[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0beta1-34-g494ec2ed3
Wed Jul 19 00:52:46 PDT 2023
the project "PostGIS".
       via  494ec2ed39f5e240224a5d2606de92534aee3a06 (commit)
       via  43fc6c4d65c926b459fda730311855d92fcc58c1 (commit)
       via  fd767d5b7153a4f082a69a62ad5088466d9d0ce1 (commit)
      from  702c21e61aa08b981dae3c2dcbd11493ffc6bad6 (commit)
revisions in full, below.
commit 494ec2ed39f5e240224a5d2606de92534aee3a06
Merge: 702c21e61 43fc6c4d6
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Jul 19 09:51:31 2023 +0200
    Merge remote-tracking branch 'weblate/master'
diff --cc doc/po/ja/reference_measure.xml.po
index 0f78a71bd,74601b191..b3b3787b5
--- a/doc/po/ja/reference_measure.xml.po
+++ b/doc/po/ja/reference_measure.xml.po
@@@ -8,8 -8,8 +8,8 @@@ msgid "
  msgstr ""
  "Project-Id-Version: PostGIS\n"
  "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 -"POT-Creation-Date: 2023-07-15 01:29+0000\n"
 +"POT-Creation-Date: 2023-07-18 20:22+0000\n"
- "PO-Revision-Date: 2023-07-14 02:08+0000\n"
+ "PO-Revision-Date: 2023-07-19 07:46+0000\n"
  "Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
  "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
  "reference_measurexml/ja/>\n"
commit 43fc6c4d65c926b459fda730311855d92fcc58c1
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date:   Wed Jul 19 02:38:28 2023 +0000
    Translated using Weblate (Japanese)
    Currently translated at 100.0% (44 of 44 strings)
    Translation: postgis/release_notes.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/release_notesxml/ja/
diff --git a/doc/po/ja/release_notes.xml.po b/doc/po/ja/release_notes.xml.po
index 345597ee3..c4daab266 100644
--- a/doc/po/ja/release_notes.xml.po
+++ b/doc/po/ja/release_notes.xml.po
@@ -8,7 +8,7 @@ msgstr ""
 "POT-Creation-Date: 2023-07-15 01:07+0000\n"
-"PO-Revision-Date: 2023-06-05 11:08+0000\n"
+"PO-Revision-Date: 2023-07-19 07:46+0000\n"
 "release_notesxml/ja/>\n"
@@ -35,13 +35,13 @@ msgstr "リリースノート"
 #: release_notes.xml:6
 #, no-c-format
 msgid "PostGIS 3.4.0beta1"
-msgstr ""
+msgstr "PostGIS 3.4.0beta1"
 #. Tag: para
 #: release_notes.xml:7
 #, no-c-format
 msgid "2023/07/14"
-msgstr ""
+msgstr "2023/07/14"
 #. Tag: para
 #: release_notes.xml:8
@@ -51,6 +51,9 @@ msgid ""
 "6.1+. To take advantage of all features, GEOS 3.12+ is needed. To take "
 "advantage of all SFCGAL featurs, SFCGAL 1.4.1+ is needed."
 msgstr ""
+"このバージョンにはPostgreSQL 12以上、GEOS 3.6以上、Proj 6.1以上が必要です。"
+"全ての機能を利用するにはGEOS 3.12以上が必要です。"
+"全てのSFCGAL機能を使用するにはSFCGAL 1.4.1以上が必要です。"
 #. Tag: para
 #: release_notes.xml:11
@@ -59,24 +62,26 @@ msgid ""
 "NOTE: GEOS 3.12.0 details at <ulink url=\"https://libgeos.org/"
 "posts/2023-06-27-geos-3-12-released/\">GEOS 3.12.0 release notes</ulink>"
 msgstr ""
+"注: GEOS 3.12.0の詳細は<ulink url=\"https://libgeos.org/posts/"
+"2023-06-27-geos-3-12-released/\">GEOS 3.12.0 release notes</ulink>にあります"
 #. Tag: para
 #: release_notes.xml:12
 #, no-c-format
 msgid "Many thanks to our translation teams, in particular:"
-msgstr ""
+msgstr "翻訳チームに感謝します、特に次の方々です:"
 #. Tag: para
 #: release_notes.xml:13
 #, no-c-format
 msgid "Teramoto Ikuhiro (Japanese Team)"
-msgstr ""
+msgstr "Teramoto Ikuhiroさん (日本語チーム)"
 #. Tag: para
 #: release_notes.xml:14
 #, no-c-format
 msgid "Vincent Bre (French Team)"
-msgstr ""
+msgstr "Vincent Breさん (フランス語チーム)"
 #. Tag: title
 #: release_notes.xml:17
@@ -91,6 +96,8 @@ msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/5055\">5055</ulink>, "
 "complete manual internationalization (Sandro Santilli)"
 msgstr ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5055\">5055</ulink>, "
+"完全なマニュアル国際化 (Sandro Santilliさん)"
 #. Tag: para
 #: release_notes.xml:19
@@ -99,6 +106,8 @@ msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/5052\">5052</ulink>, "
 "target version support in postgis_extensions_upgrade (Sandro Santilli)"
 msgstr ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5052\">5052</ulink>, "
+"postgis_extensions_upgradeでの対象バージョンへの対応 (Sandro Santilliさん)"
 #. Tag: para
 #: release_notes.xml:21
@@ -107,13 +116,16 @@ msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/5306\">5306</ulink>, "
 "expose version of GEOS at compile time (Sandro Santilli)"
 msgstr ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5306\">5306</ulink>, "
+"コンパイル時のGEOSバージョンの表示 (Sandro Santilliさん)"
 #. Tag: para
 #: release_notes.xml:22
 #, no-c-format
 msgid ""
 "New install-extension-upgrades command in postgis script (Sandro Santilli)"
-msgstr ""
+msgstr "PostGISスクリプトの新しいinstall-extension-upgradesコマンド (Sandro "
+"Santilliさん)"
 #. Tag: para
 #: release_notes.xml:23
@@ -124,6 +136,10 @@ msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/5277\">5277</ulink>, "
 "Support changes for PostgreSQL 16 (Regina Obe)"
 msgstr ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5257\">5257</ulink>, "
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5261\">5261</ulink>, "
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5277\">5277</ulink>, "
+"PostgreSQL 16への対応のための変更 (Regina Obeさん)"
 #. Tag: para
 #: release_notes.xml:24
@@ -133,6 +149,9 @@ msgid ""
 "<ulink url=\"https://github.com/postgis/postgis/pull/705\">705</ulink>, "
 "ST_Transform: Support PROJ pipelines (Robert Coup, Koordinates)"
 msgstr ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5006\">5006</ulink>, "
+"<ulink url=\"https://github.com/postgis/postgis/pull/705\">705</ulink>, "
+"ST_Transform: PROJパイプライン対応 (Robert Coupさん, Koordinates)"
 #. Tag: para
 #: release_notes.xml:25
@@ -141,6 +160,8 @@ msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/5283\">5283</ulink>, "
 "[postgis_topology] RenameTopology (Sandro Santilli)"
 msgstr ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5283\">5283</ulink>, "
+"[postgis_topology] RenameTopology (Sandro Santilliさん)"
 #. Tag: para
 #: release_notes.xml:26
@@ -149,6 +170,8 @@ msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/5286\">5286</ulink>, "
 "[postgis_topology] RenameTopoGeometryColumn (Sandro Santilli)"
 msgstr ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5286\">5286</ulink>, "
+"[postgis_topology] RenameTopoGeometryColumn (Sandro Santilliさん)"
 #. Tag: para
 #: release_notes.xml:27
@@ -157,6 +180,9 @@ msgid ""
 "<ulink url=\"https://github.com/postgis/postgis/pull/703\">703</ulink>, "
 "[postgis_raster] Add min/max resampling as options (Christian Schroeder)"
 msgstr ""
+"<ulink url=\"https://github.com/postgis/postgis/pull/703\">703</ulink>, "
+"[postgis_raster] リサンプリングの選択肢にmin/maxを追加 (Christian "
+"Schroederさん)"
 #. Tag: para
 #: release_notes.xml:28
@@ -165,6 +191,9 @@ msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/5336\">5336</ulink>, "
 "[postgis_topology] topogeometry cast to topoelement support (Regina Obe)"
 msgstr ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5336\">5336</ulink>, "
+"[postgis_topology] topogeometryからtopoelementへのキャストの対応 (Regina "
+"Obeさん)"
 #. Tag: para
 #: release_notes.xml:29
@@ -172,7 +201,8 @@ msgstr ""
 msgid ""
 "Allow singleton geometry to be inserted into Geometry(Multi*) columns (Paul "
 "Ramsey)"
-msgstr ""
+msgstr "単一ジオメトリをジオメトリ (マルチ系)カラムに挿入できるようにしました (Paul "
+"Ramseyさん)"
 #. Tag: para
 #: release_notes.xml:30
@@ -181,6 +211,9 @@ msgid ""
 "<ulink url=\"https://github.com/postgis/postgis/pull/721\">721</ulink>, New "
 "window-based ST_ClusterWithinWin and ST_ClusterIntersectingWin (Paul Ramsey)"
 msgstr ""
+"<ulink url=\"https://github.com/postgis/postgis/pull/721\">721</ulink>, "
+"新ウィンドウ関数ST_ClusterWithinWinとST_ClusterIntersectingWin (Paul "
+"Ramseyさん)"
 #. Tag: para
 #: release_notes.xml:31
@@ -189,6 +222,8 @@ msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/5397\">5397</ulink>, "
 "[address_standardizer] debug_standardize_address function (Regina Obe)"
 msgstr ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5397\">5397</ulink>, "
+"[address_standardizer] debug_standardize_address関数 (Regina Obeさん)"
 #. Tag: para
 #: release_notes.xml:32
@@ -198,6 +233,9 @@ msgid ""
 "ulink>ST_LargestEmptyCircle, exposes extra semantics on circle finding. Geos "
 "3.9+ required(Martin Davis)"
 msgstr ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5373\">5373</"
+"ulink>ST_LargestEmptyCircle, 円探索に関する追加的な意味の表示。GEOS "
+"3.9以上が必要です (Martin Davisさん)"
 #. Tag: para
 #: release_notes.xml:33
@@ -206,6 +244,9 @@ msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/5267\">5267</ulink>, "
 "ST_Project signature for geometry, and two-point signature (Paul Ramsey)"
 msgstr ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5267\">5267</ulink>, "
+"ST_Projectのジオメトリを引数に取る形式と2ポイントを引数に取る形式 (Paul "
+"Ramseyさん)"
 #. Tag: para
 #: release_notes.xml:34
@@ -214,6 +255,8 @@ msgid ""
 "ST_LineExtend for extending linestrings (Paul Ramsey)"
 msgstr ""
+"ラインストリングを拡張するST_LineExtend (Paul Ramseyさん)"
 #. Tag: title
 #: release_notes.xml:38
@@ -228,6 +271,9 @@ msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/5194\">5194</ulink>, do "
 "not update system catalogs from postgis_extensions_upgrade (Sandro Santilli)"
 msgstr ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5194\">5194</ulink>, "
+"postgis_extensions_upgradeからシステムカタログの更新ができない (Sandro "
+"Santilliさん)"
 #. Tag: para
 #: release_notes.xml:40
@@ -236,6 +282,9 @@ msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/5092\">5092</ulink>, "
 "reduce number of upgrade paths installed on system (Sandro Santilli)"
 msgstr ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5092\">5092</ulink>, "
+"システムにインストールされているアップグレードの経路の数を減らしました ("
+"Sandro Santilliさん)"
 #. Tag: para
 #: release_notes.xml:41
@@ -244,6 +293,9 @@ msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/635\">635</ulink>, honour "
 "--bindir (and --prefix) configure switch for executables (Sandro Santilli)"
 msgstr ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/635\">635</ulink>, "
+"実行可能ファイルのコンフィギュレーションスイッチ --bindir (と --prefix) "
+"を見るようになりました (Sandro Santilliさん)"
 #. Tag: para
 #: release_notes.xml:42
@@ -252,6 +304,8 @@ msgid ""
 "Honour --mandir (and --prefix) configure switch for man pages install path "
 "(Sandro Santilli)"
 msgstr ""
+"マニュアルページのインストールパスのコンフィギュレーションスイッチ --mandir ("
+"と --prefix)を未了になりました (Sandro Santilliさん)"
 #. Tag: para
 #: release_notes.xml:43
@@ -260,6 +314,8 @@ msgid ""
 "Honour --htmldir (and --docdir and --prefix) configure switch for html pages "
 "install path (Sandro Santilli)"
 msgstr ""
+"HTMLページのインストールパスのコンフィギュレーションスイッチ --htmldir (と --"
+"docdir と --prefix)を見るようになりました (Sandro Santilliさん)"
 #. Tag: para
 #: release_notes.xml:45
@@ -267,7 +323,8 @@ msgstr ""
 msgid ""
 "[postgis_topology] Speed up check of topology faces without edges (Sandro "
 "Santilli)"
-msgstr ""
+msgstr "[postgis_topology] エッジのないトポロジのフェイスの確認の速度向上 (Sandro "
+"Santilliさん)"
 #. Tag: para
 #: release_notes.xml:46
@@ -275,7 +332,8 @@ msgstr ""
 msgid ""
 "[postgis_topology] Speed up coincident nodes check in topology validation "
 "(Sandro Santilli)"
-msgstr ""
+msgstr "[postgis_topology] トポロジ評価での一致するノードの確認の高速化 (Sandro "
+"Santilliさん)"
 #. Tag: para
 #: release_notes.xml:47
@@ -284,6 +342,8 @@ msgid ""
 "<ulink url=\"https://github.com/postgis/postgis/pull/718\">718</ulink>, "
 "ST_QuantizeCoordinates(): speed-up implementation (Even Rouault)"
 msgstr ""
+"<ulink url=\"https://github.com/postgis/postgis/pull/718\">718</ulink>, "
+"ST_QuantizeCoordinates(): 実装の速度向上 (Even Rouaultさん)"
 #. Tag: para
 #: release_notes.xml:48
@@ -292,6 +352,8 @@ msgid ""
 "Repair spatial planner stats to use computed selectivity for contains/within "
 "queries (Paul Ramsey)"
 msgstr ""
+"空間プランナの統計情報を修復してcontains/"
+"withinクエリで計算から得られた選択を使用するようにしました (Paul Ramseyさん)"
 #. Tag: para
 #: release_notes.xml:49
@@ -301,6 +363,9 @@ msgid ""
 "Additional metadata on Proj installation in postgis_proj_version (Paul "
 "Ramsey)"
 msgstr ""
+"<ulink url=\"https://github.com/postgis/postgis/pull/734\">734</ulink>, "
+"postgis_proj_versionでProjインストールに関するメタデータの追加 (Paul "
+"Ramseyさん)"
 #. Tag: para
 #: release_notes.xml:50
@@ -309,13 +374,17 @@ msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/5177\">5177</ulink>, "
 "allow building tools without PostgreSQL server headers (Sandro Santilli)"
 msgstr ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5177\">5177</ulink>, "
+"PostgreSQLサーバヘッダなしでツール構築が可能になりました (Sandro "
+"Santilliさん)"
 #. Tag: para
 #: release_notes.xml:51
 #, no-c-format
 msgid ""
-msgstr ""
+msgstr "ST_Projectのジオメトリを引数に取る形式と2ポイントを引数に取る形式 (Paul "
+"Ramseyさん)"
 #. Tag: para
 #: release_notes.xml:52
@@ -325,6 +394,9 @@ msgid ""
 "ST_AsSVG support for curve types CircularString, CompoundCurve, MultiCurve, "
 "and MultiSurface (Regina Obe)"
 msgstr ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/4913\">4913</ulink>, "
+"ST_AsSVGがCircularString, CompoundCurve, Multicurve, "
+"MultiSurface曲線タイプに対応するようになりました (Regina Obeさん)"
 #. Tag: para
 #: release_notes.xml:54
@@ -334,6 +406,9 @@ msgid ""
 "ST_ClosestPoint, ST_ShortestLine support for geography type (MobilityDB "
 "Esteban Zimanyi, Paul Ramsey)"
 msgstr ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5266\">5266</ulink>, "
+"ST_ClosestPoint, ST_ShortestLineがジオグラフィ対応になりました (MobilityDB "
+"Esteban Zimanyiさん, Paul Ramseyさん)"
 #. Tag: title
 #: release_notes.xml:58
@@ -348,6 +423,8 @@ msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/5229\">5229</ulink>, Drop "
 "support for Proj < 6.1 and PG 11 (Regina Obe)"
 msgstr ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5229\">5229</ulink>, Proj "
+"6.1未満およびPostgreSQL 11へのサポートの終了 (Regina Obeさん)"
 #. Tag: para
 #: release_notes.xml:60
@@ -360,6 +437,12 @@ msgid ""
 "time version also shown if different from run-time (Paul Ramsey, Sandro "
 "Santilli)"
 msgstr ""
+"<ulink url=\"https://github.com/postgis/postgis/pull/734\">734</ulink>, postg"
+"is_full_version()とpostgis_proj_version()は、現在はprojネットワーク設定とデー"
+"タパスに関するより多くの情報を出力します。GEOSのバージョンも、"
+"コンパイル時と実行時とで異なる場合に表示されます (Paul Ramseyさん, Sandro "
+"Santilliさん)"
 #, no-c-format
 #~ msgid "PostGIS 3.3.0"
commit fd767d5b7153a4f082a69a62ad5088466d9d0ce1
Date:   Wed Jul 19 07:46:20 2023 +0000
    Currently translated at 100.0% (220 of 220 strings)
    Translation: postgis/reference_measure.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_measurexml/ja/
diff --git a/doc/po/ja/reference_measure.xml.po b/doc/po/ja/reference_measure.xml.po
index b10a39090..74601b191 100644
@@ -9,7 +9,7 @@ msgstr ""
-"PO-Revision-Date: 2023-07-14 02:08+0000\n"
@@ -486,7 +486,7 @@ msgstr ""
 #: reference_measure.xml:259
 #, no-c-format
 msgid "Enhanced: 3.4.0 - Support for geography."
-msgstr ""
+msgstr "Enhanced: 3.4.0 - ジオグラフィに対応しました。"
 #. Tag: para
 #: reference_measure.xml:260 reference_measure.xml:729
@@ -2170,7 +2170,7 @@ msgstr ""
 #: reference_measure.xml:1494
 #, no-c-format
 msgid "Enhanced: 3.4.0 - support for geography."
-msgstr ""
 #. Tag: para
 #: reference_measure.xml:1505
Summary of changes:
 doc/po/ja/reference_measure.xml.po |   6 +--
 doc/po/ja/release_notes.xml.po     | 105 +++++++++++++++++++++++++++++++++----
 2 files changed, 97 insertions(+), 14 deletions(-)
hooks/post-receive
