[postgis-tickets] [PostGIS] #5450: 3.4.0-beta1 fails to build (error: detected recursion whilst expanding macro "pixel")
PostGIS trac at osgeo.org
Sat Jul 15 23:10:56 PDT 2023
macro "pixel")
 Reporter:  Bas Couwenberg  |      Owner:  pramsey
     Type:  defect          |     Status:  new
 Priority:  medium          |  Milestone:  PostGIS 3.3.4
Component:  postgis         |    Version:  3.3.x
 Keywords:                  |
 The Debian package build for 3.4.0-beta1 failed on powerpc architectures:
 make[3]: Entering directory '/<<PKGBUILDDIR>>/raster'
 /usr/bin/make -C rt_core
 /usr/bin/make -C rt_pg rtpostgis.sql
 make[4]: Entering directory '/<<PKGBUILDDIR>>/raster/rt_pg'
 make[4]: Entering directory '/<<PKGBUILDDIR>>/raster/rt_core'
 powerpc64le-linux-gnu-gcc -I../../liblwgeom -I../../liblwgeom -I../..
 -I../../raster -I.  -I/usr/include -I/usr/include/powerpc64le-linux-gnu
 -I/usr/include/libxml2 -I/usr/include -I/usr/include/json-c   -DNDEBUG
 -Wdate-time -D_FORTIFY_SOURCE=2 -std=gnu99 -g -O2 -ffile-prefix-
 map=/<<PKGBUILDDIR>>=. -fstack-protector-strong -Wformat -Werror=format-
 security -fno-math-errno -fno-signed-zeros -Wall -flto  -fPIC -DPIC
 -I/usr/include/gdal -I/usr/include/powerpc64le-linux-gnu  -I/usr/include
 -Wdate-time -D_FORTIFY_SOURCE=2  -c -o rt_util.o rt_util.c
 -Wdate-time -D_FORTIFY_SOURCE=2  -c -o rt_spatial_relationship.o
 rt_spatial_relationship.c
 -Wdate-time -D_FORTIFY_SOURCE=2  -c -o rt_mapalgebra.o rt_mapalgebra.c
 -Wdate-time -D_FORTIFY_SOURCE=2  -c -o rt_geometry.o rt_geometry.c
 -Wdate-time -D_FORTIFY_SOURCE=2  -c -o rt_statistics.o rt_statistics.c
 -Wdate-time -D_FORTIFY_SOURCE=2  -c -o rt_pixel.o rt_pixel.c
 -Wdate-time -D_FORTIFY_SOURCE=2  -c -o rt_warp.o rt_warp.c
 /usr/bin/cpp -traditional-cpp -w -P -I../../postgis/ rtpostgis.sql.in >
 rtpostgis.sql.tmp
 rtpostgis.sql.in:1605: error: detected recursion whilst expanding macro
 "pixel"
  1605 |                                 -- per band pixel type check
 rtpostgis.sql.in:1633: error: detected recursion whilst expanding macro
 "pixel"
  1633 |                                         -- per band pixel type
 check
 rtpostgis.sql.in:3150: error: detected recursion whilst expanding macro
 "pixel"
  3150 |                 -- max distance from center pixel
 rtpostgis.sql.in:3168: error: detected recursion whilst expanding macro
 "pixel"
  3168 |                 -- center pixel's coordinates
 rtpostgis.sql.in:3187: error: detected recursion whilst expanding macro
 "pixel"
  3187 |                         -- second arg is what to do if center
 pixel has a value
 rtpostgis.sql.in:3188: error: detected recursion whilst expanding macro
 "pixel"
  3188 |                         -- this will be a weight to apply for the
 center pixel
 rtpostgis.sql.in:3205: error: detected recursion whilst expanding macro
 "pixel"
  3205 |                 -- center pixel value
 rtpostgis.sql.in:3208: error: detected recursion whilst expanding macro
 "pixel"
  3208 |                 -- check to see if center pixel has value
 rtpostgis.sql.in:3218: error: detected recursion whilst expanding macro
 "pixel"
  3218 |                                 -- skip NODATA values and center
 pixel
 rtpostgis.sql.in:3237: error: detected recursion whilst expanding macro
 "pixel"
  3237 |                         -- center pixel has value
 rtpostgis.sql.in:3256: error: detected recursion whilst expanding macro
 "pixel"
  3256 |                 -- apply weight for center pixel if center pixel
 has value
 "pixel"
 rtpostgis.sql.in:3310: error: detected recursion whilst expanding macro
 "pixel"
  3310 |                 -- max distance from center pixel
 rtpostgis.sql.in:3326: error: detected recursion whilst expanding macro
 "pixel"
  3326 |                 -- center pixel's coordinates
 rtpostgis.sql.in:3330: error: detected recursion whilst expanding macro
 "pixel"
  3330 |                 -- center pixel value
 rtpostgis.sql.in:3333: error: detected recursion whilst expanding macro
 "pixel"
  3333 |                 -- check to see if center pixel has value
 rtpostgis.sql.in:3341: error: detected recursion whilst expanding macro
 "pixel"
  3341 |                                 -- skip NODATA values and center
 pixel
 rtpostgis.sql.in:3430: error: detected recursion whilst expanding macro
 "pixel"
  3430 |                 -- check that center pixel isn't NODATA
 rtpostgis.sql.in:3433: error: detected recursion whilst expanding macro
 "pixel"
  3433 |                 -- substitute center pixel for any neighbor pixels
 that are NODATA
 rtpostgis.sql.in:3599: error: detected recursion whilst expanding macro
 "pixel"
  3599 |                 -- check that center pixel isn't NODATA
 rtpostgis.sql.in:3602: error: detected recursion whilst expanding macro
 "pixel"
  3602 |                 -- substitute center pixel for any neighbor pixels
 that are NODATA
 rtpostgis.sql.in:3781: error: detected recursion whilst expanding macro
 "pixel"
  3781 |                 -- check that pixel is not edge pixel
 "pixel"
 rtpostgis.sql.in:3979: error: detected recursion whilst expanding macro
 "pixel"
  3979 |                 -- check that center pixel isn't NODATA
 rtpostgis.sql.in:3982: error: detected recursion whilst expanding macro
 "pixel"
  3982 |                 -- substitute center pixel for any neighbor pixels
 that are NODATA
 rtpostgis.sql.in:4123: error: detected recursion whilst expanding macro
 "pixel"
  4123 |                 -- check that center pixel isn't NODATA
 rtpostgis.sql.in:4126: error: detected recursion whilst expanding macro
 "pixel"
  4126 |                 -- substitute center pixel for any neighbor pixels
 that are NODATA
 rtpostgis.sql.in:4261: error: detected recursion whilst expanding macro
 "pixel"
  4261 |                 -- check that center pixel isn't NODATA
 rtpostgis.sql.in:4264: error: detected recursion whilst expanding macro
 "pixel"
  4264 |                 -- substitute center pixel for any neighbor pixels
 that are NODATA
 rtpostgis.sql.in:5230: error: detected recursion whilst expanding macro
 "pixel"
  5230 | -- Returns the pixel column and row covering the provided X and Y
 world
 rtpostgis.sql.in:5245: error: detected recursion whilst expanding macro
 "pixel"
  5245 | -- Returns the pixel column and row covering the provided point
 geometry.
 rtpostgis.sql.in:5273: error: detected recursion whilst expanding macro
 "pixel"
  5273 | -- Returns the column number of the pixel covering the provided X
 and Y world
 rtpostgis.sql.in:5297: error: detected recursion whilst expanding macro
 "pixel"
  5297 | -- Returns the column number of the pixel covering the provided
 point geometry.
 rtpostgis.sql.in:5320: error: detected recursion whilst expanding macro
 "pixel"
  5320 | -- Returns the row number of the pixel covering the provided X and
 Y world
 rtpostgis.sql.in:5344: error: detected recursion whilst expanding macro
 "pixel"
  5344 | -- Returns the row number of the pixel covering the provided point
 geometry.
 rtpostgis.sql.in:5379: error: detected recursion whilst expanding macro
 "pixel"
  5379 | -- Returns the longitude and latitude of the upper left corner of
 the pixel
 rtpostgis.sql.in:5380: error: detected recursion whilst expanding macro
 "pixel"
  5380 | -- located at the provided pixel column and row.
 rtpostgis.sql.in:5396: error: detected recursion whilst expanding macro
 "pixel"
  5396 | -- Returns the X world coordinate of the upper left corner of the
 pixel located at
 rtpostgis.sql.in:5408: error: detected recursion whilst expanding macro
 "pixel"
  5408 | -- Returns the X world coordinate of the upper left corner of the
 pixel located at
 rtpostgis.sql.in:5422: error: detected recursion whilst expanding macro
 "pixel"
  5422 | -- Returns the Y world coordinate of the upper left corner of the
 pixel located at
 rtpostgis.sql.in:5434: error: detected recursion whilst expanding macro
 "pixel"
  5434 | -- Returns the Y world coordinate of the upper left corner of the
 pixel located at
 rtpostgis.sql.in:5534: error: detected recursion whilst expanding macro
 "bool"
  5534 |         RETURNS bool
 rtpostgis.sql.in:5556: error: detected recursion whilst expanding macro
 "bool"
  5556 |     RETURNS bool
 rtpostgis.sql.in:5561: error: detected recursion whilst expanding macro
 "bool"
  5561 |     RETURNS bool
 rtpostgis.sql.in:5566: error: detected recursion whilst expanding macro
 "bool"
  5566 |     RETURNS bool
 rtpostgis.sql.in:5571: error: detected recursion whilst expanding macro
 "bool"
  5571 |     RETURNS bool
 rtpostgis.sql.in:5576: error: detected recursion whilst expanding macro
 "bool"
  5576 |     RETURNS bool
 rtpostgis.sql.in:5581: error: detected recursion whilst expanding macro
 "bool"
  5581 |     RETURNS bool
 rtpostgis.sql.in:5586: error: detected recursion whilst expanding macro
 "bool"
  5586 |     RETURNS bool
 rtpostgis.sql.in:5591: error: detected recursion whilst expanding macro
 "bool"
  5591 |     RETURNS bool
 rtpostgis.sql.in:5596: error: detected recursion whilst expanding macro
 "bool"
  5596 |     RETURNS bool
 rtpostgis.sql.in:5601: error: detected recursion whilst expanding macro
 "bool"
  5601 |     RETURNS bool
 rtpostgis.sql.in:5606: error: detected recursion whilst expanding macro
 "bool"
  5606 |     RETURNS bool
 rtpostgis.sql.in:5611: error: detected recursion whilst expanding macro
 "bool"
  5611 |     RETURNS bool
 rtpostgis.sql.in:5619: error: detected recursion whilst expanding macro
 "bool"
  5619 |     RETURNS bool
 rtpostgis.sql.in:5625: error: detected recursion whilst expanding macro
 "bool"
  5625 |     RETURNS bool
 rtpostgis.sql.in:5631: error: detected recursion whilst expanding macro
 "bool"
  5631 |     RETURNS bool
 rtpostgis.sql.in:5639: error: detected recursion whilst expanding macro
 "bool"
  5639 |     RETURNS bool
 rtpostgis.sql.in:5645: error: detected recursion whilst expanding macro
 "bool"
  5645 |     RETURNS bool
 rtpostgis.sql.in:5651: error: detected recursion whilst expanding macro
 "bool"
  5651 |     RETURNS bool
 rtpostgis.sql.in:8627: error: detected recursion whilst expanding macro
 "pixel"
  8627 | -- @param sfx scale factor x (pixel width)
 rtpostgis.sql.in:8628: error: detected recursion whilst expanding macro
 "pixel"
  8628 | -- @param sfy scale factor y (pixel height, usually negative)
 make[4]: *** [Makefile:128: rtpostgis.sql] Error 1
 Full buildlogs:
 [https://buildd.debian.org/status/fetch.php?pkg=postgis&arch=ppc64el&ver=3.4.0%7Ebeta1%2Bdfsg-1%7Eexp4&stamp=1689485687&raw=0
 ppc64el] (64bit, little endian),
 [https://buildd.debian.org/status/fetch.php?pkg=postgis&arch=ppc64&ver=3.4.0%7Ebeta1%2Bdfsg-1%7Eexp3&stamp=1689448496&raw=0
 ppc64] (64bit, big endian),
 [https://buildd.debian.org/status/fetch.php?pkg=postgis&arch=powerpc&ver=3.4.0%7Ebeta1%2Bdfsg-1%7Eexp3&stamp=1689448400&raw=0
 powerpc] (32bit, big endian)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5450>
