[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1253-gaa5466846
Fri Jul 14 03:08:38 PDT 2023
the project "PostGIS".
       via  aa5466846937c8d8c84966b0ea914857c572ee2e (commit)
       via  09b2fc61d49318c3262ddad04664665c678c22ed (commit)
       via  5521d92ff819d54c877cd2a313b14f0613e3ac13 (commit)
       via  127794235965d1fbaa76e4a0c67f84031bf09046 (commit)
       via  5f3424fa465a225d84ed3495c43c6d7570d1bff9 (commit)
      from  5c9b758146a7a98e26c19935deb34a99a8122c00 (commit)
revisions in full, below.
commit aa5466846937c8d8c84966b0ea914857c572ee2e
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date:   Fri Jul 14 08:46:44 2023 +0000
    Translated reference_coverage using Weblate (Japanese)
    Currently translated at 100.0% (39 of 39 strings)
    Translation: postgis/reference_coverage
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_coverage/ja/
diff --git a/doc/po/ja/reference_coverage.xml.po b/doc/po/ja/reference_coverage.xml.po
index eab629171..4fa32d87b 100644
--- a/doc/po/ja/reference_coverage.xml.po
+++ b/doc/po/ja/reference_coverage.xml.po
@@ -7,7 +7,7 @@ msgstr ""
 "Project-Id-Version: ming 64gcc81\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-07-12 18:27+0000\n"
-"PO-Revision-Date: 2023-07-11 05:08+0000\n"
+"PO-Revision-Date: 2023-07-14 10:08+0000\n"
 "Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
 "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
 "reference_coverage/ja/>\n"
@@ -44,7 +44,7 @@ msgstr "カバレッジ"
 #: reference_coverage.xml:15
 #, no-c-format
 msgid "ST_CoverageInvalidEdges"
-msgstr ""
+msgstr "ST_CoverageInvalidEdges"
 #. Tag: refpurpose
 #: reference_coverage.xml:17
@@ -64,6 +64,10 @@ msgid ""
 "paramdef> <paramdef><type>float8 </type> <parameter>tolerance = 0</"
 "parameter></paramdef>"
 msgstr ""
+"<funcdef>geometry <function>ST_CoverageInvalidEdges</function></funcdef> "
+"<paramdef><type>geometry winset </type> <parameter>geom</parameter></"
+"paramdef> <paramdef><type>float8 </type> <parameter>tolerance = "
+"0</parameter></paramdef>"
 #. Tag: title
 #: reference_coverage.xml:33 reference_coverage.xml:120
@@ -194,6 +198,25 @@ msgid ""
 "  3 | LINESTRING (140 80, 140 190)\n"
 "  3 | null"
 msgstr ""
+"WITH coverage(id, geom) AS (VALUES\n"
+"  (1, 'POLYGON ((10 190, 30 160, 40 110, 100 70, 120 10, 10 10, 10 "
+"190))'::geometry),\n"
+"  (2, 'POLYGON ((100 190, 10 190, 30 160, 40 110, 50 80, 74 110.5, 100 130, "
+"140 120, 140 160, 100 190))'::geometry),\n"
+"  (3, 'POLYGON ((140 190, 190 190, 190 80, 140 80, 140 190))'::geometry),\n"
+"  (4, 'POLYGON ((180 40, 120 10, 100 70, 140 80, 190 80, 180 40))'::geometry)"
+"\n"
+")\n"
+"SELECT id, ST_AsText(ST_CoverageInvalidEdges(geom) OVER ())\n"
+"  FROM coverage;\n"
+"\n"
+" id |               st_astext\n"
+"----+---------------------------------------\n"
+"  1 | LINESTRING (40 110, 100 70)\n"
+"  2 | MULTILINESTRING ((100 130, 140 120, 140 160, 100 190), (40 110, 50 80, "
+"74 110.5))\n"
+"  3 | LINESTRING (140 80, 140 190)\n"
+"  3 | null"
 #. Tag: programlisting
 #: reference_coverage.xml:83
@@ -205,6 +228,11 @@ msgid ""
 "    FROM coverage\n"
 msgstr ""
+"-- カバレッジ妥当性のためにテーブル全体をテストする\n"
+"SELECT true = ALL (\n"
+"    SELECT ST_CoverageInvalidEdges(geom) OVER () IS NULL\n"
+"    FROM coverage\n"
 #. Tag: title
 #: reference_coverage.xml:87 reference_coverage.xml:177
@@ -299,6 +327,10 @@ msgid ""
 "appeared to be shared). Use <xref linkend=\"ST_CoverageInvalidEdges\"/> to "
 "determine if a coverage is valid."
 msgstr ""
+"入力が妥当なカバレッジでない場合には、出力に予期しない何か (境界のインタセク"
+"ト、共有されているように見えるのに分かれている境界)が出現する可能性があります"
+"。カバレッジが妥当かどうかを判断するには<xref linkend="
+"\"ST_CoverageInvalidLocations\"/>を使います。"
 #. Tag: para
 #: reference_coverage.xml:154 reference_coverage.xml:230
@@ -411,6 +443,10 @@ msgid ""
 "the output (such as unmerged or overlapping polygons). Use <xref "
 "linkend=\"ST_CoverageInvalidEdges\"/> to determine if a coverage is valid."
 msgstr ""
+"入力が妥当なカバレッジでない場合には、出力に予期しない何か (マージされていな"
+"いポリゴンやオーバラップするポリゴン)が出現する可能性があります。"
+"カバレッジが妥当かどうかを判断するには<xref linkend="
 #. Tag: para
 #: reference_coverage.xml:215
commit 09b2fc61d49318c3262ddad04664665c678c22ed
Date:   Fri Jul 14 08:42:07 2023 +0000
    Translated using Weblate (Japanese)
    Currently translated at 100.0% (112 of 112 strings)
    Translation: postgis/reference_lrs.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_lrsxml/ja/
diff --git a/doc/po/ja/reference_lrs.xml.po b/doc/po/ja/reference_lrs.xml.po
index 8f9002700..674e3c8a1 100644
--- a/doc/po/ja/reference_lrs.xml.po
+++ b/doc/po/ja/reference_lrs.xml.po
 "Project-Id-Version: PostGIS\n"
-"PO-Revision-Date: 2023-05-15 11:08+0000\n"
 "reference_lrsxml/ja/>\n"
@@ -51,6 +51,16 @@ msgid ""
 "choice=\"opt\"><type>boolean </type><parameter>use_spheroid = true</"
 "parameter></paramdef> </funcprototype>"
 msgstr ""
+"<funcprototype> <funcdef>geometry "
+"<function>ST_LineInterpolatePoint</function></funcdef> "
+"<paramdef><type>geometry </type> <parameter>a_linestring</parameter></"
+"paramdef> <paramdef><type>float8 </type> <parameter>a_fraction</parameter></"
+"paramdef> </funcprototype> <funcprototype> <funcdef>geography "
+"<paramdef><type>geography </type> <parameter>a_linestring</parameter></"
+"paramdef> <paramdef choice=\"opt\"><type>boolean </"
+"type><parameter>use_spheroid = true</parameter></paramdef> </funcprototype>"
 #. Tag: title
 #: reference_lrs.xml:31 reference_lrs.xml:111 reference_lrs.xml:180
@@ -347,6 +357,19 @@ msgid ""
 "parameter></paramdef> <paramdef choice=\"opt\"><type>boolean </type> "
 "<parameter>repeat = true</parameter></paramdef> </funcprototype>"
 msgstr ""
+"<function>ST_LineInterpolatePoints</function></funcdef> "
+"paramdef> <paramdef><type>boolean </type> <parameter>repeat</parameter></"
+"type><parameter>use_spheroid = true</parameter></paramdef> <paramdef choice="
+"\"opt\"><type>boolean </type> <parameter>repeat = true</parameter></"
+"paramdef> </funcprototype>"
 #. Tag: para
 #: reference_lrs.xml:182
@@ -446,6 +469,16 @@ msgid ""
 "<paramdef choice=\"opt\"><type>boolean </type><parameter>use_spheroid = "
 "true</parameter></paramdef> </funcprototype>"
 msgstr ""
+"<funcprototype> <funcdef>float8 <function>ST_LineLocatePoint</function></"
+"funcdef> <paramdef><type>geometry </type> "
+"<parameter>a_linestring</parameter></paramdef> <paramdef><type>geometry </"
+"type> <parameter>a_point</parameter></paramdef> </funcprototype> "
+"funcdef> <paramdef><type>geography </type> "
+"<parameter>a_linestring</parameter></paramdef> <paramdef><type>geography </"
+"type> <parameter>a_point</parameter></paramdef> <paramdef choice=\"opt\""
+"><type>boolean </type><parameter>use_spheroid = true</parameter></paramdef> "
+"</funcprototype>"
 #. Tag: para
 #: reference_lrs.xml:254
@@ -598,6 +631,16 @@ msgid ""
 "<parameter>startfraction</parameter></paramdef> <paramdef><type>float8 </"
 "type> <parameter>endfraction</parameter></paramdef> </funcprototype>"
 msgstr ""
+"<funcprototype> <funcdef>geometry <function>ST_LineSubstring</function></"
+"<parameter>a_linestring</parameter></paramdef> <paramdef><type>float8 </"
+"type> <parameter>startfraction</parameter></paramdef> <paramdef><type>float8 "
+"</type> <parameter>endfraction</parameter></paramdef> </funcprototype> "
+"<funcprototype> <funcdef>geography <function>ST_LineSubstring</function></"
+"</type> <parameter>endfraction</parameter></paramdef> </funcprototype>"
 #. Tag: para
 #: reference_lrs.xml:311
commit 5521d92ff819d54c877cd2a313b14f0613e3ac13
Date:   Fri Jul 14 08:43:19 2023 +0000
    Currently translated at 100.0% (88 of 88 strings)
    Translation: postgis/administration.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/administrationxml/ja/
diff --git a/doc/po/ja/administration.xml.po b/doc/po/ja/administration.xml.po
index b0765a778..6540d6210 100644
--- a/doc/po/ja/administration.xml.po
+++ b/doc/po/ja/administration.xml.po
@@ -1,11 +1,11 @@
 # SOME DESCRIPTIVE TITLE.
-# Teramoto Ikuhiro <yellow at affrc.go.jp>, 2022.
+# Teramoto Ikuhiro <yellow at affrc.go.jp>, 2022, 2023.
 msgid ""
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "POT-Creation-Date: 2023-05-25 20:53+0000\n"
-"PO-Revision-Date: 2022-09-27 07:04+0000\n"
 "administrationxml/ja/>\n"
@@ -14,7 +14,7 @@ msgstr ""
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
 "Plural-Forms: nplurals=1; plural=0;\n"
-"X-Generator: Weblate 4.14.1\n"
+"X-Generator: Weblate 4.16.4\n"
 #. Tag: title
 #: administration.xml:3
commit 127794235965d1fbaa76e4a0c67f84031bf09046
Date:   Fri Jul 14 08:41:13 2023 +0000
    Currently translated at 100.0% (155 of 155 strings)
    Translation: postgis/reference_overlay.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_overlayxml/ja/
diff --git a/doc/po/ja/reference_overlay.xml.po b/doc/po/ja/reference_overlay.xml.po
index a65990968..6d278bcf5 100644
--- a/doc/po/ja/reference_overlay.xml.po
+++ b/doc/po/ja/reference_overlay.xml.po
@@ -6,7 +6,7 @@ msgstr ""
 "POT-Creation-Date: 2023-07-13 08:07+0000\n"
-"PO-Revision-Date: 2023-07-03 03:08+0000\n"
 "reference_overlayxml/ja/>\n"
@@ -211,13 +211,13 @@ msgstr "GEOSモジュールで実現しています。"
 #: reference_overlay.xml:768 reference_overlay.xml:874
 #, no-c-format
 msgid "Enhanced: 3.1.0 accept a gridSize parameter."
-msgstr ""
+msgstr "Enhanced: 3.1.0 gridSizeパラメータを受け付けるようになりました。"
 #. Tag: para
 #: reference_overlay.xml:98
 #, no-c-format
 msgid "Requires GEOS >= 3.9.0 to use the gridSize parameter."
-msgstr ""
+msgstr "gridSizeパラメータを使うにはGEOS 3.9.0以上が必要です。"
 #. Tag: para
 #: reference_overlay.xml:100 reference_overlay.xml:225
@@ -438,7 +438,7 @@ msgstr ""
 #: reference_overlay.xml:220
 #, no-c-format
 msgid "Enhanced: 3.1.0 accept a gridSize parameter"
-msgstr ""
+msgstr "Enhanced: 3.1.0 gridSizeパラメータを受け付けるようになりました"
 #. Tag: para
 #: reference_overlay.xml:221 reference_overlay.xml:549
@@ -446,7 +446,7 @@ msgstr ""
 #: reference_overlay.xml:875
 #, no-c-format
 msgid "Requires GEOS >= 3.9.0 to use the gridSize parameter"
-msgstr ""
+msgstr "gridSizeパラメータを使うにはGEOS 3.9.0以上が必要です"
 #. Tag: para
 #: reference_overlay.xml:222 reference_overlay.xml:876
commit 5f3424fa465a225d84ed3495c43c6d7570d1bff9
Date:   Fri Jul 14 08:22:13 2023 +0000
    Currently translated at 100.0% (426 of 426 strings)
    Translation: postgis/reference_processing.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_processingxml/ja/
diff --git a/doc/po/ja/reference_processing.xml.po b/doc/po/ja/reference_processing.xml.po
index b0712ffe6..694880af0 100644
--- a/doc/po/ja/reference_processing.xml.po
+++ b/doc/po/ja/reference_processing.xml.po
@@ -10,7 +10,7 @@ msgstr ""
 "reference_processingxml/ja/>\n"
@@ -766,6 +766,12 @@ msgid ""
 "      ST_GeomFromText('POINT(100 90)'), 25) As smallc,\n"
 "    ST_Buffer(ST_GeomFromText('POINT(100 90)'), 50) As bigc) As foo;"
 msgstr ""
+"<lineannotation>ポリゴンを使う</lineannotation>\n"
+"SELECT ST_BuildArea(ST_Collect(smallc,bigc))\n"
+"FROM (SELECT\n"
+"    ST_Buffer(\n"
+"      ST_GeomFromText('POINT(100 90)'), 25) As smallc,\n"
+"    ST_Buffer(ST_GeomFromText('POINT(100 90)'), 50) As bigc) As foo;"
 #: reference_processing.xml:340
@@ -779,6 +785,13 @@ msgid ""
 "    ST_ExteriorRing(ST_Buffer(ST_GeomFromText('POINT(100 90)'), 50)) As "
 "bigc) As foo;"
 msgstr ""
+"<lineannotation>ラインストリングを使う</lineannotation>\n"
+"FROM (SELECT\n"
+"    ST_ExteriorRing(ST_Buffer(\n"
+"      ST_GeomFromText('POINT(100 90)'), 25)) As smallc,\n"
+"    ST_ExteriorRing(ST_Buffer(ST_GeomFromText('POINT(100 90)'), 50)) As bigc)"
+" As foo;"
 #. Tag: para
 #: reference_processing.xml:351
@@ -1757,6 +1770,11 @@ msgid ""
 "        ST_Buffer(ST_GeomFromText('POINT(110 170)'), 20)\n"
 msgstr ""
+"<lineannotation>元のジオメトリ</lineannotation>\n"
+"    ST_Union(ST_GeomFromText('POLYGON((175 150, 20 40,\n"
+"            50 60, 125 100, 175 150))'),\n"
+"        ST_Buffer(ST_GeomFromText('POINT(110 170)'), 20)\n"
 #. Tag: para
 #: reference_processing.xml:893
@@ -1783,6 +1801,16 @@ msgid ""
 "        ))\n"
 "     As  dtriag;"
 msgstr ""
+"<lineannotation>\n"
+"マルチラインストリングの三角形を重ねたジオメトリ\n"
+"</lineannotation>\n"
+"SELECT\n"
+"    ST_DelaunayTriangles(\n"
+"        ))\n"
+"     As  dtriag;"
 #. Tag: para
 #: reference_processing.xml:903
@@ -1847,6 +1875,32 @@ msgid ""
 "POLYGON((154 14,14 154,150 14,154 14))\n"
 "POLYGON((154 14,150 14,154 6,154 14))"
 msgstr ""
+"これによりL字型を形成する42点のテーブルが生成されます\n"
+"SELECT (ST_DumpPoints(ST_GeomFromText(\n"
+"'MULTIPOINT(14 14,34 14,54 14,74 14,94 14,114 14,134 14,\n"
+"150 14,154 14,154 6,134 6,114 6,94 6,74 6,54 6,34 6,\n"
+"14 6,10 6,8 6,7 7,6 8,6 10,6 30,6 50,6 70,6 90,6 110,6 130,\n"
+"6 150,6 170,6 190,6 194,14 194,14 174,14 154,14 134,14 114,\n"
+"14 94,14 74,14 54,14 34,14 14)'))).geom\n"
+"    INTO TABLE l_shape;\n"
+"個々のポリゴン三角形として出力\n"
+"SELECT ST_AsText((ST_Dump(geom)).geom) As wkt\n"
+"FROM ( SELECT ST_DelaunayTriangles(ST_Collect(geom)) As geom\n"
+"FROM l_shape) As foo;\n"
+"\n"
+"wkt\n"
+"POLYGON((6 194,6 190,14 194,6 194))\n"
+"POLYGON((14 194,6 190,14 174,14 194))\n"
+"POLYGON((14 194,14 174,154 14,14 194))\n"
+"POLYGON((154 14,14 174,14 154,154 14))\n"
+"POLYGON((154 14,14 154,150 14,154 14))\n"
+"POLYGON((154 14,150 14,154 6,154 14))"
 #. Tag: para
 #: reference_processing.xml:925
@@ -1870,6 +1924,17 @@ msgid ""
 "GEOMETRYCOLLECTION Z (POLYGON Z ((14 14 10,20 10 150,34 6 25,14 14 10))\n"
 " ,POLYGON Z ((14 14 10,34 6 25,150 14 100,14 14 10)))"
 msgstr ""
+"3次元マルチポイント\n"
+"SELECT ST_AsText(ST_DelaunayTriangles(ST_GeomFromText(\n"
+"         'MULTIPOINT Z(14 14 10, 150 14 100,34 6 25, 20 10 150)'))) As wkt;\n"
+"\n"
+"wkt\n"
+"GEOMETRYCOLLECTION Z (POLYGON Z ((14 14 10,20 10 150,34 6 25,14 14 10))\n"
+" ,POLYGON Z ((14 14 10,34 6 25,150 14 100,14 14 10)))"
 #. Tag: para
 #: reference_processing.xml:931
@@ -1991,6 +2056,15 @@ msgid ""
 "----------------------------\n"
 " LINESTRING(5 2,7 25,10 10)"
 msgstr ""
+"SELECT ST_AsText(ST_FilterByM(geom,30)) simplified\n"
+"FROM (SELECT  ST_SetEffectiveArea('LINESTRING(5 2, 3 8, 6 20, 7 25, 10 "
+"10)'::geometry) geom) As foo;\n"
+"結果\n"
+"         simplified\n"
+"----------------------------\n"
+" LINESTRING(5 2,7 25,10 10)"
 #. Tag: para
 #: reference_processing.xml:983
@@ -2282,13 +2356,13 @@ msgstr ""
 #: reference_processing.xml:1168
 #, no-c-format
 msgid "Enhanced: 3.3.0 accept a directed parameter."
-msgstr ""
+msgstr "Enhanced: 3.3.0 directedパラメータを付け付けるようになりました。"
 #. Tag: para
 #: reference_processing.xml:1169
 #, no-c-format
 msgid "Requires GEOS >= 3.11.0 to use the directed parameter."
-msgstr ""
+msgstr "directedパラメータを使うにはGEOS 3.11.0以上が必要です。"
 #. Tag: para
 #: reference_processing.xml:1171
@@ -2496,14 +2570,14 @@ msgstr ""
 #: reference_processing.xml:1266 reference_processing.xml:1906
 #, no-c-format
 msgid "Availability: 3.1.0."
-msgstr ""
+msgstr "Availability: 3.1.0."
 #. Tag: para
 #: reference_processing.xml:1267 reference_processing.xml:1331
 #: reference_processing.xml:1907
 #, no-c-format
 msgid "Requires GEOS >= 3.9.0."
-msgstr ""
+msgstr "GEOS 3.9.0以上が必要です。"
 #. Tag: para
 #: reference_processing.xml:1278
@@ -2634,7 +2708,7 @@ msgstr ""
 #: reference_processing.xml:1330
 #, no-c-format
 msgid "Availability: 3.4.0."
-msgstr ""
+msgstr "Availability: 3.4.0."
 #: reference_processing.xml:1338
@@ -2996,13 +3070,13 @@ msgstr ""
 #: reference_processing.xml:1495
 #, no-c-format
 msgid "Availability: 2.5.0."
-msgstr ""
+msgstr "Availability: 2.5.0."
 #. Tag: para
 #: reference_processing.xml:1498
 #, no-c-format
 msgid "Requires GEOS >= 3.6.0."
-msgstr ""
+msgstr "GEOS 3.6.0以上が必要です。"
 #: reference_processing.xml:1503
@@ -3222,6 +3296,19 @@ msgid ""
 "    5.39339828220179 7.39339828220179,\n"
 "    2.14180701233067 12.2597485145237,1 18,1 195)"
 msgstr ""
+"SELECT ST_AsText(ST_OffsetCurve(ST_GeomFromText(\n"
+"'LINESTRING(164 16,144 16,124 16,104 16,84 16,64 16,\n"
+"    44 16,24 16,20 16,18 16,17 17,\n"
+"    16 18,16 20,16 40,16 60,16 80,16 100,\n"
+"    16 120,16 140,16 160,16 180,16 195)'),\n"
+"    15, 'quad_segs=4 join=round'));\n"
+"出力\n"
+"LINESTRING(164 1,18 1,12.2597485145237 2.1418070123307,\n"
+"    7.39339828220179 5.39339828220179,\n"
+"    5.39339828220179 7.39339828220179,\n"
+"    2.14180701233067 12.2597485145237,1 18,1 195)"
 #. Tag: para
 #: reference_processing.xml:1618
@@ -3245,6 +3332,17 @@ msgid ""
 "LINESTRING(31 195,31 31,164 31)"
 msgstr ""
+"SELECT ST_AsText(ST_OffsetCurve(geom,\n"
+"    -15, 'quad_segs=4 join=round')) As notsocurvy\n"
+"    FROM ST_GeomFromText(\n"
+"    16 120,16 140,16 160,16 180,16 195)') As geom;\n"
+"そんなに曲線でない\n"
+"LINESTRING(31 195,31 31,164 31)"
 #. Tag: para
 #: reference_processing.xml:1631
@@ -3275,6 +3373,20 @@ msgid ""
 "35.3933982822018 35.3933982822018,\n"
 "32.1418070123307 40.2597485145237,31 46,31 195)"
 msgstr ""
+"SELECT ST_AsText(ST_OffsetCurve(ST_OffsetCurve(geom,\n"
+"    -30, 'quad_segs=4 join=round'), -15, 'quad_segs=4 join=round')) As "
+"morecurvy\n"
+"かなり曲線\n"
+"LINESTRING(164 31,46 31,40.2597485145236 32.1418070123307,\n"
+"35.3933982822018 35.3933982822018,\n"
+"32.1418070123307 40.2597485145237,31 46,31 195)"
 #. Tag: para
 #: reference_processing.xml:1641
@@ -3311,6 +3423,26 @@ msgid ""
 "35.3933982822018,\n"
 "32.1418070123307 40.2597485145237,31 46,31 195))"
 msgstr ""
+"SELECT ST_AsText(ST_Collect(\n"
+"    ST_OffsetCurve(geom, 15, 'quad_segs=4 join=round'),\n"
+"    ST_OffsetCurve(ST_OffsetCurve(geom,\n"
+"    -30, 'quad_segs=4 join=round'), -15, 'quad_segs=4 join=round')\n"
+"    )\n"
+") As parallel_curves\n"
+"平行曲線\n"
+"MULTILINESTRING((164 1,18 1,12.2597485145237 2.1418070123307,\n"
+"7.39339828220179 5.39339828220179,5.39339828220179 7.39339828220179,\n"
+"2.14180701233067 12.2597485145237,1 18,1 195),\n"
+"(164 31,46 31,40.2597485145236 32.1418070123307,35.3933982822018 35."
+"3933982822018,\n"
+"32.1418070123307 40.2597485145237,31 46,31 195))"
 #. Tag: para
 #: reference_processing.xml:1653
@@ -3334,6 +3466,17 @@ msgid ""
 "LINESTRING(164 1,18 1,7.39339828220179 5.39339828220179,\n"
 "    5.39339828220179 7.39339828220179,1 18,1 195)"
 msgstr ""
+"        15, 'quad_segs=4 join=bevel'));\n"
+"出力\n"
+"LINESTRING(164 1,18 1,7.39339828220179 5.39339828220179,\n"
+"    5.39339828220179 7.39339828220179,1 18,1 195)"
 #. Tag: para
 #: reference_processing.xml:1664
@@ -3361,6 +3504,20 @@ msgid ""
 "MULTILINESTRING((164 1,11.7867965644036 1,1 11.7867965644036,1 195),\n"
 "    (31 195,31 31,164 31))"
 msgstr ""
+"    ST_OffsetCurve(geom, 15, 'quad_segs=4 join=mitre mitre_limit=2.2'),\n"
+"    ST_OffsetCurve(geom, -15, 'quad_segs=4 join=mitre mitre_limit=2.2')\n"
+"    ) )\n"
+"出力\n"
+"MULTILINESTRING((164 1,11.7867965644036 1,1 11.7867965644036,1 195),\n"
+"    (31 195,31 31,164 31))"
 #. Tag: refname
 #: reference_processing.xml:1684
@@ -3964,6 +4121,21 @@ msgid ""
 "GEOMETRYCOLLECTION(MULTILINESTRING EMPTY,\n"
 "MULTILINESTRING((76 175,90 161),(90 161,101 150),(126 125,126 156.25)))"
 msgstr ""
+"同じ例ですがラインストリングの順序を入れ替えています\n"
+"SELECT ST_AsText(\n"
+"  ST_SharedPaths(\n"
+"   ST_GeomFromText('LINESTRING(76 175,90 161,126 125,126 156.25,151 100)'),\n"
+"   ST_GeomFromText('MULTILINESTRING((26 125,26 200,126 200,126 125,26 125),\n"
+"       (51 150,101 150,76 175,51 150))')\n"
+"    )\n"
+"  ) As wkt\n"
+"\n"
+"                                wkt\n"
+"-------------------------------------------------------------\n"
+"GEOMETRYCOLLECTION(MULTILINESTRING EMPTY,\n"
+"MULTILINESTRING((76 175,90 161),(90 161,101 150),(126 125,126 156.25)))"
 #. Tag: para
 #: reference_processing.xml:1995
@@ -4313,13 +4485,13 @@ msgstr ""
 #: reference_processing.xml:2149 reference_processing.xml:2325
 #, no-c-format
 msgid "Availability: 3.3.0."
-msgstr ""
+msgstr "Availability: 3.3.0."
 #. Tag: para
 #: reference_processing.xml:2150 reference_processing.xml:2326
 #, no-c-format
 msgid "Requires GEOS >= 3.11.0."
-msgstr ""
+msgstr "GEOS 3.11.0以上が必要です。"
 #. Tag: para
 #: reference_processing.xml:2162
@@ -4868,6 +5040,10 @@ msgid ""
 "(36.8181818181818 92.2727272727273,-110 43.3333333333333),(230 "
 "-45.7142857142858,36.8181818181818 92.2727272727273))"
 msgstr ""
+"<lineannotation>ST_AsText 出力</lineannotation>\n"
+"MULTILINESTRING((135.555555555556 270,36.8181818181818 92.2727272727273),("
+"36.8181818181818 92.2727272727273,-110 43.3333333333333),(230 -"
+"45.7142857142858,36.8181818181818 92.2727272727273))"
 #. Tag: para
 #: reference_processing.xml:2429
@@ -4959,6 +5135,18 @@ msgid ""
 "POLYGON((100.5 270,230 270,230 47.5,59.3478260869565 132.826086956522,100.5 "
 "270)))"
 msgstr ""
+"GEOMETRYCOLLECTION(POLYGON((-110 43.3333333333333,-110 270,100.5 "
+"270,59.3478260869565 132.826086956522,36.8181818181818 92.2727272727273,-110 "
+"43.3333333333333)),\n"
+"POLYGON((55 -90,-110 -90,-110 43.3333333333333,36.8181818181818 "
+"92.2727272727273,55 79.2857142857143,55 -90)),\n"
+"POLYGON((230 47.5,230 -20.7142857142857,55 79.2857142857143,36.8181818181818 "
+"92.2727272727273,59.3478260869565 132.826086956522,230 47.5)),POLYGON((230 -"
+"20.7142857142857,230 -90,55 -90,55 79.2857142857143,230 -20.7142857142857)),"
+"\n"
+"POLYGON((100.5 270,230 270,230 47.5,59.3478260869565 132.826086956522,100.5 "
+"270)))"
 #. Tag: para
 #: reference_processing.xml:2509
@@ -4993,6 +5181,16 @@ msgid ""
 "270)))"
 msgstr ""
+"POLYGON((230 47.5,230 -45.7142857142858,36.8181818181818 "
+"45.7142857142858,230 -90,-110 -90,-110 43.3333333333333,36.8181818181818 "
+"92.2727272727273,230 -45.7142857142858)),\n"
+"270)))"
 #. Tag: para
 #: reference_processing.xml:2521
Summary of changes:
 doc/po/ja/administration.xml.po       |   6 +-
 doc/po/ja/reference_coverage.xml.po   |  40 ++++++-
 doc/po/ja/reference_lrs.xml.po        |  45 ++++++-
 doc/po/ja/reference_overlay.xml.po    |  10 +-
 doc/po/ja/reference_processing.xml.po | 218 ++++++++++++++++++++++++++++++++--
 5 files changed, 298 insertions(+), 21 deletions(-)
hooks/post-receive
