[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1227-g28b152436
Wed Jul 12 12:14:21 PDT 2023
the project "PostGIS".
       via  28b15243639da0bce2f761aa195f80dccf0229a9 (commit)
       via  39ff618ffdeb04989da312ef259a0208296a539d (commit)
      from  f5854415ce66e8feb1a68abb0ee4628455295bbb (commit)
revisions in full, below.
commit 28b15243639da0bce2f761aa195f80dccf0229a9
Author: Regina Obe <regina at arrival3d.com>
Date:   Wed Jul 12 19:10:39 2023 +0000
    Translated using Weblate (Italian)
    Currently translated at 20.0% (61 of 304 strings)
    Translation: postgis/reference_measure.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_measurexml/it/
diff --git a/doc/po/it_IT/reference_measure.xml.po b/doc/po/it_IT/reference_measure.xml.po
index 2fd8742de..fdfdfc5c8 100644
--- a/doc/po/it_IT/reference_measure.xml.po
+++ b/doc/po/it_IT/reference_measure.xml.po
@@ -7,7 +7,7 @@ msgstr ""
 "Project-Id-Version: PostGIS\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-07-12 18:27+0000\n"
-"PO-Revision-Date: 2023-07-12 18:26+0000\n"
+"PO-Revision-Date: 2023-07-12 19:14+0000\n"
 "Last-Translator: Regina Obe <regina at arrival3d.com>\n"
 "Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/"
 "reference_measurexml/it/>\n"
@@ -430,7 +430,7 @@ msgstr ""
 #. Tag: funcsynopsis
 #: reference_measure.xml:165
-#, fuzzy, no-c-format
+#, no-c-format
 msgid ""
 "<funcprototype> <funcdef>float <function>ST_Angle</function></funcdef> "
 "<paramdef><type>geometry </type><parameter>point1</parameter></paramdef> "
@@ -442,13 +442,6 @@ msgid ""
 "type><parameter>line1</parameter></paramdef> <paramdef><type>geometry </"
 "type><parameter>line2</parameter></paramdef> </funcprototype>"
 msgstr ""
-"<funcprototype> <funcdef>float <function>ST_Azimuth</function></funcdef> "
-"<paramdef><type>geometry </type><parameter>pointA</parameter></paramdef> "
-"<paramdef><type>geometry </type><parameter>pointB</parameter></paramdef> </"
-"funcprototype> <funcprototype> <funcdef>float <function>ST_Azimuth</"
-"function></funcdef> <paramdef><type>geography </type><parameter>pointA</"
-"parameter></paramdef> <paramdef><type>geography </type><parameter>pointB</"
-"parameter></paramdef> </funcprototype>"
 #. Tag: para
 #: reference_measure.xml:183
@@ -539,7 +532,7 @@ msgstr ""
 #. Tag: programlisting
 #: reference_measure.xml:208
+#, no-c-format
 msgid ""
 "SELECT degrees( ST_Angle('LINESTRING(0 0, 0.3 0.7, 1 1)', 'LINESTRING(0 0, "
 "0.2 0.5, 1 0)') );\n"
@@ -548,12 +541,6 @@ msgid ""
 "--------------\n"
 "           45"
 msgstr ""
-"postgis=# SELECT st_hausdorffdistance('LINESTRING (130 0, 0 0, 0 150)'::"
-"geometry, 'LINESTRING (10 10, 10 150, 130 10)'::geometry, 0.5);\n"
-" st_hausdorffdistance\n"
-" ----------------------\n"
-"                                        70\n"
-"(1 row)"
 #. Tag: refname
 #: reference_measure.xml:221
commit 39ff618ffdeb04989da312ef259a0208296a539d
Date:   Wed Jul 12 19:12:16 2023 +0000
    Translated using Weblate (German)
    Currently translated at 49.0% (149 of 304 strings)
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_measurexml/de/
diff --git a/doc/po/de/reference_measure.xml.po b/doc/po/de/reference_measure.xml.po
index ce14f7965..14885db64 100644
--- a/doc/po/de/reference_measure.xml.po
+++ b/doc/po/de/reference_measure.xml.po
-"PO-Revision-Date: 2023-01-09 04:42+0000\n"
 "Language-Team: German <https://weblate.osgeo.org/projects/postgis/"
 "reference_measurexml/de/>\n"
@@ -16,7 +16,7 @@ msgstr ""
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
 "Plural-Forms: nplurals=2; plural=n != 1;\n"
-"X-Generator: Weblate 4.15\n"
+"X-Generator: Weblate 4.16.4\n"
 #. Tag: para
 #: reference_measure.xml:5
@@ -599,7 +599,7 @@ msgstr ""
+#, no-c-format
 msgid ""
@@ -608,12 +608,6 @@ msgid ""
 "--------------\n"
 "           45"
 msgstr ""
-"SELECT st_frechetdistance('LINESTRING (0 0, 100 0)'::geometry, 'LINESTRING "
-"(0 0, 50 50, 100 0)'::geometry, 0.5);\n"
-" st_frechetdistance\n"
-"--------------------\n"
-"                 50\n"
-"(1 row)"
 #. Tag: refname
Summary of changes:
 doc/po/de/reference_measure.xml.po    | 12 +++---------
 doc/po/it_IT/reference_measure.xml.po | 19 +++----------------
 2 files changed, 6 insertions(+), 25 deletions(-)
hooks/post-receive
