[postgis-tickets] [PostGIS] #5441: winnie is trying to build translation docs
PostGIS trac at osgeo.org
Fri Jul 14 00:05:57 PDT 2023
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  3.3.x
Resolution:  fixed                  |   Keywords:
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"ab511bf34c90759769e6782ac1a0915972191690/git" ab511bf/git]:
 {{{#!CommitTicketReference repository="git"
 revision="ab511bf34c90759769e6782ac1a0915972191690"
 Use -rf to remove the html and xsl files under po/*
 Worksaround lack of symlinks in windows
 References #5441
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5441#comment:9>
