[postgis-tickets] [PostGIS] #5442: Database search_path does not what it intends to do
PostGIS trac at osgeo.org
Fri Jul 14 05:05:46 PDT 2023
  Reporter:  JelteF   |      Owner:  pramsey
      Type:  patch    |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.3.4
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:  search_path topology tiger
Comment (by JelteF):
 Before falling back to boot_val (when there's no database specific
 search_path), I actually think we might want to look at `pg_file_settings`
 to see if search_path was set in one of the config files. You can get this
 using:
 select setting from pg_file_settings where name = 'search_path' and
 applied;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5442#comment:1>
