[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0beta1-41-ga7c7770d8
Thu Jul 20 00:54:13 PDT 2023
the project "PostGIS".
       via  a7c7770d8c25a2f5194ea0b4a37a9bf9bb1a9ddd (commit)
       via  dc3b6d15396404abdfc61891c68f5eec0105ec0b (commit)
      from  421695b78663211fb7a9f134589a0f9a69c1077f (commit)
revisions in full, below.
commit a7c7770d8c25a2f5194ea0b4a37a9bf9bb1a9ddd
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jul 20 08:53:12 2023 +0200
    [winnie] disable path conversion for all scripts
    References #5436
    At least one winnie job seems to be using build_postgis.sh
    instead of regress_postgis.sh, I'm not sure this is intentional, but
    this commit should make that one work.
    https://winnie.postgis.net/job/PostGIS_2_windows_PGVERSION_winnie/14540/consoleFull
    This commit adds a shared file to be sourced by all scripts.
    As a bonus, adds `set -e` to the `package_postgis.sh`, making it stop
    on first failure.
diff --git a/ci/winnie/build_postgis.sh b/ci/winnie/build_postgis.sh
index 94c78010b..3ec9e8411 100644
--- a/ci/winnie/build_postgis.sh
+++ b/ci/winnie/build_postgis.sh
@@ -1,4 +1,7 @@
 #!/usr/bin/env bash
+. $(dirname $0)/winnie_common.h
 set -e
 if  [[ "${OVERRIDE}" == '' ]] ; then
 	export GEOS_VER=3.10.2
diff --git a/ci/winnie/package_postgis.sh b/ci/winnie/package_postgis.sh
index 837c724a8..5b6faf08a 100644
--- a/ci/winnie/package_postgis.sh
+++ b/ci/winnie/package_postgis.sh
@@ -3,6 +3,9 @@
 ## PostgreSQL, OS_BUILD denote the last build to be packaged
 ## and are passed in by the jenkins job process
 #export OS_BUILD=64
 #export PGPORT=8442
@@ -27,6 +30,7 @@ if  [[ "${OVERRIDE}" == '' ]] ; then
 	export CURL_VER=7.73
 fi;
 export PROTOBUF_VER=3.2.0
 export PROTOBUFC_VER=1.2.1
 export JSON_VER=0.12
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index 82122e5e8..99199f441 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -1,4 +1,7 @@
 #!/usr/bin/env bash
 set -e
 	export GEOS_VER=3.11.0
@@ -19,10 +22,6 @@ export PROTOBUFC_VER=1.2.1
 export PCRE_VER=8.33
-# Don't convert paths
-# See https://trac.osgeo.org/postgis/ticket/5436#comment:5
-export MSYS2_ARG_CONV_EXCL=/config/tags
 if  [[ "${ICON_VER}" == '' ]] ; then
   export ICON_VER=1.16
diff --git a/ci/winnie/winnie_common.sh b/ci/winnie/winnie_common.sh
new file mode 100644
index 000000000..7c9dde5a2
--- /dev/null
+++ b/ci/winnie/winnie_common.sh
@@ -0,0 +1,10 @@
+# Common code for all winnie scripts
+# TODO: add more shared code, I guess
+set -e
+# Don't convert paths
+# See https://trac.osgeo.org/postgis/ticket/5436#comment:5
+export MSYS2_ARG_CONV_EXCL=/config/tags
commit dc3b6d15396404abdfc61891c68f5eec0105ec0b
Date:   Thu Jul 20 09:49:52 2023 +0200
    Improve robustness of install-upgrade-paths Makefile target
     - Do not hide errors on install
     - Improve comment
     - Ensure target dir exists before installing to it
    References #5444
diff --git a/extensions/upgrade-paths-rules.mk b/extensions/upgrade-paths-rules.mk
index e543db61c..c87a4e6c2 100644
--- a/extensions/upgrade-paths-rules.mk
+++ b/extensions/upgrade-paths-rules.mk
@@ -6,23 +6,24 @@ PG_SHAREDIR=$(shell $(PG_CONFIG) --sharedir)
 install: install-upgrade-paths
-# The "next" lines are a cludge to allow upgrading between different
-# revisions of the same version
-# TODO: drop the "next" lines, give users instruction to use:
+# Install <extension>--<curversion>--ANY.sql
+#     and <extension>--ANY--<curversion>.sql
+# upgrade paths
-#   SELECT postgis_extensions_upgrade();
+# The <curversion>--ANY file will be a symlink ( or copy,
+# on systems not supporting symlinks ) to an empty upgrade template
+# file named <extension>--TEMPLATED--TO--ANY.sql and be overwritten
+# by any future versions of PostGIS, keeping the overall number of
+# upgrade paths down.
-# Or:
+# See https://trac.osgeo.org/postgis/ticket/5092
-#   ALTER EXTENSION postgis UPDATE TO 'ANY';
-#   ALTER EXTENSION postgis UPDATE;
-install-upgrade-paths: tag-as-any
-	tpl='$(EXTENSION)--ANY--$(EXTVERSION).sql'; \
-	$(INSTALL_DATA) sql/$${tpl} "$(EXTDIR)/$${tpl}"; \
-	$(INSTALL_DATA) "sql/$(TAG_UPGRADE)" "$(EXTDIR)/$(TAG_UPGRADE)"; \
-	ln -fs "$(TAG_UPGRADE)" $(EXTDIR)/$(EXTENSION)--$(EXTVERSION)--ANY.sql;
+install-upgrade-paths: sql/$(TAG_UPGRADE) sql/$(EXTENSION)--ANY--$(EXTVERSION).sql
+	mkdir -p "$(EXTDIR)"
+	$(INSTALL_DATA) "sql/$(EXTENSION)--ANY--$(EXTVERSION).sql" "$(EXTDIR)/$(EXTENSION)--ANY--$(EXTVERSION).sql"
+	$(INSTALL_DATA) "sql/$(TAG_UPGRADE)" "$(EXTDIR)/$(TAG_UPGRADE)"
+	ln -fs "$(TAG_UPGRADE)" "$(EXTDIR)/$(EXTENSION)--$(EXTVERSION)--ANY.sql"
 install-extension-upgrades-from-known-versions:
 	$(PERL) $(top_srcdir)/loader/postgis.pl \
@@ -33,8 +34,6 @@ install-extension-upgrades-from-known-versions:
 all: sql/$(TAG_UPGRADE)
-tag-as-any: sql/$(TAG_UPGRADE)
 sql/$(TAG_UPGRADE): $(MAKEFILE_LIST) | sql
 	echo '-- Just tag extension $(EXTENSION) version as "ANY"' > $@
 	echo '-- Installed by $(EXTENSION) $(EXTVERSION)' >> $@
Summary of changes:
 ci/winnie/build_postgis.sh        |  3 +++
 ci/winnie/package_postgis.sh      |  4 ++++
 ci/winnie/regress_postgis.sh      |  7 +++----
 ci/winnie/winnie_common.sh        | 10 ++++++++++
 extensions/upgrade-paths-rules.mk | 29 ++++++++++++++---------------
 5 files changed, 34 insertions(+), 19 deletions(-)
 create mode 100644 ci/winnie/winnie_common.sh
hooks/post-receive
