[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1158-ge55666b2b
Wed Jul 5 15:30:01 PDT 2023
the project "PostGIS".
       via  e55666b2b0cb4cdcb3717635297fd9988259d81d (commit)
       via  f5fd56c66b9b960787f1555c50f0568d9de12654 (commit)
      from  4997d11b8291aacee7ce683539b61641252b5508 (commit)
revisions in full, below.
commit e55666b2b0cb4cdcb3717635297fd9988259d81d
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jul 6 00:28:18 2023 +0200
    Have woodie build cheatsheets
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index aee2639fd..36cf748c7 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -7,21 +7,25 @@ pipeline:
       - mkdir -p build-docs && cd build-docs
       - ../configure --without-pg
       - make postgis_revision.h
+  check-xml:
+      - cd build-docs
+      - make -C doc check
+      - make -C doc/ check-localized
   build-html:
     image: docker.osgeo.org/postgis/build-test:trisquel3
     commands:
       - cd build-docs
-      - make docs
-      - make -C doc check
-      - make docs-localized
-      - make -C doc/ check-localized
+      - make -C doc html
+      - make -C doc/ html-localized
   build-pdf:
     commands:
       - cd build-docs
       - make -C doc/ pdf
+      - make -C doc/ pdf-localized
   build-cheatsheets:
     commands:
       - cd build-docs
       - make -C doc/ cheatsheets
+      - make -C doc/ cheatsheets-localized
commit f5fd56c66b9b960787f1555c50f0568d9de12654
Date:   Thu Jul 6 00:24:13 2023 +0200
    Localize cheatsheets
    References #5435
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 01b93c551..e28bf221f 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -227,8 +227,8 @@ GENERATED_COMMENT_FILES = $(patsubst \
 GENERATED_CHEATSHEET_FILES = $(patsubst \
-	$(srcdir)/xsl/%.xsl, \
-	html/%, \
+	$(srcdir)/xsl/%.html.xsl, \
+	html/%$(DOCSUFFIX).html, \
 	$(wildcard $(srcdir)/xsl/*_cheatsheet.html.xsl) \
@@ -298,7 +298,7 @@ endif
 $(GENERATED_COMMENT_FILES): %.sql: xsl/%.sql.xsl $(XML_INPUTS) postgis-out.xml
 	$(XSLTPROC) --novalid $(XSLTPROC_PATH_OPT) -o $@ $< postgis-out.xml
-$(GENERATED_CHEATSHEET_FILES): html/%.html: xsl/%.html.xsl $(XML_INPUTS) postgis-out.xml
+$(GENERATED_CHEATSHEET_FILES): html/%$(DOCSUFFIX).html: xsl/%.html.xsl $(XML_INPUTS) postgis-out.xml
 postgis-out.xml: postgis.xml Makefile
@@ -417,14 +417,16 @@ pdf-clean:
 epub-clean:
 	rm -f postgis*$(DOCSUFFIX).epub
-clean: images-clean html-clean html-clean-localized pdf-clean pdf-clean-localized epub-clean epub-clean-localized
+cheatsheet-clean:
+	rm -f $(GENERATED_CHEATSHEET_FILES)
+clean: images-clean html-clean html-clean-localized pdf-clean pdf-clean-localized epub-clean epub-clean-localized cheatsheet-clean cheatsheet-clean-localized
 	rm -f images # work around https://trac.osgeo.org/postgis/ticket/5422
 	rm -f $(XML_GENERATED_SOURCES)
 	rm -f $(TAG_GENERATED_SOURCES)
 	$(MAKE) -C html/images clean
 	rm -f postgis_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql
 	rm -f raster_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql
-	rm -f $(GENERATED_CHEATSHEET_FILES)
 	rm -f *.tmp
 	$(MAKE) clean-localized
@@ -441,7 +443,7 @@ else
 comments: postgis_comments.sql raster_comments.sql topology_comments.sql sfcgal_comments.sql tiger_geocoder_comments.sql
 endif
-cheatsheets: html/postgis_cheatsheet.html html/raster_cheatsheet.html html/topology_cheatsheet.html html/sfcgal_cheatsheet.html html/tiger_geocoder_cheatsheet.html
+cheatsheets: $(GENERATED_CHEATSHEET_FILES)
 ifneq ($(CAN_BUILD_COMMENTS),yes)
 comments-install:
Summary of changes:
 .woodpecker/docs.yml | 12 ++++++++----
 doc/Makefile.in      | 14 ++++++++------
 2 files changed, 16 insertions(+), 10 deletions(-)
hooks/post-receive
