[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1259-g109084be6
Fri Jul 14 15:55:52 PDT 2023
the project "PostGIS".
       via  109084be602f8e045ec3511e01052f81257b9a92 (commit)
      from  3bbaa720c547c96a4fb2f8e4b08f6f18eb00a9cd (commit)
revisions in full, below.
commit 109084be602f8e045ec3511e01052f81257b9a92
Author: Sandro Santilli <strk at kbt.io>
Date:   Sat Jul 15 00:38:12 2023 +0200
    Skip translation of some xml tags
    For now we skip these tags:
      - programlisting
      - screen
      - funcsynopsis
    Closes #5440
diff --git a/doc/Makefile.in b/doc/Makefile.in
index a87f56576..55519f282 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -251,22 +251,21 @@ ifeq ($(XML2POT),)
 $(XML_INPUTS_POT): requirements_not_met_xml2pot
 else
 $(XML_INPUTS_POT): $(srcdir)/po/templates/%.xml.pot: %.xml
+	@$(XML2POT) $< > $@.tmp;
+	@$(abs_srcdir)/po/strip_untranslatable.sh $@.tmp;
 	@if test -f $@; then \
-	  $(XML2POT) $< > $@.tmp; \
     changed=`diff $@.tmp $@ \
 			| grep -v '^[<>] "POT-Creation-Date:' \
 			| grep -v '^[<>] "Report-Msgid-Bugs-To:' \
 			| wc -l`; \
     if expr $${changed} \> 3 >/dev/null; then \
       echo "$@ updated"; \
-      mv $@.tmp $@; \
     else \
       echo "$@ unchanged"; \
       rm -f $@.tmp; \
     fi; \
-  else \
-	  $(XML2POT) $< > $@; \
   fi;
+	@if test -e $@.tmp; then mv $@.tmp $@; fi
 endif
 # Update translation templates
diff --git a/doc/po/strip_untranslatable.sh b/doc/po/strip_untranslatable.sh
new file mode 100755
index 000000000..a79ddf35c
--- /dev/null
+++ b/doc/po/strip_untranslatable.sh
@@ -0,0 +1,13 @@
+#!/bin/sh
+# This would be best done with ITS but it doesn't
+# work very effectively at the moment
+# See https://www.w3.org/TR/xml-i18n-bp/#relating-docbook-plus-its
+# https://trac.osgeo.org/postgis/ticket/5074
+sed -e '/^#\. Tag: programlisting$/,/^$/d' \
+    -e '/^#\. Tag: programlisting$/,/^$/d' \
+    -e '/^#\. Tag: funcsynopsis$/,/^$/d' \
+    -i $1
Summary of changes:
 doc/Makefile.in                |  7 +++----
 doc/po/strip_untranslatable.sh | 13 +++++++++++++
 2 files changed, 16 insertions(+), 4 deletions(-)
 create mode 100755 doc/po/strip_untranslatable.sh
hooks/post-receive
