[postgis-tickets] [PostGIS] #5439: Error with Japanese translation (PDF)
PostGIS trac at osgeo.org
Mon Jul 10 01:11:56 PDT 2023
  Reporter:  strk           |      Owner:  robe
      Type:  defect         |     Status:  new
  Priority:  medium         |  Milestone:  PostGIS 3.3.4
 Component:  documentation  |    Version:  3.3.x
Resolution:                 |   Keywords:
Comment (by strk):
 To recap: building the PDF fails IF japanese unicode characters are
 entered in tags that are rendered as literal strings in tex. This seem to
 be things like `<programlisting>` and `<screen>`. The use of
 `<lineannotation>` was in hope that'd be different but is not, as long as
 that tag is INSIDE '<programlisting>` or `<screen>`. My commit resulted in
 a success because the japanese translators did not update the translation
 after introduction of the new tag so ther's no Japanese character in the
 translated XML.
 The bug in handling utf8 in so called "listing environment" seems to be
 already reported upstream: https://sourceforge.net/p/dblatex/bugs/130/ and
 I saw workaround posted suggesting to add mapping for each character to be
 used in there, which is not very practical.
 What we could do as a workaround, maybe, is to pre-process our XML to make
 sure `<programlisting>` and `<screen>` tags are never sent to the
 translation process.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5439#comment:8>
