[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0beta1-21-g736b18954
Mon Jul 17 12:26:29 PDT 2023
the project "PostGIS".
       via  736b1895401da196854dccd0aa892e4f33a24190 (commit)
      from  24234cc4f2adb98c9805fd18086d36842fa057ee (commit)
revisions in full, below.
commit 736b1895401da196854dccd0aa892e4f33a24190
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Jul 17 21:25:40 2023 +0200
    Tweak --prefix warning
    Utilities are now installed honouring --prefix, and there's no need
    to print warning when building without postgresql
diff --git a/configure.ac b/configure.ac
index 000cd7d21..785009d67 100644
--- a/configure.ac
+++ b/configure.ac
@@ -599,14 +599,13 @@ dnl ===========================================================================
 dnl Explain our prefix policy if necessary.
-if test "$prefix" != "NONE"; then
+if test "$prefix" != "NONE" -a "x$PG_CONFIG" != "xno"; then
   AC_MSG_RESULT([------------------------------------------------------------------------])
   AC_MSG_RESULT([  WARNING: You have set the --prefix to '$prefix'. But we mostly    ])
   AC_MSG_RESULT([  ignore the --prefix. For your info, using the values determined from ])
   AC_MSG_RESULT([  $PG_CONFIG we will be installing:   ])
   AC_MSG_RESULT([    * postgis shared library in $PGSQL_LIBDIR ])
   AC_MSG_RESULT([    * postgis SQL files in $PGSQL_SHAREDIR/contrib/postgis-$POSTGIS_MAJOR_VERSION.$POSTGIS_MINOR_VERSION ])
-  AC_MSG_RESULT([    * postgis executables in $PGSQL_BINDIR ])
 fi
Summary of changes:
 configure.ac | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
hooks/post-receive
