[postgis-tickets] [PostGIS] #5427: PG17 change broke our code
PostGIS trac at osgeo.org
Tue Jul 11 08:01:44 PDT 2023
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 3.5.0
 Component:  postgis  |    Version:  master
Resolution:  fixed    |   Keywords:  PostgreSQL 17 pg17
Comment (by Laurenz Albe):
 The patch is not good enough.
 You forgot to fix the references to `stats->attr` that are in the code
 block surrounded by `#if POSTGIS_DEBUG_LEVEL > 0`, at line 1535.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5427#comment:2>
