[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1233-g2e149c756
Thu Jul 13 00:12:34 PDT 2023
the project "PostGIS".
       via  2e149c75634d2f352150313a0b0b0666e1b57198 (commit)
      from  eab031d713e1f948bfffd81fe4dcfc6efab7e349 (commit)
revisions in full, below.
commit 2e149c75634d2f352150313a0b0b0666e1b57198
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jul 13 09:11:58 2023 +0200
    [de] Fix ST_Collect synopsis translation
    References #5440
diff --git a/doc/po/de/reference_constructor.xml.po b/doc/po/de/reference_constructor.xml.po
index 3e7923826..48651b184 100644
--- a/doc/po/de/reference_constructor.xml.po
+++ b/doc/po/de/reference_constructor.xml.po
@@ -50,14 +50,14 @@ msgid ""
 "<function>ST_Collect</function></funcdef> <paramdef><type>geometry set</"
 "type> <parameter>g1field</parameter></paramdef> </funcprototype>"
 msgstr ""
-"<funcprototype> <funcdef>geometry <function>ST_GeomFromGeoJSON</function></"
-"funcdef> <paramdef><type>text </type> <parameter>geomjson</parameter></"
-"paramdef> </funcprototype> <funcprototype> <funcdef>geometry "
-"<function>ST_GeomFromGeoJSON</function></funcdef> <paramdef><type>json </"
-"type> <parameter>geomjson</parameter></paramdef> </funcprototype> "
-"funcdef> <paramdef><type>jsonb </type> <parameter>geomjson</parameter></"
-"paramdef> </funcprototype>"
+"<funcprototype> <funcdef>geometry <function>ST_Collect</function></funcdef> "
+"<paramdef><type>geometry</type> <parameter>g1</parameter></paramdef> "
+"<paramdef><type>geometry</type> <parameter>g2</parameter></paramdef> </"
+"funcprototype> <funcprototype> <funcdef>geometry <function>ST_Collect</"
+"function></funcdef> <paramdef><type>geometry[]</type> <parameter>g1_array</"
+"parameter></paramdef> </funcprototype> <funcprototype> <funcdef>geometry "
+"<function>ST_Collect</function></funcdef> <paramdef><type>geometry set</"
+"type> <parameter>g1field</parameter></paramdef> </funcprototype>"
 #. Tag: title
 #: reference_constructor.xml:30 reference_constructor.xml:109
Summary of changes:
 doc/po/de/reference_constructor.xml.po | 16 ++++++++--------
 1 file changed, 8 insertions(+), 8 deletions(-)
hooks/post-receive
