[postgis-tickets] [PostGIS] #5438: woodie pdf build step errors out (unknown error)
PostGIS trac at osgeo.org
Sat Jul 8 08:04:34 PDT 2023
  Reporter:  strk       |      Owner:  strk
      Type:  defect     |     Status:  reopened
  Priority:  medium     |  Milestone:  Website Management, Bots
 Component:  buildbots  |    Version:
Resolution:             |   Keywords:
Changes (by strk):
 * status:  closed => reopened
 * resolution:  fixed =>
Comment:
 While the fix was effective (tested locally) the green on woodie was a
 false negative,
 as a split organization of jobs show that the japanese translation still
 fails:
 https://woodie.osgeo.org/postgis/postgis/build/594/61
 When trying to compare the logs from the green job, I got the "unknown
 error occurred" message back:
 https://woodie.osgeo.org/postgis/postgis/build/593/10
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5438#comment:9>
