[postgis-tickets] [PostGIS] #5441: winnie is trying to build translation docs
PostGIS trac at osgeo.org
Thu Jul 13 03:50:32 PDT 2023
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  blocker                |  Milestone:  PostGIS 3.4.0
Component:  build/upgrade/install  |    Version:  3.3.x
 Keywords:                         |
 Looks like winnie's windows builds stopped on 7/3/2023.
 Looks like it is failing on make install because she's trying to build
 translations.
 I don't need docs built.  Need to have a way to turn this off.
 Example error:
 https://winnie.postgis.net/job/PostGIS_2_windows_PGVERSION_winnie/14464/console
 She doesn't even have ability to build pdfs so why is pdf-clean even
 running
 make[3]: Leaving directory '/projects/postgis/branches/3.4/doc/po/ru'
 make[2]: Leaving directory '/projects/postgis/branches/3.4/doc/po/ru'
 rm -f postgis*-en.pdf
 rule=pdf-clean; \
 for lang in it_IT pt_BR fr es pl ko_KR de ja ru; do \
     echo "Making $rule for language $lang..."; \
     make -C po/$lang local-$rule || exit 1; \
   done
 Making pdf-clean for language it_IT...
 make[2]: Entering directory '/projects/postgis/branches/3.4/doc/po/it_IT'
 ln -sf ../../html .
 ln: ./html: cannot overwrite directory
 make[2]: *** [../Makefile.local:21: symlinks] Error 1
 make[2]: Leaving directory '/projects/postgis/branches/3.4/doc/po/it_IT'
 make[1]: *** [Makefile:347: pdf-clean-localized] Error 1
 make[1]: Leaving directory '/projects/postgis/branches/3.4/doc'
 make: *** [GNUmakefile:188: docs-clean] Error 2
 E:\jenkins\postgis>E:
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5441>
