
+                <listitem><para>West is azimuth 3&#x03C0;/2 (270 degrees)</para></listitem>
+            </itemizedlist>
+            <para>Negative azimuth values and values greater than 2&#x03C0; (360 degrees) are supported.</para>
+            <para role="availability" conformance="2.0.0">Availability: 2.0.0</para>
+            <para role="enhanced" conformance="2.4.0">Enhanced: 2.4.0 Allow negative distance and non-normalized azimuth.</para>
+            <para role="enhanced" conformance="3.4.0">Enhanced: 3.4.0 Allow geometry arguments and two-point form omitting azimuth.</para>
+          </refsection>
+          <refsection>
+<programlisting>
+</programlisting>
+          </refsection>
+          <refsection>
+            <para><xref linkend="ST_Azimuth" />, <xref linkend="ST_Distance" />, <ulink url="http://www.postgresql.org/docs/current/interactive/functions-math.html">PostgreSQL function radians()</ulink></para>
+          </refsection>
+    </refentry>
 	<refentry id="ST_QuantizeCoordinates">
 		<refnamediv>
 			<refname>
diff --git a/doc/reference_measure.xml b/doc/reference_measure.xml
index 8708b2a22..4bd94c94d 100644
--- a/doc/reference_measure.xml
+++ b/doc/reference_measure.xml
@@ -1868,98 +1868,6 @@ FROM ST_GeogFromText('MULTIPOLYGON(((-71.1044543107478 42.340674480411,-71.10445
 	  </refsection>
 	</refentry>
-	<refentry id="ST_Project">
-		  <refnamediv>
-			<refname>ST_Project</refname>
-			<refpurpose>Returns a point projected from a start point by a distance and bearing (azimuth).</refpurpose>
-		  </refnamediv>
-		  <refsynopsisdiv>
-			<funcsynopsis>
-			  <funcprototype>
-				<funcdef>geometry <function>ST_Project</function></funcdef>
-				<paramdef><type>geometry </type>
-				<parameter>g1</parameter></paramdef>
-				<paramdef><type>float </type>
-				<parameter>distance</parameter></paramdef>
-				<parameter>azimuth</parameter></paramdef>
-			  </funcprototype>
-              <funcprototype>
-                <parameter>g2</parameter></paramdef>
-              </funcprototype>
-              <funcprototype>
-                <funcdef>geography <function>ST_Project</function></funcdef>
-                <paramdef><type>geography </type>
-              </funcprototype>
-              <funcprototype>
-              </funcprototype>
-			</funcsynopsis>
-		  </refsynopsisdiv>
-		  <refsection>
-			<title>Description</title>
-			<para>Returns a point projected from a point along a geodesic using a given distance and azimuth (bearing). This is known as the direct geodesic problem.</para>
-            <para>The two-point version uses the path from the first to the second point to implicitly define the azimuth and uses the distance as before.</para>
-			<para>The distance is given in meters.  Negative values are supported.</para>
-			<para>The azimuth (also known as heading or bearing) is given in radians.
-			It is measured clockwise from true north.</para>
-            <itemizedlist>
-                <listitem><para>North is azimuth zero (0 degrees)</para></listitem>
-                <listitem><para>East is azimuth &#x03C0;/2 (90 degrees)</para></listitem>
-                <listitem><para>South is azimuth &#x03C0; (180 degrees)</para></listitem>
-                <listitem><para>West is azimuth 3&#x03C0;/2 (270 degrees)</para></listitem>
-            </itemizedlist>
-            <para>Negative azimuth values and values greater than 2&#x03C0; (360 degrees) are supported.</para>
-			<para role="availability" conformance="2.0.0">Availability: 2.0.0</para>
-			<para role="enhanced" conformance="2.4.0">Enhanced: 2.4.0 Allow negative distance and non-normalized azimuth.</para>
-            <para role="enhanced" conformance="3.4.0">Enhanced: 3.4.0 Allow geometry arguments and two-point form omitting azimuth.</para>
-		  </refsection>
-		  <refsection>
-			<title>Example: Projected point at 100,000 meters and bearing 45 degrees </title>
-<programlisting>
-SELECT ST_AsText(ST_Project('POINT(0 0)'::geography, 100000, radians(45.0)));
- POINT(0.635231029125537 0.639472334729198)
-</programlisting>
-		  </refsection>
-		  <refsection>
-			<title>See Also</title>
-			<para><xref linkend="ST_Azimuth" />, <xref linkend="ST_Distance" />, <ulink url="http://www.postgresql.org/docs/current/interactive/functions-math.html">PostgreSQL function radians()</ulink></para>
-		  </refsection>
-	</refentry>
 <refentry id="ST_ShortestLine">
 	  <refnamediv>
 		<refname>ST_ShortestLine</refname>
diff --git a/liblwgeom/liblwgeom.h.in b/liblwgeom/liblwgeom.h.in
index 3bf5b4820..cbac60f3c 100644
--- a/liblwgeom/liblwgeom.h.in
+++ b/liblwgeom/liblwgeom.h.in
@@ -1153,6 +1153,11 @@ extern POINTARRAY* lwline_interpolate_points(const LWLINE *line, double length_f
 extern LWPOINT* lwline_interpolate_point_3d(const LWLINE *line, double distance);
+ * Extend the ends of a line
+extern LWLINE* lwline_extend(const LWLINE *line, double distance_forward, double distance_backward);
  * LWPOLY functions
diff --git a/liblwgeom/liblwgeom_internal.h b/liblwgeom/liblwgeom_internal.h
index cc45fdeef..a0f76162f 100644
--- a/liblwgeom/liblwgeom_internal.h
+++ b/liblwgeom/liblwgeom_internal.h
@@ -196,9 +196,9 @@ int lwpoint_is_empty(const LWPOINT *point);
 * Number of vertices?
-uint32_t lwline_count_vertices(LWLINE *line);
-uint32_t lwpoly_count_vertices(LWPOLY *poly);
-uint32_t lwcollection_count_vertices(LWCOLLECTION *col);
+uint32_t lwline_count_vertices(const LWLINE *line);
+uint32_t lwpoly_count_vertices(const LWPOLY *poly);
+uint32_t lwcollection_count_vertices(const LWCOLLECTION *col);
 * DP simplification
diff --git a/liblwgeom/lwcollection.c b/liblwgeom/lwcollection.c
index 6d5c5ce68..2cba81c1b 100644
--- a/liblwgeom/lwcollection.c
+++ b/liblwgeom/lwcollection.c
@@ -497,7 +497,7 @@ lwcollection_force_dims(const LWCOLLECTION *col, int hasz, int hasm, double zval
 	uint32_t i = 0;
 	uint32_t v = 0; /* vertices */
diff --git a/liblwgeom/lwgeom.c b/liblwgeom/lwgeom.c
index 1a580b9d6..6f2eb9764 100644
--- a/liblwgeom/lwgeom.c
+++ b/liblwgeom/lwgeom.c
@@ -1264,10 +1264,10 @@ uint32_t lwgeom_count_vertices(const LWGEOM *geom)
 	case TRIANGLETYPE:
 	case CIRCSTRINGTYPE:
 	case LINETYPE:
-		result = lwline_count_vertices((LWLINE *)geom);
+		result = lwline_count_vertices((const LWLINE *)geom);
 		break;
 	case POLYGONTYPE:
-		result = lwpoly_count_vertices((LWPOLY *)geom);
+		result = lwpoly_count_vertices((const LWPOLY *)geom);
 		break;
 	case COMPOUNDTYPE:
 	case CURVEPOLYTYPE:
@@ -1279,7 +1279,7 @@ uint32_t lwgeom_count_vertices(const LWGEOM *geom)
 	case POLYHEDRALSURFACETYPE:
 	case TINTYPE:
 	case COLLECTIONTYPE:
-		result = lwcollection_count_vertices((LWCOLLECTION *)geom);
+		result = lwcollection_count_vertices((const LWCOLLECTION *)geom);
 		break;
 	default:
 		lwerror("%s: unsupported input geometry type: %s",
diff --git a/liblwgeom/lwline.c b/liblwgeom/lwline.c
index af5b67eb4..936d9503c 100644
--- a/liblwgeom/lwline.c
+++ b/liblwgeom/lwline.c
@@ -502,7 +502,7 @@ lwline_force_dims(const LWLINE *line, int hasz, int hasm, double zval, double mv
 	return lineout;
 	assert(line);
 	if ( ! line->points )
@@ -667,3 +667,73 @@ lwline_interpolate_point_3d(const LWLINE *line, double distance)
 	getPoint4d_p(ipa, ipa->npoints - 1, &pt);
 	return lwpoint_make(line->srid, has_z, has_m, &pt);
+extern LWLINE *
+lwline_extend(const LWLINE *line, double distance_forward, double distance_backward)
+	POINTARRAY *pa, *opa;
+	POINT4D p00, p01, p10, p11;
+	POINT4D p_start, p_end;
+	uint32_t i;
+	bool forward = false, backward = false;
+	if (distance_forward < 0 || distance_backward < 0)
+		lwerror("%s: distances must be non-negative", __func__);
+	if (!line || lwline_is_empty(line) || lwline_count_vertices(line) < 2)
+		lwerror("%s: line must have at least two points", __func__);
+	pa = line->points;
+	if (distance_backward > 0.0)
+		i = 0;
+		/* Get two distinct points at start of pointarray */
+		getPoint4d_p(pa, i++, &p00);
+		getPoint4d_p(pa, i, &p01);
+		while(p4d_same(&p00, &p01))
+			if (i == pa->npoints - 1)
+				lwerror("%s: line must have at least two distinct points", __func__);
+			i++;
+		project_pt_pt(&p01, &p00, distance_backward, &p_start);
+		backward = true;
+	if (distance_forward > 0.0)
+		i = pa->npoints - 1;
+		/* Get two distinct points at end of pointarray */
+		getPoint4d_p(pa, i--, &p10);
+		getPoint4d_p(pa, i, &p11);
+		while(p4d_same(&p10, &p11))
+			if (i == 0)
+			i--;
+		project_pt_pt(&p11, &p10, distance_forward, &p_end);
+		forward = true;
+	opa = ptarray_construct_empty(ptarray_has_z(pa), ptarray_has_m(pa), pa->npoints + 2);
+	if (backward)
+		ptarray_append_point(opa, &p_start, true);
+	ptarray_append_ptarray(opa, pa, -1.0);
+	if (forward)
+		ptarray_append_point(opa, &p_end, true);
+	return lwline_construct(line->srid, NULL, opa);
diff --git a/liblwgeom/lwpoly.c b/liblwgeom/lwpoly.c
index e35fe2e5b..716bf00b3 100644
--- a/liblwgeom/lwpoly.c
+++ b/liblwgeom/lwpoly.c
@@ -415,7 +415,7 @@ lwpoly_force_dims(const LWPOLY *poly, int hasz, int hasm, double zval, double mv
 	return polyout;
 	uint32_t i = 0;
diff --git a/liblwgeom/measures.c b/liblwgeom/measures.c
index d1e327cd2..3469d29d7 100644
--- a/liblwgeom/measures.c
+++ b/liblwgeom/measures.c
@@ -2486,8 +2486,8 @@ project_pt(const POINT2D *P, double distance, double azimuth, POINT2D *R)
 	double dx = cos(slope) * distance;
 	double dy = sin(slope) * distance;
-	R->x += dx;
-	R->y += dy;
+	R->x = P->x + dx;
+	R->y = P->x + dy;
 	return LW_TRUE;
@@ -2505,10 +2505,10 @@ project_pt_pt(const POINT4D *A, const POINT4D *B, double distance, POINT4D *R)
 	double dy = (B->y - A->y) * prop;
 	double dz = (B->z - A->z) * prop;
 	double dm = (B->m - A->m) * prop;
-	R->x += dx;
-	R->y += dy;
-	if (isfinite(dz)) R->z += dz;
-	if (isfinite(dm)) R->m += dm;
+	R->x = B->x + dx;
+	R->y = B->y + dy;
+	if (isfinite(dz)) R->z = B->z + dz;
+	if (isfinite(dm)) R->m = B->m + dm;
 	return LW_TRUE;
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index 4f22b76a9..b0aa4b9b3 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -107,6 +107,7 @@ Datum LWGEOM_hasBBOX(PG_FUNCTION_ARGS);
 Datum LWGEOM_azimuth(PG_FUNCTION_ARGS);
 Datum geometry_project_direction(PG_FUNCTION_ARGS);
 Datum geometry_project_geometry(PG_FUNCTION_ARGS);
+Datum geometry_line_extend(PG_FUNCTION_ARGS);
 Datum LWGEOM_angle(PG_FUNCTION_ARGS);
 Datum LWGEOM_affine(PG_FUNCTION_ARGS);
 Datum LWGEOM_longitude_shift(PG_FUNCTION_ARGS);
@@ -2651,6 +2652,45 @@ Datum geometry_project_geometry(PG_FUNCTION_ARGS)
+ * Extend the ends of a line outwards from
+ * the end, the start, or both, a set positive distance.
+ * ST_LineExtent(linestring, distance_forward, distance_backward (default 0.0)
+ * Geometry must be linestring.
+PG_FUNCTION_INFO_V1(geometry_line_extend);
+	GSERIALIZED *geom1, *geom2;
+	LWLINE *lwline1, *lwline2;
+	LWGEOM *lwgeom1, *lwgeom2;
+	double distance_forward, distance_backward;
+	geom1 = PG_GETARG_GSERIALIZED_P(0);
+	distance_forward = PG_GETARG_FLOAT8(1);
+	distance_backward = PG_GETARG_FLOAT8(2);
+	lwgeom1 = lwgeom_from_gserialized(geom1);
+	lwline1 = lwgeom_as_lwline(lwgeom1);
+	if (!lwline1)
+		lwpgerror("Argument must be LINESTRING geometry");
+	if (lwline_is_empty(lwline1))
+		PG_RETURN_NULL();
+	if (lwline_length_2d(lwline1) <= 0.0)
+		PG_RETURN_POINTER(geom1);
+	lwline2 = lwline_extend(lwline1, distance_forward, distance_backward);
+	lwgeom2 = lwline_as_lwgeom(lwline2);
+	geom2 = geometry_serialize(lwgeom2);
+	PG_RETURN_POINTER(geom2);
  * Compute the angle defined by 3 points or the angle between 2 vectors
  * defined by 4 points
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 5e9275c74..016233f6d 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -1411,6 +1411,13 @@ CREATE OR REPLACE FUNCTION ST_Angle(pt1 geometry, pt2 geometry, pt3 geometry, pt
 	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
 	_COST_LOW;
+-- Availability: 3.4.0
+CREATE OR REPLACE FUNCTION ST_LineExtend(geom geometry, distance_forward float8, distance_backward float8 DEFAULT 0.0)
+	RETURNS geometry
+	AS 'MODULE_PATHNAME', 'geometry_line_extend'
+	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
+	_COST_LOW;
 -- Availability: Future
 -- CREATE OR REPLACE FUNCTION _ST_DistanceRectTree(g1 geometry, g2 geometry)
 --	RETURNS float8
diff --git a/regress/core/measures.sql b/regress/core/measures.sql
index 465578177..705789cdc 100644
--- a/regress/core/measures.sql
+++ b/regress/core/measures.sql
@@ -298,6 +298,7 @@ SELECT 'st_project.04', ST_AsText(ST_SnapToGrid(ST_Project('POINT(0 0)'::geometr
 SELECT 'st_project.05', ST_AsText(ST_SnapToGrid(ST_Project('POINT(0 0)'::geometry, 1, pi()/4), 0.001), 3);
 SELECT 'st_project.06', ST_AsText(ST_SnapToGrid(ST_Project('POINT(0 0)'::geometry, 1, pi()+pi()/4), 0.001), 3);
 SELECT 'st_project.07', ST_AsText(ST_SnapToGrid(ST_Project('POINT(0 0)'::geometry, 0, 0), 0.001), 3);
+SELECT 'st_project.08', ST_AsText(ST_SnapToGrid(ST_Project('POINT(10 10)'::geometry, 1, pi()+pi()/4), 0.001), 3);
 SELECT 'st_project.11', ST_AsText(ST_SnapToGrid(ST_Project('POINT(1 0)'::geometry, 'POINT(0 0)'::geometry, 1), 0.1), 2);
 SELECT 'st_project.12', ST_AsText(ST_SnapToGrid(ST_Project('POINT(-1 0)'::geometry, 'POINT(0 0)'::geometry, 1), 0.1), 2);
@@ -306,3 +307,11 @@ SELECT 'st_project.14', ST_AsText(ST_SnapToGrid(ST_Project('POINT(0 -1)'::geomet
 SELECT 'st_project.15', ST_AsText(ST_SnapToGrid(ST_Project('POINT(1 1)'::geometry, 'POINT(0 0)'::geometry, 1), 0.001), 3);
 SELECT 'st_project.16', ST_AsText(ST_SnapToGrid(ST_Project('POINT(-1 -1)'::geometry, 'POINT(0 0)'::geometry, 1), 0.001), 3);
 SELECT 'st_project.17', ST_AsText(ST_SnapToGrid(ST_Project('POINT(0 0)'::geometry, 'POINT(0 0)'::geometry, 1), 0.001), 3);
+SELECT 'st_project.18', ST_AsText(ST_SnapToGrid(ST_Project('POINT(10 10)'::geometry, 'POINT(8 8)'::geometry, 1), 0.001), 3);
+SELECT 'st_lineextend.1', ST_AsText(ST_SnapToGrid(ST_LineExtend('LINESTRING(0 0,1 1)'::geometry, 1, 1), 0.001), 3);
+SELECT 'st_lineextend.2', ST_AsText(ST_SnapToGrid(ST_LineExtend('LINESTRING(0 0,1 1)'::geometry, 0, 1), 0.001), 3);
+SELECT 'st_lineextend.3', ST_AsText(ST_SnapToGrid(ST_LineExtend('LINESTRING(0 0,1 1)'::geometry, 1), 0.001), 3);
+SELECT 'st_lineextend.4', ST_AsText(ST_SnapToGrid(ST_LineExtend('LINESTRING(0 0,1 1,1 1,1 1)'::geometry, 1), 0.001), 3);
+SELECT 'st_lineextend.5', ST_AsText(ST_SnapToGrid(ST_LineExtend('LINESTRING EMPTY'::geometry, 1), 0.001), 3);
+SELECT 'st_lineextend.6', ST_AsText(ST_SnapToGrid(ST_LineExtend('POINT EMPTY'::geometry, 1), 0.001), 3);
diff --git a/regress/core/measures_expected b/regress/core/measures_expected
index a9114589c..09878b4a0 100644
--- a/regress/core/measures_expected
+++ b/regress/core/measures_expected
@@ -86,6 +86,7 @@ st_project.04|POINT(-1 0)
 st_project.05|POINT(0.707 0.707)
 st_project.06|POINT(-0.707 -0.707)
 st_project.07|POINT(0 0)
+st_project.08|POINT(9.293 9.293)
 st_project.11|POINT(-1 0)
 st_project.12|POINT(1 0)
 st_project.13|POINT(0 -1)
@@ -93,3 +94,10 @@ st_project.14|POINT(0 1)
 st_project.15|POINT(-0.707 -0.707)
 st_project.16|POINT(0.707 0.707)
 st_project.17|POINT(0 0)
+st_project.18|POINT(7.293 7.293)
+st_lineextend.1|LINESTRING(-0.707 -0.707,0 0,1 1,1.707 1.707)
+st_lineextend.2|LINESTRING(-0.707 -0.707,0 0,1 1)
+st_lineextend.3|LINESTRING(0 0,1 1,1.707 1.707)
+st_lineextend.4|LINESTRING(0 0,1 1,1.707 1.707)
+st_lineextend.5|
+ERROR:  Argument must be LINESTRING geometry
Summary of changes:
 doc/reference_editor.xml         | 159 +++++++++++++++++++++++++++++++++++++++
 doc/reference_measure.xml        |  92 ----------------------
 liblwgeom/liblwgeom.h.in         |   5 ++
 liblwgeom/liblwgeom_internal.h   |   6 +-
 liblwgeom/lwcollection.c         |   2 +-
 liblwgeom/lwgeom.c               |   6 +-
 liblwgeom/lwline.c               |  72 +++++++++++++++++-
 liblwgeom/lwpoly.c               |   2 +-
 liblwgeom/measures.c             |  12 +--
 postgis/lwgeom_functions_basic.c |  40 ++++++++++
 postgis/postgis.sql.in           |   7 ++
 regress/core/measures.sql        |   9 +++
 regress/core/measures_expected   |   8 ++
 13 files changed, 313 insertions(+), 107 deletions(-)
hooks/post-receive
