[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0beta1-16-gd07f11a3c
Sun Jul 16 13:46:22 PDT 2023
the project "PostGIS".
       via  d07f11a3cab53818d5be3f261a9177bd11a01d25 (commit)
      from  1a525819301c7b715a74cd1549142dede3e34e49 (commit)
revisions in full, below.
commit d07f11a3cab53818d5be3f261a9177bd11a01d25
Author: Sandro Santilli <strk at kbt.io>
Date:   Sun Jul 16 22:45:53 2023 +0200
    Translate one line, cleanup some comments
diff --git a/doc/po/it_IT/xsl-config.xml.po b/doc/po/it_IT/xsl-config.xml.po
index dcfda8462..411950eb9 100644
--- a/doc/po/it_IT/xsl-config.xml.po
+++ b/doc/po/it_IT/xsl-config.xml.po
@@ -1,55 +1,3 @@
-# #-#-#-#-#  tag_address_standardizer_required.xml.po (pg 13)  #-#-#-#-#
-# Italian translations for pg package.
-# Automatically generated, 2023.
-# #-#-#-#-#  tag_curve_support.xml.po (pg 13)  #-#-#-#-#
-# #-#-#-#-#  tag_geography_transform.xml.po (ming 64gcc81)  #-#-#-#-#
-# Italian translations for ming package.
-# #-#-#-#-#  tag_index_aware.xml.po (pg 13)  #-#-#-#-#
-# #-#-#-#-#  tag_M_support.xml.po (pg 13)  #-#-#-#-#
-# #-#-#-#-#  tag_P_support.xml.po (pg 13)  #-#-#-#-#
-# #-#-#-#-#  tag_sfcgal_enhanced.xml.po (pg 13)  #-#-#-#-#
-# #-#-#-#-#  tag_sfcgal_required.xml.po (pg 13)  #-#-#-#-#
-# #-#-#-#-#  tag_sfs_compliant.xml.po (pg 13)  #-#-#-#-#
-# #-#-#-#-#  tag_sqlmm_compliant.xml.po (pg 13)  #-#-#-#-#
-# #-#-#-#-#  tag_T_support.xml.po (pg 13)  #-#-#-#-#
-# #-#-#-#-#  tag_Z_support.xml.po (pg 13)  #-#-#-#-#
-# #-#-#-#-#  xsl-config.xml.po (PACKAGE VERSION)  #-#-#-#-#
-# Italian translations for PACKAGE package.
 #, fuzzy
 msgid ""
 msgstr ""
@@ -57,44 +5,19 @@ msgstr ""
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-07-12 08:31+0000\n"
 "PO-Revision-Date: 2023-06-29 14:24+0000\n"
-"Last-Translator: Automatically generated\n"
+"Last-Translator: Sandro Santilli <strk at kbt.io>\n"
 "Language-Team: none\n"
 "Language: it\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
-"#-#-#-#-#  tag_address_standardizer_required.xml.po (pg 13)  #-#-#-#-#\n"
-"Plural-Forms: nplurals=2; plural=(n != 1);\n"
-"#-#-#-#-#  tag_curve_support.xml.po (pg 13)  #-#-#-#-#\n"
-"#-#-#-#-#  tag_geography_transform.xml.po (ming 64gcc81)  #-#-#-#-#\n"
-"#-#-#-#-#  tag_index_aware.xml.po (pg 13)  #-#-#-#-#\n"
-"#-#-#-#-#  tag_M_support.xml.po (pg 13)  #-#-#-#-#\n"
-"#-#-#-#-#  tag_P_support.xml.po (pg 13)  #-#-#-#-#\n"
-"#-#-#-#-#  tag_sfcgal_enhanced.xml.po (pg 13)  #-#-#-#-#\n"
-"#-#-#-#-#  tag_sfcgal_required.xml.po (pg 13)  #-#-#-#-#\n"
-"#-#-#-#-#  tag_sfs_compliant.xml.po (pg 13)  #-#-#-#-#\n"
-"#-#-#-#-#  tag_sqlmm_compliant.xml.po (pg 13)  #-#-#-#-#\n"
-"#-#-#-#-#  tag_T_support.xml.po (pg 13)  #-#-#-#-#\n"
-"#-#-#-#-#  tag_Z_support.xml.po (pg 13)  #-#-#-#-#\n"
-"#-#-#-#-#  xsl-config.xml.po (PACKAGE VERSION)  #-#-#-#-#\n"
 #. Tag: title
 #: xsl-config.xml:41
 #, no-c-format
 msgid "PostGIS Functions new or enhanced in %"
-msgstr ""
+msgstr "Funzioni PostGIS aggiunto o migliorate nella versione %"
 #. Tag: para
 #: xsl-config.xml:42
Summary of changes:
 doc/po/it_IT/xsl-config.xml.po | 81 ++----------------------------------------
 1 file changed, 2 insertions(+), 79 deletions(-)
hooks/post-receive
