[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1265-gc82514531
Fri Jul 14 18:07:38 PDT 2023
the project "PostGIS".
       via  c825145319e5e70fdf18e38cd74e382fe7b67f25 (commit)
      from  f2595f1b8d25af3ef61c59076e64728883063ae4 (commit)
revisions in full, below.
commit c825145319e5e70fdf18e38cd74e382fe7b67f25
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Jul 14 21:07:33 2023 -0400
    Updte credits.  Turn back on localized pdf building
diff --git a/NEWS b/NEWS
index 8c042238a..9247d1270 100644
--- a/NEWS
+++ b/NEWS
@@ -48,7 +48,7 @@ Vincent Bre (French Team)
   - #4913, ST_AsSVG support for curve types CircularString, CompoundCurve, MultiCurve,
            and MultiSurface (Regina Obe)
   - #5266, ST_ClosestPoint, ST_ShortestLine support for geography type
-           (MobilityDB, Paul Ramsey)
+           (MobilityDB Esteban Zimanyi, Paul Ramsey)
 * Breaking Changes *
   - #5229, Drop support for Proj < 6.1 and PG 11 (Regina Obe)
diff --git a/ci/debbie/postgis_release_docs.sh b/ci/debbie/postgis_release_docs.sh
index 412ca42e9..2d9a87a46 100644
--- a/ci/debbie/postgis_release_docs.sh
+++ b/ci/debbie/postgis_release_docs.sh
@@ -112,9 +112,9 @@ make epub-install # || : survive failure
 # build german and french pdf
 #make -C ../doc/po/fr local-pdf-install
 #make -C ../doc/po/de local-pdf-install
-# TODO put back after resolve issue with japan build
 # Build and install localized pdf and epub
-#make pdf-install-localized # || : survive failures
+make pdf-install-localized # || : survive failures
 #make epub-install-localized # || : survive failures
 if [[ "$POSTGIS_MICRO_VERSION" == *"dev"* ]]; then
diff --git a/doc/introduction.xml b/doc/introduction.xml
index 628b471ce..8452ca803 100644
--- a/doc/introduction.xml
+++ b/doc/introduction.xml
@@ -245,6 +245,7 @@
 					<member>David Techer</member>
 					<member>Dmitry Vasilyev</member>
 					<member>Eduin Carrillo</member>
+                    <member>Esteban Zimanyi</member>
 					<member>Eugene Antimirov</member>
 					<member>Even Rouault</member>
                     <member>Florian Weimer</member>
@@ -317,9 +318,11 @@
 					<member>Stephen Frost</member>
                     <member>Steven Ottens</member>
 					<member>Talha Rizwan</member>
+                    <member>Teramoto Ikuhiro</member>
 					<member>Tom Glancy</member>
 					<member>Tom van Tilburg</member>
                     <member>Victor Collod</member>
+                    <member>Vincent Bre</member>
 					<member>Vincent Mora</member>
 					<member>Vincent Picavet</member>
 					<member>Volf Tomáš</member>
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index c743fdaa8..cd2533d2f 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -51,7 +51,7 @@
                 <para>ST_Project signature for geometry, and two-point signature (Paul Ramsey)</para>
                 <para><ulink url="https://trac.osgeo.org/postgis/ticket/4913">4913</ulink>, ST_AsSVG support for curve types CircularString, CompoundCurve, MultiCurve,
                         and MultiSurface (Regina Obe)</para>
-                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5266">5266</ulink>, ST_ClosestPoint, ST_ShortestLine support for geography type (MobilityDB, Paul Ramsey)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5266">5266</ulink>, ST_ClosestPoint, ST_ShortestLine support for geography type (MobilityDB Esteban Zimanyi, Paul Ramsey)</para>
             </simplesect>
             <simplesect>
Summary of changes:
 NEWS                              | 2 +-
 ci/debbie/postgis_release_docs.sh | 4 ++--
 doc/introduction.xml              | 3 +++
 doc/release_notes.xml             | 2 +-
 4 files changed, 7 insertions(+), 4 deletions(-)
hooks/post-receive
