[postgis-tickets] [PostGIS] #5448: Test failures on i386
PostGIS trac at osgeo.org
Sat Jul 15 21:13:01 PDT 2023
  Reporter:  Bas Couwenberg         |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Description changed by Bas Couwenberg:
Old description:
> The CI run for the Debian package failed on i386 due to test failures:
>  regress/core/geography .. failed (diff expected obtained:
> /tmp/pgis_reg/test_18_diff)
> --- ./regress/core/geography_expected   2023-07-15 11:11:05.000000000
> +0000
> +++ /tmp/pgis_reg/test_18_out   2023-07-15 11:42:53.723140832 +0000
> @@ -58,7 +58,7 @@
>  lrs_lip_1|POINT(4.35 50.85)
>  lrs_lip_2|POINT(4.35 50.85)
>  lrs_lip_3|POINT(37.62 55.76)
> -lrs_lip_4|MULTIPOINT((7.22 51.72),(10.23 52.53),(13.37 53.26),(16.63
> 53.91),(20 54.46),(23.45 54.93),(26.96 55.29),(30.51 55.55),(34.07
> 55.7),(37.62 55.76))
> +lrs_lip_4|MULTIPOINT((7.22 51.72),(10.23 52.53),(13.37 53.26),(16.63
> 53.91),(20 54.46),(23.45 54.93),(26.96 55.29),(30.51 55.55),(34.07 55.7))
>  lrs_llp_1|0.50
>  lrs_llp_2|0.00
>  lrs_llp_3|1.00
>  regress/core/measures .. failed (diff expected obtained:
> /tmp/pgis_reg/test_34_diff)
> --- ./regress/core/measures_expected    2023-07-15 11:11:05.000000000
> +0000
> +++ /tmp/pgis_reg/test_34_out   2023-07-15 11:42:56.919134867 +0000
> @@ -98,6 +98,6 @@
>  st_lineextend.1|LINESTRING(-0.707 -0.707,0 0,1 1,1.707 1.707)
>  st_lineextend.2|LINESTRING(-0.707 -0.707,0 0,1 1)
>  st_lineextend.3|LINESTRING(0 0,1 1,1.707 1.707)
> -st_lineextend.4|LINESTRING(0 0,1 1,1.707 1.707)
> +st_lineextend.4|LINESTRING(0 0,1 1,1 1,1 1,1.707 1.707)
>  st_lineextend.5|
>  ERROR:  Argument must be LINESTRING geometry
>  topology/test/regress/getnodeedges .. failed (diff expected obtained:
> /tmp/pgis_reg/test_185_diff)
> --- ./topology/test/regress/getnodeedges_expected       2023-07-15
> 11:11:05.000000000 +0000
> +++ /tmp/pgis_reg/test_185_out  2023-07-15 11:43:58.771046299 +0000
> @@ -1,37 +1,37 @@
>  N1|1|1
>  N1|2|-1
> -N2|1|3
> -N2|2|2
> -N2|3|-2
> +N2|1|2
> +N2|2|-2
> +N2|3|3
>  N3|1|-3
>  N5|1|4
> -N6|1|-5
> -N6|2|-4
> +N6|1|-4
> +N6|2|-5
>  N7|1|5
> -N8|1|22
> -N8|2|12
> -N9|1|20
> -N9|2|13
> -N9|3|-12
> -N10|1|18
> -N10|2|14
> -N10|3|-13
> -N11|1|16
> -N11|2|-14
> -N12|1|15
> -N12|2|-16
> -N12|3|-11
> -N13|1|17
> -N13|2|11
> -N13|3|-18
> -N13|4|10
> -N14|1|19
> -N14|2|-10
> -N14|3|-20
> -N14|4|-9
> -N15|1|21
> -N15|2|9
> -N15|3|-22
> +N8|1|12
> +N8|2|22
> +N9|1|13
> +N9|2|-12
> +N9|3|20
> +N10|1|14
> +N10|2|-13
> +N10|3|18
> +N11|1|-14
> +N11|2|16
> +N12|1|-16
> +N12|2|-11
> +N12|3|15
> +N13|1|11
> +N13|2|-18
> +N13|3|10
> +N13|4|17
> +N14|1|-10
> +N14|2|-20
> +N14|3|-9
> +N14|4|19
> +N15|1|9
> +N15|2|-22
> +N15|3|21
>  N16|1|6
>  N16|2|-21
>  N17|1|7
> @@ -42,8 +42,8 @@
>  N18|3|-7
>  N19|1|-15
>  N19|2|-8
> -N20|1|-26
> -N20|2|26
> +N20|1|26
> +N20|2|-26
>  N21|1|25
>  N22|1|-25
>  Topology 'city_data' dropped
>  topology/test/regress/legacy_invalid .. failed (diff expected obtained:
> /tmp/pgis_reg/test_190_diff)
> --- ./topology/test/regress/legacy_invalid_expected     2023-07-15
> +++ /tmp/pgis_reg/test_190_out  2023-07-15 11:44:00.843043387 +0000
> @@ -20,7 +20,7 @@
>  invalid next_left_edge|6|29
>  invalid next_left_edge|18|-27
>  invalid next_left_edge|27|10
> -invalid next_left_edge|29|-33
> +invalid next_left_edge|29|31
>  invalid next_left_edge|30|-3
>  invalid next_left_edge|31|-28
>  invalid next_left_edge|33|33
> @@ -28,7 +28,8 @@
>  invalid next_right_edge|27|-22
>  invalid next_right_edge|28|-30
>  invalid next_right_edge|29|7
> -invalid next_right_edge|33|31
> +invalid next_right_edge|31|-33
> +invalid next_right_edge|33|-31
>  #4936|missing_count|1
>  #4936|missing|face without edges|10|
>  Topology 'invalid_topology' dropped
> make[2]: *** [regress/runtest.mk:24: check-regress] Error 4
> make[2]: Leaving directory '/builds/debian-gis-
> team/postgis/debian/output/source_dir'
> *** /tmp/pg_virtualenv.EruFGH/log/postgresql-15-regress.log (last 100
> lines) ***
> 2023-07-15 11:44:41.895 UTC [27239] salsaci at postgis_reg-3.4 ERROR:  Band
> at index '2' not found for raster '2'
> 2023-07-15 11:44:41.895 UTC [27239] salsaci at postgis_reg-3.4 CONTEXT:
> PL/pgSQL function st_grayscale(rastbandarg[],text) line 41 at RAISE
>         PL/pgSQL function
> st_grayscale(raster,integer,integer,integer,text) line 5 at RETURN
> 2023-07-15 11:44:41.895 UTC [27239] salsaci at postgis_reg-3.4 STATEMENT:
> SELECT
>                 ST_Grayscale(rast)
>         FROM raster_grayscale_in
>         ORDER BY rid
>         LIMIT 1;
> SELECT
>                 ST_Grayscale(
>                         ARRAY[
>                                 ROW(rast, 1)::rastbandarg,
>                                 ROW(rast, 2)::rastbandarg,
>                         ]::rastbandarg[]
>         ORDER BY rid
>         LIMIT 1;
> 2023-07-15 11:44:43.194 UTC [27287] salsaci at postgis_reg-3.4 ERROR:
> Tolerance cannot be less than zero
> 2023-07-15 11:44:43.194 UTC [27287] salsaci at postgis_reg-3.4 STATEMENT:
> SELECT
>                 '2.2',
>                 r1.rid,
>                 r2.rid,
>                 -1 AS distance,
>                 ST_DWithin(r1.rast, NULL, r2.rast, NULL, -1)
>         FROM raster_geos_rast r1
>         CROSS JOIN raster_geos_rast r2
>         WHERE r1.rid = 0;
> 2023-07-15 11:44:43.199 UTC [27287] salsaci at postgis_reg-3.4 ERROR:
> 2023-07-15 11:44:43.199 UTC [27287] salsaci at postgis_reg-3.4 STATEMENT:
> SELECT
>                 '2.4',
>                 r1.rid,
>                 r2.rid,
>                 -1 AS distance,
>                 ST_DFullyWithin(r1.rast, NULL, r2.rast, NULL, -1)
>         WHERE r1.rid = 0;
> ERROR 4: `/vsimem/in.dat' not recognized as a supported file format.
> 2023-07-15 11:44:44.638 UTC [27323] salsaci at postgis_reg-3.4 ERROR:
> RASTER_fromGDALRaster: Could not open bytea with GDAL. Check that the
> bytea is of a GDAL supported format
> 2023-07-15 11:44:44.638 UTC [27323] salsaci at postgis_reg-3.4 STATEMENT:
> SELECT convert_from(ST_AsGDALRaster(ST_FromGDALRaster('<VRTDataset
> rasterXSize="1000"
>         rasterYSize="1"><VRTRasterBand band="1"
> subClass="VRTRawRasterBand"><SourceFilename>/etc/passwd</SourceFilename></VRTRasterBand></VRTDataset>'::bytea),
>         'EHDR')::bytea, 'LATIN1');
> ERROR 4: <VRTDataset rasterXSize="1000" rasterYSize="1"><VRTRasterBand
> band="1"
> subClass="VRTRawRasterBand"><SourceFilename>/etc/passwd</SourceFilename></VRTRasterBand></VRTDataset>:
> No such file or directory
> 2023-07-15 11:44:44.641 UTC [27323] salsaci at postgis_reg-3.4 ERROR:
> rt_band_load_offline_data: Cannot open offline raster: <VRTDataset
> rasterXSize="1000" rasterYSize="1"><VRTRasterBand band="1"
> 2023-07-15 11:44:44.641 UTC [27323] salsaci at postgis_reg-3.4 STATEMENT:
> SELECT count(convert_from(ST_AsGDALRaster(r, 'EHDR')::bytea, 'LATIN1'))
> as passwd from raster_test where lbl = 'passwd';
> band="1"
> 2023-07-15 11:44:44.642 UTC [27323] salsaci at postgis_reg-3.4 ERROR:
> 2023-07-15 11:44:44.642 UTC [27323] salsaci at postgis_reg-3.4 STATEMENT:
> band="1"
> 2023-07-15 11:44:44.650 UTC [27323] salsaci at postgis_reg-3.4 ERROR:
> 2023-07-15 11:44:44.650 UTC [27323] salsaci at postgis_reg-3.4 STATEMENT:
> band="1"
> 2023-07-15 11:44:44.867 UTC [27335] salsaci at postgis_reg-3.4 WARNING:
> Unable to add constraint: 'scale_x'.  Skipping
> 2023-07-15 11:44:44.867 UTC [27335] salsaci at postgis_reg-3.4 CONTEXT:
> PL/pgSQL function addrasterconstraints(name,name,name,text[]) line 113 at
> RAISE
> 2023-07-15 11:44:44.871 UTC [27335] salsaci at postgis_reg-3.4 ERROR:  new
> row for relation "test_raster_scale_regular" violates check constraint
> "enforce_scaley_rast"
> 2023-07-15 11:44:44.871 UTC [27335] salsaci at postgis_reg-3.4 DETAIL:
> Failing row contains (3,
> 01000001006ABC74931804F03FCB1A50CAFFFFEF3F0000000000000000000000...).
> 2023-07-15 11:44:44.871 UTC [27335] salsaci at postgis_reg-3.4 CONTEXT:  SQL
> statement "INSERT INTO test_raster_scale_regular VALUES ('3',
> '01000001006ABC74931804F03FCB1A50CAFFFFEF3F00000000000000000000000000000000000000000000000000000000000000000000000002000200440001010101')"
>         PL/pgSQL function make_test_raster(text,integer,double
> precision,double precision) line 16 at EXECUTE
> 2023-07-15 11:44:44.871 UTC [27335] salsaci at postgis_reg-3.4 STATEMENT:
> SELECT make_test_raster('regular', 3, 1.001, 0.9999999);
> 2023-07-15 11:44:44.875 UTC [27335] salsaci at postgis_reg-3.4 ERROR:  new
> row for relation "test_raster_scale_big" violates check constraint
> "enforce_scalex_rast"
> 2023-07-15 11:44:44.875 UTC [27335] salsaci at postgis_reg-3.4 DETAIL:
> Failing row contains (1,
> 0100000100E1639D31956AE5C3000000000000F03F0000000000000000000000...).
> 2023-07-15 11:44:44.875 UTC [27335] salsaci at postgis_reg-3.4 CONTEXT:  SQL
> statement "INSERT INTO test_raster_scale_big VALUES ('1',
> '0100000100E1639D31956AE5C3000000000000F03F00000000000000000000000000000000000000000000000000000000000000000000000002000200440001010101')"
> 2023-07-15 11:44:44.875 UTC [27335] salsaci at postgis_reg-3.4 STATEMENT:
> SELECT make_test_raster('big', 1, -12345678901234567890.0);
> 2023-07-15 11:44:44.876 UTC [27335] salsaci at postgis_reg-3.4 WARNING:
> 2023-07-15 11:44:44.876 UTC [27335] salsaci at postgis_reg-3.4 CONTEXT:
> RAISE
> 2023-07-15 11:44:44.879 UTC [27335] salsaci at postgis_reg-3.4 ERROR:  new
> row for relation "test_raster_scale_small" violates check constraint
> 2023-07-15 11:44:44.879 UTC [27335] salsaci at postgis_reg-3.4 DETAIL:
> 0100000100F168E388B5F8E43E72C45A7C0A00F03F0000000000000000000000...).
> 2023-07-15 11:44:44.879 UTC [27335] salsaci at postgis_reg-3.4 CONTEXT:  SQL
> statement "INSERT INTO test_raster_scale_small VALUES ('3',
> '0100000100F168E388B5F8E43E72C45A7C0A00F03F00000000000000000000000000000000000000000000000000000000000000000000000002000200440001010101')"
> 2023-07-15 11:44:44.879 UTC [27335] salsaci at postgis_reg-3.4 STATEMENT:
> SELECT make_test_raster('small', 3, 0.00001, 1.00001);
> 2023-07-15 11:44:44.901 UTC [27335] salsaci at postgis_reg-3.4 WARNING:
> Unable to add constraint: 'blocksize_x'.  Skipping
> 2023-07-15 11:44:44.901 UTC [27335] salsaci at postgis_reg-3.4 CONTEXT:
> RAISE
>         PL/pgSQL function
> addrasterconstraints(name,name,name,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean)
> line 53 at RETURN
> Unable to add constraint: 'blocksize_y'.  Skipping
> RAISE
>         PL/pgSQL function
> line 53 at RETURN
> Unable to add constraint: 'pixel_types'.  Skipping
> RAISE
>         PL/pgSQL function
> line 53 at RETURN
> 2023-07-15 11:44:44.902 UTC [27335] salsaci at postgis_reg-3.4 WARNING:
> Unable to add constraint: 'nodata_values'.  Skipping
> 2023-07-15 11:44:44.902 UTC [27335] salsaci at postgis_reg-3.4 CONTEXT:
> RAISE
>         PL/pgSQL function
> line 53 at RETURN
> Unable to add constraint: 'out_db'.  Skipping
> RAISE
>         PL/pgSQL function
> line 53 at RETURN
> Unable to add constraint: 'extent'.  Skipping
> RAISE
>         PL/pgSQL function
> line 53 at RETURN
> 2023-07-15 11:44:50.534 UTC [20328] LOG:  checkpoint starting: immediate
> force wait
> 2023-07-15 11:44:50.536 UTC [20328] LOG:  checkpoint complete: wrote 56
> buffers (0.3%); 0 WAL file(s) added, 0 removed, 11 recycled; write=0.001
> s, sync=0.001 s, total=0.002 s; sync files=0, longest=0.000 s,
> average=0.000 s; distance=178357 kB, estimate=178357 kB
> Dropping cluster 15/regress ...
> make[1]: *** [debian/rules:165: override_dh_auto_test] Error 1
> Full buildlog: https://salsa.debian.org/debian-gis-
> team/postgis/-/jobs/4434289/raw
New description:
 +0000
 @@ -58,7 +58,7 @@
  lrs_llp_1|0.50
  lrs_llp_2|0.00
  lrs_llp_3|1.00
 +0000
 @@ -98,6 +98,6 @@
  st_lineextend.5|
 @@ -1,37 +1,37 @@
  N1|1|1
  N1|2|-1
 -N2|1|3
 -N2|2|2
 -N2|3|-2
 +N2|1|2
 +N2|2|-2
 +N2|3|3
  N3|1|-3
  N5|1|4
 -N6|1|-5
 -N6|2|-4
 +N6|1|-4
 +N6|2|-5
  N7|1|5
 -N8|1|22
 -N8|2|12
 -N9|1|20
 -N9|2|13
 -N9|3|-12
 -N10|1|18
 -N10|2|14
 -N10|3|-13
 -N11|1|16
 -N11|2|-14
 -N12|1|15
 -N12|2|-16
 -N12|3|-11
 -N13|1|17
 -N13|2|11
 -N13|3|-18
 -N13|4|10
 -N14|1|19
 -N14|2|-10
 -N14|3|-20
 -N14|4|-9
 -N15|1|21
 -N15|2|9
 -N15|3|-22
 +N8|1|12
 +N8|2|22
 +N9|1|13
 +N9|2|-12
 +N9|3|20
 +N10|1|14
 +N10|2|-13
 +N10|3|18
 +N11|1|-14
 +N11|2|16
 +N12|1|-16
 +N12|2|-11
 +N12|3|15
 +N13|1|11
 +N13|2|-18
 +N13|3|10
 +N13|4|17
 +N14|1|-10
 +N14|2|-20
 +N14|3|-9
 +N14|4|19
 +N15|1|9
 +N15|2|-22
 +N15|3|21
  N16|1|6
  N16|2|-21
  N17|1|7
 @@ -42,8 +42,8 @@
  N18|3|-7
  N19|1|-15
  N19|2|-8
 -N20|1|-26
 -N20|2|26
 +N20|1|26
 +N20|2|-26
  N21|1|25
  N22|1|-25
 @@ -20,7 +20,7 @@
 @@ -28,7 +28,8 @@
 lines) ***
         PL/pgSQL function
 SELECT
                 ST_Grayscale(rast)
         ORDER BY rid
         LIMIT 1;
 SELECT
                 ST_Grayscale(
                         ARRAY[
                         ]::rastbandarg[]
         ORDER BY rid
         LIMIT 1;
 SELECT
                 '2.2',
                 r1.rid,
                 r2.rid,
                 -1 AS distance,
         WHERE r1.rid = 0;
 SELECT
                 '2.4',
                 r1.rid,
                 r2.rid,
                 -1 AS distance,
         WHERE r1.rid = 0;
 rasterXSize="1000"
 band="1"
 SELECT count(convert_from(ST_AsGDALRaster(r, 'EHDR')::bytea, 'LATIN1')) as
 band="1"
 band="1"
 band="1"
 RAISE
 RAISE
 RAISE
         PL/pgSQL function
 line 53 at RETURN
 RAISE
         PL/pgSQL function
 line 53 at RETURN
 RAISE
         PL/pgSQL function
 line 53 at RETURN
 RAISE
         PL/pgSQL function
 line 53 at RETURN
 RAISE
         PL/pgSQL function
 line 53 at RETURN
 RAISE
         PL/pgSQL function
 line 53 at RETURN
 force wait
 The build on the i386 buildd likewise failed:
 https://buildd.debian.org/status/fetch.php?pkg=postgis&arch=i386&ver=3.4.0%7Ebeta1%2Bdfsg-1%7Eexp3&stamp=1689453565&raw=0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5448#comment:1>
