[postgis-tickets] [PostGIS] #5446: 3.4.0-beta1 fails to build (unable to parse postgis-out.xml)
PostGIS trac at osgeo.org
Sat Jul 15 00:06:42 PDT 2023
 Reporter:  Bas Couwenberg         |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 3.4.0
Component:  build/upgrade/install  |    Version:  master
 Keywords:                         |
 The Debian package build for 3.4.0-beta1 failed to build:
 warning: failed to load external entity
 "address_standardizer_required.tag"
 table_body_function_support_matrix.xsl.xml:3754: parser error : expected
                                 </inlinemediaob
 table_body_function_support_matrix.xsl.xml:3754: parser error : Opening
 and ending tag mismatch: inlinemediaobject line 3750 and inlinemediaob
                                 </inlinemediaob
 table_body_function_support_matrix.xsl.xml:3754: parser error : Premature
 end of data in tag entry line 3749
                                 </inlinemediaob
 table_body_function_support_matrix.xsl.xml:3754: parser error : chunk is
 not well balanced
                                 </inlinemediaob
 postgis_special.xml:134: parser error : Entity
 'table_body_function_support_matrix' failed to parse
           &table_body_function_support_matrix;
 postgis_special.xml:146: parser error : chunk is not well balanced
 postgis-out.xml:145: parser error : Entity 'postgis_special' failed to
 parse
   &postgis_special;
 make[3]: *** [Makefile:313: tiger_geocoder_comments.sql] Error 6
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5446>
