[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0beta1-13-g8140ae8be
Sat Jul 15 15:29:03 PDT 2023
the project "PostGIS".
       via  8140ae8be1ca9b4c7309e56333d19392899333e9 (commit)
      from  a24263108e1e4cbb2944825e02d9d8221b6ec16d (commit)
revisions in full, below.
commit 8140ae8be1ca9b4c7309e56333d19392899333e9
Author: Sandro Santilli <strk at kbt.io>
Date:   Sun Jul 16 00:28:44 2023 +0200
    Make generator parallel-safe
diff --git a/doc/html/images/Makefile.in b/doc/html/images/Makefile.in
index 7a724d053..871d7fcd9 100644
--- a/doc/html/images/Makefile.in
+++ b/doc/html/images/Makefile.in
@@ -273,7 +273,7 @@ generator: $(OBJS) ../../../liblwgeom/.libs/liblwgeom.a
 clean:
 	rm -f $(OBJS)
 	rm -f generator
+	rm -rf generator-temp-*
 distclean: clean
 	rm -f Makefile
diff --git a/doc/html/images/generator.c b/doc/html/images/generator.c
index c1c71ccb0..73d55a690 100644
--- a/doc/html/images/generator.c
+++ b/doc/html/images/generator.c
@@ -43,9 +43,12 @@
 #include <stdio.h>
 #include <stdlib.h>
 #include <string.h>
+#include <unistd.h> /* for rmdir */
 #include <ctype.h>
 #include <sys/wait.h> /* for WEXITSTATUS */
 #include <stdbool.h>
+#include <sys/types.h>
+#include <dirent.h>
 #include "liblwgeom_internal.h"
 #include "lwgeom_log.h"
@@ -60,7 +63,8 @@ bool optionVerbose = false;
 // Some global styling variables
 const char *imageSize = "200x200";
-int getStyleName(char **styleName, char* line);
+char tempdir_template[] = "generator-temp-XXXXXX";
+char *tmpdir = NULL;
 static void
 checked_system(const char* cmd)
@@ -72,6 +76,33 @@ checked_system(const char* cmd)
+static void
+cleanupTempDir(const char *dir)
+	struct dirent *p;
+	DIR *d = opendir(dir);
+	char *buf;
+	size_t maxlen;
+	if ( NULL == d ) {
+		perror( dir );
+		exit(EXIT_FAILURE); /* or be tolerant ? */
+	maxlen = strlen(dir) + 64;
+	buf = malloc(maxlen);
+	while ( (p=readdir(d)) ) {
+		if ( strcmp(p->d_name, ".") == 0 ) continue;
+		if ( strcmp(p->d_name, ".." ) == 0) continue;
+		snprintf(buf, maxlen-1, "%s/%s", dir, p->d_name);
+		remove(buf);
+	closedir(d);
+	rmdir(dir);
  * Writes the coordinates of a POINTARRAY to a char* where ordinates are
  * separated by a comma and coordinates by a space so that the coordinate
@@ -349,29 +380,18 @@ optimizeImage(char* filename)
 static void
 flattenLayers(char* filename)
-	char *str = malloc( (48 + strlen(filename) + 1) * sizeof(char) );
-	sprintf(str, "convert tmp[0-9].png -background white -flatten %s", filename);
+	char *str = malloc( (48 + strlen(filename) + strlen(tmpdir) + 2) * sizeof(char) );
+	sprintf(str, "convert %s/tmp*.png -background white -flatten %s", tmpdir, filename);
 	LWDEBUGF(4, "%s", str);
 	checked_system(str);
-	// TODO: only remove the tmp files if they exist.
-	remove("tmp0.png");
-	remove("tmp1.png");
-	remove("tmp2.png");
-	remove("tmp3.png");
-	remove("tmp4.png");
-	remove("tmp5.png");
-	remove("tmp6.png");
-	remove("tmp7.png");
-	remove("tmp8.png");
-	remove("tmp9.png");
 	free(str);
 // TODO: comments
-int
-getStyleName(char **styleName, char* line)
+static int
+getStyleName(char **styleName, const char* line)
 	char *ptr = strrchr(line, ';');
 	if (ptr == NULL)
@@ -466,6 +486,12 @@ int main( int argc, const char* argv[] )
 		sprintf(filename + strlen(image_src) - 3, "png" );
+	tmpdir = mkdtemp(tempdir_template);
+	if ( NULL == tmpdir ) {
+		perror ( image_src );
 	printf( "generating %s\n", filename );
 	layerCount = 0;
@@ -499,7 +525,7 @@ int main( int argc, const char* argv[] )
 		ptr += drawGeometry( ptr, lwgeom, style );
-		ptr += sprintf( ptr, "-flip tmp%d.png", layerCount );
+		ptr += sprintf( ptr, "-flip %s/tmp%d.png", tmpdir, layerCount );
 		lwgeom_free( lwgeom );
@@ -519,5 +545,8 @@ int main( int argc, const char* argv[] )
 	fclose(pfile);
 	free(filename);
 	freeStyles(&styles);
+	cleanupTempDir(tmpdir);
 	return 0;
Summary of changes:
 doc/html/images/Makefile.in |  2 +-
 doc/html/images/generator.c | 63 +++++++++++++++++++++++++++++++++------------
 2 files changed, 47 insertions(+), 18 deletions(-)
hooks/post-receive
