[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1187-gc80e97e59
Sat Jul 8 14:21:58 PDT 2023
the project "PostGIS".
       via  c80e97e59a3f92ef4044f0427bc263e59059ca05 (commit)
      from  92dd3257a02d227c392113298360e4244c273463 (commit)
revisions in full, below.
commit c80e97e59a3f92ef4044f0427bc263e59059ca05
Author: Sandro Santilli <strk at kbt.io>
Date:   Sat Jul 8 21:17:48 2023 +0200
    [woodie] Reorganize docs workflow to avoid per-lang clone and configure
    Replaces matrix with generated static list of steps
diff --git a/.woodpecker/docs-localized.yml b/.woodpecker/docs-localized.yml
deleted file mode 100644
index 05829b372..000000000
--- a/.woodpecker/docs-localized.yml
+++ /dev/null
@@ -1,47 +0,0 @@
-matrix:
-  TR:
-    - it_IT
-    - pt_BR
-    - fr
-    - es
-    - pl
-    - ko_KR
-    - de
-    - ja
-    - ru
-pipeline:
-  prepare:
-    image: docker.osgeo.org/postgis/build-test:trisquel3
-    pull: true
-    commands:
-      - ./autogen.sh
-      - mkdir -p build-docs && cd build-docs
-      - ../configure --without-pg
-      - make postgis_revision.h
-    when:
-      path: "doc/po/${TR}/*.po"
-  check-xml:
-    commands:
-      - make -C build-docs/doc/po/${TR} local-check
-    when:
-  build-html:
-    commands:
-      - make -C build-docs/doc/po/${TR} local-html
-    when:
-  build-pdf:
-    commands:
-      - make -C build-docs/doc/po/${TR} local-pdf
-    when:
-  build-cheatsheets:
-    commands:
-      - make -C build-docs/doc/po/${TR} local-cheatsheets
-    when:
diff --git a/.woodpecker/docs-localized.yml.in b/.woodpecker/docs-localized.yml.in
new file mode 100644
index 000000000..24221e8f9
--- /dev/null
+++ b/.woodpecker/docs-localized.yml.in
@@ -0,0 +1,27 @@
+  check-xml- at LANG@:
+    image: *test_image
+    commands:
+      - make -C build-docs/doc/po/@LANG@ local-check
+    when:
+      path: *when_path
+  build-html- at LANG@:
+    group: output- at LANG@
+    commands:
+      - make -C build-docs/doc/po/@LANG@ local-html
+    when:
+      path: *when_path
+  build-pdf- at LANG@:
+    commands:
+      - make -C build-docs/doc/po/@LANG@ local-pdf
+    when:
+      path: *when_path
+  build-cheatsheets- at LANG@:
+    commands:
+      - make -C build-docs/doc/po/@LANG@ local-cheatsheets
+    when:
+      path: *when_path
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index c003f7d33..c8e6f19a3 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -1,29 +1,309 @@
+variables:
+  - &test_image 'docker.osgeo.org/postgis/build-test:trisquel3'
+  - &when_path
+      include:
+        # related config files
+        - ".woodpecker/docs.yml"
+        # Makefiles
+        - "doc/Makefile.in"
+        # XML sources
+        - "doc/*.xml"
+        # Localized Makefiles
+        - "doc/po/Makefile.local"
+        - "doc/po/*/Makefile.local"
+        # Translation files
+        - "doc/po/*/*.po"
 pipeline:
   prepare:
     pull: true
     commands:
       - ./autogen.sh
+    when:
+      path: *when_path
   check-xml:
     commands:
       - make -C build-docs/doc check
+    when:
+      path: *when_path
   build-html:
+    group: output
     commands:
       - make -C build-docs/doc html
+    when:
+      path: *when_path
   build-cheatsheets:
+    group: output
     commands:
       - make -C build-docs/doc/ cheatsheets
+    when:
+      path: *when_path
   build-chunked-html:
+    group: output
     commands:
+    when:
+      path: *when_path
   build-pdf:
+    group: output
     commands:
       - make -C build-docs/doc/ pdf
+    when:
+      path: *when_path
+  # DO NOT EDIT PAST THIS LINE, use update-docs-localized.sh to update #
+# Supported languages  it_IT pt_BR fr es pl ko_KR de ja ru
+  check-xml-it_IT:
+    commands:
+      - make -C build-docs/doc/po/it_IT local-check
+    when:
+      path: *when_path
+  build-html-it_IT:
+    group: output-it_IT
+    commands:
+      - make -C build-docs/doc/po/it_IT local-html
+    when:
+      path: *when_path
+  build-pdf-it_IT:
+    commands:
+      - make -C build-docs/doc/po/it_IT local-pdf
+    when:
+      path: *when_path
+  build-cheatsheets-it_IT:
+    commands:
+      - make -C build-docs/doc/po/it_IT local-cheatsheets
+    when:
+      path: *when_path
+  check-xml-pt_BR:
+    commands:
+      - make -C build-docs/doc/po/pt_BR local-check
+    when:
+      path: *when_path
+  build-html-pt_BR:
+    group: output-pt_BR
+    commands:
+      - make -C build-docs/doc/po/pt_BR local-html
+    when:
+      path: *when_path
+  build-pdf-pt_BR:
+    commands:
+      - make -C build-docs/doc/po/pt_BR local-pdf
+    when:
+      path: *when_path
+  build-cheatsheets-pt_BR:
+    commands:
+      - make -C build-docs/doc/po/pt_BR local-cheatsheets
+    when:
+      path: *when_path
+  check-xml-fr:
+    commands:
+      - make -C build-docs/doc/po/fr local-check
+    when:
+      path: *when_path
+  build-html-fr:
+    group: output-fr
+    commands:
+      - make -C build-docs/doc/po/fr local-html
+    when:
+      path: *when_path
+  build-pdf-fr:
+    group: output-fr
+    commands:
+      - make -C build-docs/doc/po/fr local-pdf
+    when:
+      path: *when_path
+  build-cheatsheets-fr:
+    group: output-fr
+    commands:
+      - make -C build-docs/doc/po/fr local-cheatsheets
+    when:
+      path: *when_path
+  check-xml-es:
+    commands:
+      - make -C build-docs/doc/po/es local-check
+    when:
+      path: *when_path
+  build-html-es:
+    group: output-es
+    commands:
+      - make -C build-docs/doc/po/es local-html
+    when:
+      path: *when_path
+  build-pdf-es:
+    group: output-es
+    commands:
+      - make -C build-docs/doc/po/es local-pdf
+    when:
+      path: *when_path
+  build-cheatsheets-es:
+    group: output-es
+    commands:
+      - make -C build-docs/doc/po/es local-cheatsheets
+    when:
+      path: *when_path
+  check-xml-pl:
+    commands:
+      - make -C build-docs/doc/po/pl local-check
+    when:
+      path: *when_path
+  build-html-pl:
+    group: output-pl
+    commands:
+      - make -C build-docs/doc/po/pl local-html
+    when:
+      path: *when_path
+  build-pdf-pl:
+    group: output-pl
+    commands:
+      - make -C build-docs/doc/po/pl local-pdf
+    when:
+      path: *when_path
+  build-cheatsheets-pl:
+    group: output-pl
+    commands:
+      - make -C build-docs/doc/po/pl local-cheatsheets
+    when:
+      path: *when_path
+  check-xml-ko_KR:
+    commands:
+      - make -C build-docs/doc/po/ko_KR local-check
+    when:
+      path: *when_path
+  build-html-ko_KR:
+    group: output-ko_KR
+    commands:
+      - make -C build-docs/doc/po/ko_KR local-html
+    when:
+      path: *when_path
+  build-pdf-ko_KR:
+    commands:
+      - make -C build-docs/doc/po/ko_KR local-pdf
+    when:
+      path: *when_path
+  build-cheatsheets-ko_KR:
+    commands:
+      - make -C build-docs/doc/po/ko_KR local-cheatsheets
+    when:
+      path: *when_path
+  check-xml-de:
+    commands:
+      - make -C build-docs/doc/po/de local-check
+    when:
+      path: *when_path
+  build-html-de:
+    group: output-de
+    commands:
+      - make -C build-docs/doc/po/de local-html
+    when:
+      path: *when_path
+  build-pdf-de:
+    group: output-de
+    commands:
+      - make -C build-docs/doc/po/de local-pdf
+    when:
+      path: *when_path
+  build-cheatsheets-de:
+    group: output-de
+    commands:
+      - make -C build-docs/doc/po/de local-cheatsheets
+    when:
+      path: *when_path
+  check-xml-ja:
+    commands:
+      - make -C build-docs/doc/po/ja local-check
+    when:
+      path: *when_path
+  build-html-ja:
+    group: output-ja
+    commands:
+      - make -C build-docs/doc/po/ja local-html
+    when:
+      path: *when_path
+  build-pdf-ja:
+    group: output-ja
+    commands:
+      - make -C build-docs/doc/po/ja local-pdf
+    when:
+      path: *when_path
+  build-cheatsheets-ja:
+    group: output-ja
+    commands:
+      - make -C build-docs/doc/po/ja local-cheatsheets
+    when:
+      path: *when_path
+  check-xml-ru:
+    commands:
+      - make -C build-docs/doc/po/ru local-check
+    when:
+      path: *when_path
+  build-html-ru:
+    group: output-ru
+    commands:
+      - make -C build-docs/doc/po/ru local-html
+    when:
+      path: *when_path
+  build-pdf-ru:
+    group: output-ru
+    commands:
+      - make -C build-docs/doc/po/ru local-pdf
+    when:
+      path: *when_path
+  build-cheatsheets-ru:
+    group: output-ru
+    commands:
+      - make -C build-docs/doc/po/ru local-cheatsheets
+    when:
+      path: *when_path
diff --git a/.woodpecker/update-docs-localized.sh b/.woodpecker/update-docs-localized.sh
new file mode 100755
index 000000000..bb9f4fc67
--- /dev/null
+++ b/.woodpecker/update-docs-localized.sh
@@ -0,0 +1,20 @@
+#!/bin/sh
+cd $(dirname $0)
+SUPPORTED_LANGUAGES=$(grep ^translations ../doc/Makefile.in | cut -d= -f2)
+exec > docs.yml.new
+cat docs.yml | sed '/DO NOT EDIT/q'
+echo
+echo "# Supported languages $SUPPORTED_LANGUAGES"
+echo
+for lang in ${SUPPORTED_LANGUAGES};
+do
+  sed "s/@LANG@/$lang/" docs-localized.yml.in
+done
+mv -b docs.yml.new docs.yml
Summary of changes:
 .woodpecker/docs-localized.yml       |  47 ------
 .woodpecker/docs-localized.yml.in    |  27 ++++
 .woodpecker/docs.yml                 | 292 ++++++++++++++++++++++++++++++++++-
 .woodpecker/update-docs-localized.sh |  20 +++
 4 files changed, 333 insertions(+), 53 deletions(-)
 delete mode 100644 .woodpecker/docs-localized.yml
 create mode 100644 .woodpecker/docs-localized.yml.in
 create mode 100755 .woodpecker/update-docs-localized.sh
hooks/post-receive
