[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1247-ge63ad7402
Fri Jul 14 00:50:12 PDT 2023
the project "PostGIS".
       via  e63ad7402c62de04e3cae32b12d980c230a80038 (commit)
       via  1fba0a7e56b6f53756280dec4b6146853b43dcd6 (commit)
      from  ab511bf34c90759769e6782ac1a0915972191690 (commit)
revisions in full, below.
commit e63ad7402c62de04e3cae32b12d980c230a80038
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Jul 14 09:49:53 2023 +0200
    Simplify symlink processing
diff --git a/doc/po/Makefile.local b/doc/po/Makefile.local
index 1113da625..cd2f464bd 100644
--- a/doc/po/Makefile.local
+++ b/doc/po/Makefile.local
@@ -13,11 +13,11 @@ local-clean: local-html-clean local-pdf-clean local-epub-clean local-cheatsheet-
 local-distclean:
 	rm -f Makefile
-local-%: symlinks
+local-%: xsl
 	$(MAKE) $(patsubst local-%,%,$@) DOCSUFFIX=$(DOCSUFFIX)
-symlinks:
-	test -e xsl || ln -sf $(srcdir)/../../xsl .
+xsl:
+	ln -sf $(srcdir)/../../xsl .
 # for XML_SOURCES
 include ../../Makefile
commit 1fba0a7e56b6f53756280dec4b6146853b43dcd6
Date:   Fri Jul 14 09:30:40 2023 +0200
    Use a variable for HTML output dir, stop using symlink for localized
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 7650caf93..95a3b005b 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -45,6 +45,8 @@ POSTGIS_MINOR_VERSION=@POSTGIS_MINOR_VERSION@
 POSTGIS_MICRO_VERSION=@POSTGIS_MICRO_VERSION@
 DOCSUFFIX=-en
+# TODO: change this ?
+HTML_OUT_DIR=$(abs_builddir)/html
 ifneq (,$(findstring dev,$(POSTGIS_MICRO_VERSION)))
   POSTGIS_DOWNLOAD_URL=http://postgis.net/stuff
@@ -236,7 +238,7 @@ GENERATED_COMMENT_FILES = $(patsubst \
 GENERATED_CHEATSHEET_FILES = $(patsubst \
 	$(abs_srcdir)/xsl/%.html.xsl, \
-	html/%$(DOCSUFFIX).html, \
+	$(HTML_OUT_DIR)/%$(DOCSUFFIX).html, \
 	$(wildcard $(abs_srcdir)/xsl/*_cheatsheet.html.xsl) \
@@ -306,23 +308,23 @@ endif
 $(GENERATED_COMMENT_FILES): %.sql: xsl/%.sql.xsl $(XML_INPUTS) postgis-out.xml
 	$(XSLTPROC) --novalid $(XSLTPROC_PATH_OPT) -o $@ $< postgis-out.xml
-$(GENERATED_CHEATSHEET_FILES): html/%$(DOCSUFFIX).html: xsl/%.html.xsl $(XML_INPUTS) postgis-out.xml xsl/common_cheatsheet.xsl xsl/common_utils.xsl
+$(GENERATED_CHEATSHEET_FILES): $(HTML_OUT_DIR)/%$(DOCSUFFIX).html: xsl/%.html.xsl $(XML_INPUTS) postgis-out.xml xsl/common_cheatsheet.xsl xsl/common_utils.xsl
 	$(XSLTPROC) --novalid $(XSLTPROC_PATH_OPT) $(XSLTPROC_CUSTOM_VARS) -o $@ $< postgis-out.xml
 # TODO: use a postgis_release_version variable passed via --stringparam
 postgis-out.xml: postgis.xml Makefile
 	$(PERL) -lpe "s'@@LAST_RELEASE_VERSION@@'${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}'g;s'@@POSTGIS_DOWNLOAD_URL@@'${POSTGIS_DOWNLOAD_URL}'g;" $< > $@
-chunked-html: html/postgis$(DOCSUFFIX)/docbook.css
-html/postgis$(DOCSUFFIX)/docbook.css: postgis-out.xml Makefile $(XML_INPUTS)
+chunked-html: $(HTML_OUT_DIR)/postgis$(DOCSUFFIX)/docbook.css
+$(HTML_OUT_DIR)/postgis$(DOCSUFFIX)/docbook.css: postgis-out.xml Makefile $(XML_INPUTS)
 	$(XSLTPROC) $(XSLTPROC_COMMONOPTS) \
 		$(XSLTPROC_CHUNKED_HTML_OPTS) \
 		--output $(dir $@) \
 		$(CHUNK_HTML_DOCBOOK_XSL) \
-chunked-html-web: html/postgis-web$(DOCSUFFIX)/docbook.css
-html/postgis-web$(DOCSUFFIX)/docbook.css: postgis-out.xml Makefile $(XML_INPUTS)
+chunked-html-web: $(HTML_OUT_DIR)/postgis-web$(DOCSUFFIX)/docbook.css
+$(HTML_OUT_DIR)/postgis-web$(DOCSUFFIX)/docbook.css: postgis-out.xml Makefile $(XML_INPUTS)
@@ -331,8 +333,8 @@ html/postgis-web$(DOCSUFFIX)/docbook.css: postgis-out.xml Makefile $(XML_INPUTS)
 HTML_BITS = $(wildcard html/*.html)
-chunked-html-web-mobile: html/postgis-web-mobile$(DOCSUFFIX)/docbook.css
-html/postgis-web-mobile$(DOCSUFFIX)/docbook.css: postgis-out.xml Makefile $(XML_INPUTS)
+chunked-html-web-mobile: $(HTML_OUT_DIR)/postgis-web-mobile$(DOCSUFFIX)/docbook.css
+$(HTML_OUT_DIR)/postgis-web-mobile$(DOCSUFFIX)/docbook.css: postgis-out.xml Makefile $(XML_INPUTS)
@@ -341,7 +343,7 @@ html/postgis-web-mobile$(DOCSUFFIX)/docbook.css: postgis-out.xml Makefile $(XML_
 	$(PERL) -pi -e 's/<head>/<head><meta name="viewport" content="width=device-width, initial-scale=1, shrink-to-fit=no">/g' $(HTML_BITS)
-html: html/postgis$(DOCSUFFIX).html
+html: $(HTML_OUT_DIR)/postgis$(DOCSUFFIX).html
 %-localized:
 	rule=$(patsubst %-localized,%,$@); \
@@ -350,10 +352,10 @@ html: html/postgis$(DOCSUFFIX).html
     $(MAKE) -C po/$$lang local-$$rule || exit 1; \
   done
-html/postgis$(DOCSUFFIX).html: postgis-out.xml Makefile $(XML_INPUTS)
+$(HTML_OUT_DIR)/postgis$(DOCSUFFIX).html: postgis-out.xml Makefile $(XML_INPUTS)
 		--stringparam html.stylesheet style.css \
-		--output html/postgis$(DOCSUFFIX).html \
+		--output $(HTML_OUT_DIR)/postgis$(DOCSUFFIX).html \
 		$(HTML_DOCBOOK_XSL) \
@@ -424,10 +426,10 @@ images images-install images-uninstall images-clean:
 	$(MAKE) -C html/images $@
 html-clean:
-	rm -f html/postgis$(DOCSUFFIX).html
-	rm -rf html/postgis$(DOCSUFFIX)/
-	rm -rf html/postgis-web$(DOCSUFFIX)/
-	rm -rf html/postgis-web-mobile$(DOCSUFFIX)/
+	rm -f $(HTML_OUT_DIR)/postgis$(DOCSUFFIX).html
+	rm -rf $(HTML_OUT_DIR)/postgis$(DOCSUFFIX)/
+	rm -rf $(HTML_OUT_DIR)/postgis-web$(DOCSUFFIX)/
+	rm -rf $(HTML_OUT_DIR)/postgis-web-mobile$(DOCSUFFIX)/
 pdf-clean:
 	rm -f postgis*$(DOCSUFFIX).pdf
@@ -496,30 +498,30 @@ man-uninstall:
 	rm -f $(DESTDIR)$(mandir)/man1/pgtopo_export.1
 	rm -f $(DESTDIR)$(mandir)/man1/pgtopo_import.1
-html-install: html/postgis$(DOCSUFFIX).html
+html-install: $(HTML_OUT_DIR)/postgis$(DOCSUFFIX).html
 	mkdir -p $(DESTDIR)$(htmldir)
-	$(INSTALL_DATA) html/postgis$(DOCSUFFIX).html $(DESTDIR)$(htmldir)/
+	$(INSTALL_DATA) $(HTML_OUT_DIR)/postgis$(DOCSUFFIX).html $(DESTDIR)$(htmldir)/
 html-uninstall:
 	rm -f $(DESTDIR)$(htmldir)/postgis$(DOCSUFFIX).html
 chunked-html-install: chunked-html
-	cp -R html/postgis$(DOCSUFFIX) $(DESTDIR)$(htmldir)/
+	cp -R $(HTML_OUT_DIR)/postgis$(DOCSUFFIX) $(DESTDIR)$(htmldir)/
 chunked-html-uninstall:
 	rm -rf $(DESTDIR)$(htmldir)/postgis$(DOCSUFFIX)/
 chunked-html-web-install: chunked-html-web
-	cp -R html/postgis-web$(DOCSUFFIX) $(DESTDIR)$(htmldir)/
+	cp -R $(HTML_OUT_DIR)/postgis-web$(DOCSUFFIX) $(DESTDIR)$(htmldir)/
 chunked-html-web-uninstall:
 	rm -rf $(DESTDIR)$(htmldir)/postgis-web$(DOCSUFFIX)/
 chunked-html-web-mobile-install: chunked-html-web-mobile
-	cp -R html/postgis-web-mobile$(DOCSUFFIX) $(DESTDIR)$(htmldir)/
+	cp -R $(HTML_OUT_DIR)/postgis-web-mobile$(DOCSUFFIX) $(DESTDIR)$(htmldir)/
 chunked-html-web-mobile-uninstall:
 	rm -rf $(DESTDIR)$(htmldir)/postgis-web-mobile$(DOCSUFFIX)/
@@ -562,7 +564,7 @@ check-xml: $(XML_INPUTS)
 	$(XMLLINT) --loaddtd $(XSLTPROC_PATH_OPT) --xinclude --valid postgis-out.xml --noout
 check-cheatsheets: cheatsheets
-	for f in $(abs_builddir)/html/*_cheatsheet-en.html; do \
+	for f in $(abs_builddir)/$(HTML_OUT_DIR)/*_cheatsheet-en.html; do \
 		$(abs_top_srcdir)/utils/check_localized_cheatsheets.sh $${f} en $(patsubst -%,%,$(DOCSUFFIX)) || exit 1; \
 	done
index a282d0ce4..1113da625 100644
@@ -7,7 +7,6 @@ local-all: local-html comments
 local-clean: local-html-clean local-pdf-clean local-epub-clean local-cheatsheet-clean
 	rm -f images # work around https://trac.osgeo.org/postgis/ticket/5422
 	rm -f $(XML_INPUTS)
-	rm -rf html
 	rm -rf xsl
 # We do not want to recurse in parent dir here
@@ -18,7 +17,6 @@ local-%: symlinks
 symlinks:
-	test -e html || ln -sf ../../html .
 # for XML_SOURCES
Summary of changes:
 doc/Makefile.in       | 44 +++++++++++++++++++++++---------------------
 doc/po/Makefile.local |  8 +++-----
 2 files changed, 26 insertions(+), 26 deletions(-)
hooks/post-receive
