[postgis-tickets] [PostGIS] #5438: woodie pdf build step errors out (unknown error)
PostGIS trac at osgeo.org
Sat Jul 8 02:57:15 PDT 2023
  Reporter:  strk       |      Owner:  strk
      Type:  defect     |     Status:  assigned
  Priority:  medium     |  Milestone:  Website Management, Bots
 Component:  buildbots  |    Version:
Resolution:             |   Keywords:
Comment (by strk):
 I connected to the machine (osgeo8-woodie-server) and got an interactive
 bash shell inside the docker container running the job. There I see this
 process being executed:
 > pdflatex -interaction=batchmode postgis-out.tex
 The version of pdlatex is {{{ pdfTeX 3.14159265-2.6-1.40.20 (TeX Live
 2019/Debian) }}}
 At the moment of writing multiple pdfs have been created, about one every
 3 minutes:
 -rw-r--r-- 1 root root 5383393 Jul  8 09:40 ./po/pt_BR/postgis-3.4.0dev-
 br.pdf
 -rw-r--r-- 1 root root 5483288 Jul  8 09:43 ./po/fr/postgis-3.4.0dev-
 fr.pdf
 -rw-r--r-- 1 root root 5345350 Jul  8 09:48 ./po/pl/postgis-3.4.0dev-
 pl.pdf
 -rw-r--r-- 1 root root 5349839 Jul  8 09:45 ./po/es/postgis-3.4.0dev-
 es.pdf
 -rw-r--r-- 1 root root 5542413 Jul  8 09:50 ./po/ko_KR/postgis-3.4.0dev-
 ko_KR.pdf
 -rw-r--r-- 1 root root 5332001 Jul  8 09:38 ./po/it_IT/postgis-3.4.0dev-
 it.pdf
 -rw-r--r-- 1 root root 5308009 Jul  8 09:35 ./postgis-3.4.0dev-en.pdf
 The logs of the corresponding build are being received:
 https://woodie.osgeo.org/postgis/postgis/build/592/10
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5438#comment:1>
