[postgis-tickets] [PostGIS] #5439: Error with Japanese translation (PDF)
PostGIS trac at osgeo.org
Sat Jul 8 10:10:50 PDT 2023
 Reporter:  strk           |      Owner:  robe
     Type:  defect         |     Status:  new
 Priority:  medium         |  Milestone:  PostGIS 3.3.4
Component:  documentation  |    Version:  3.3.x
 Keywords:                 |
 The problem seems to be in release_notes.xml which taken out makes the
 build of pdf succeed. It can be used as the only input to the dblatex
 command and would result in:
 postgis-out.toc:4: You can't use `macro parameter character #' in
 horizontal mode.
 postgis-out.toc:4: leading text:
 ...&##x5909;\&##x66f4;}{2}{subsection.a.A.1.2}
 This is a snip-off of #5438
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5439>
