[postgis-tickets] [PostGIS] #5438: woodie pdf build step errors out (unknown error)
PostGIS trac at osgeo.org
Sat Jul 8 05:14:04 PDT 2023
  Reporter:  strk       |      Owner:  strk
      Type:  defect     |     Status:  assigned
  Priority:  medium     |  Milestone:  Website Management, Bots
 Component:  buildbots  |    Version:
Resolution:             |   Keywords:
Comment (by strk):
 Running the offending job manually in the appropriate container shows a
 useful failure message:
 ostgis-out.tex:58: Undefined control sequence \cyro.
 postgis-out.tex:58: leading text: ...{PostgreSQL},
 \cyrchar\cyrk{}\cyrchar\cyro
 Transformation failure might be caused by handling a cyrillic document
 without the XeTeX backend
 Error: pdflatex compilation failed
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5438#comment:5>
