[postgis-tickets] [PostGIS] #5441: winnie is trying to build translation docs
PostGIS trac at osgeo.org
Thu Jul 13 05:44:26 PDT 2023
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  3.3.x
Resolution:                         |   Keywords:
Comment (by strk):
 The other thing is that the message `cannot overwrite directory` should
 happen when the target is a real directory, if you give me access to the
 machine I'll check that out so I can also verify an eventual fix
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5441#comment:3>
