[postgis-tickets] [PostGIS] #5435: localize cheatsheets
PostGIS trac at osgeo.org
Thu Jul 13 00:49:28 PDT 2023
  Reporter:  robe           |      Owner:  robe
      Type:  task           |     Status:  new
  Priority:  medium         |  Milestone:  PostGIS 3.4.0
 Component:  documentation  |    Version:  master
Resolution:                 |   Keywords:
Comment (by strk):
 Next issue we have is formalization of the `requires GEOS > 3.9` snippet,
 which is currently used by cheatsheet xsl and broken when translated.
 Formalization would also be useful to really specify what it means.
 Right now it's sometimes associated with "availability" and sometimes with
 "enhanced" tag:
 reference_overlay.xml:        <para role="enhanced"
 conformance="3.1.0">Enhanced: 3.1.0 accept a gridSize parameter - requires
 GEOS >= 3.9.0</para>
 conformance="3.1.0">Enhanced: 3.1.0 accept a gridSize parameter, requires
 GEOS >= 3.9.0 to use this new feature.</para>
 reference_processing.xml:        <para role="availability"
 conformance="3.1.0">Availability: 3.1.0 - requires GEOS >=
 3.9.0.</para>
 conformance="3.4.0">Availability: 3.4.0 - requires GEOS >=
 3.9.0.</para>
 conformance="3.1.0">Availability: 3.1.0 - requires GEOS >= 3.9.0.
 </para>
 I guess it means it requires that version of GEOS _only_ to use that
 specific new feature ?
 How about completely dropping this indication from the cheatsheets ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5435#comment:17>
