[postgis-tickets] [PostGIS] #5436: Can't compile master, getting docbook error on address standardizer
PostGIS trac at osgeo.org
Thu Jul 6 09:50:20 PDT 2023
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  3.3.x
Resolution:                         |   Keywords:
Comment (by strk):
 does inverting the quotes work ?
 xmllint --xpath '/config/tags/para[@role="tag_Z_support"]' doc/xsl-
 config.xml
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5436#comment:3>
