[postgis-tickets] [PostGIS] #5444: 3.4.0-beta1 fails to build (postgis--TEMPLATED--TO--ANY.sql is missing)
PostGIS trac at osgeo.org
Fri Jul 21 04:53:18 PDT 2023
  Reporter:  Bas Couwenberg         |      Owner:  strk
      Type:  defect                 |     Status:  reopened
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by Bas Couwenberg):
 Replying to [comment:14 strk]:
 > exp7 seems all green:
 https://buildd.debian.org/status/logs.php?pkg=postgis&ver=3.4.0~beta1%2Bdfsg-1~exp7
 can we close this ticket now ?
 This URL is better:
  https://buildd.debian.org/status/package.php?p=postgis&suite=experimental
 It shows that the amd64, i386, mips64el, and mipsel builds are still
 pending.
 Since this is a hard to reproduce flaky issue, any successful builds are
 no guarantee. You can close this issue if you think it's definitely fixed
 now, I can reopen it again when failing builds prove otherwise.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5444#comment:15>
