[postgis-tickets] [PostGIS] #5431: make clean does not clean doc/po/* directories
PostGIS trac at osgeo.org
Wed Jul 5 14:58:12 PDT 2023
  Reporter:  strk           |      Owner:  robe
      Type:  defect         |     Status:  reopened
  Priority:  medium         |  Milestone:  PostGIS 3.5.0
 Component:  documentation  |    Version:  master
Resolution:                 |   Keywords:
Changes (by strk):
 * status:  closed => reopened
 * resolution:  fixed =>
Comment:
 Reopening because pdf files are still there:
         po/de/postgis-3.4.0dev-de.pdf
         po/es/postgis-3.4.0dev-es.pdf
         po/fr/postgis-3.4.0dev-fr.pdf
         po/it_IT/postgis-3.4.0dev-it.pdf
         po/ko_KR/postgis-3.4.0dev-ko_KR.pdf
         po/pl/postgis-3.4.0dev-pl.pdf
         po/pt_BR/postgis-3.4.0dev-br.pdf
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5431#comment:3>
