[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0beta1-67-g57c738f80
Tue Jul 25 13:12:36 PDT 2023
the project "PostGIS".
       via  57c738f80fe332520d23869daad1183408ba7dbe (commit)
      from  718917d953ce6dce61ed8c4220bc5537d4feaff6 (commit)
revisions in full, below.
commit 57c738f80fe332520d23869daad1183408ba7dbe
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Jul 25 10:58:47 2023 +0200
    Rename postgis_restore.pl to postgis_restore
    References #5447
diff --git a/.gitignore b/.gitignore
index 4d852102f..98ffda812 100644
--- a/.gitignore
+++ b/.gitignore
@@ -194,7 +194,7 @@ topology/uninstall_topology.sql
 libpgcommon/Makefile
 libpgcommon/cunit/Makefile
 utils/Makefile
-utils/postgis_restore.pl
+utils/postgis_restore
 utils/postgis_restore_data.*
 doc/sfcgal_comments.sql
 postgis/sfcgal.sql
diff --git a/NEWS b/NEWS
index 01a9d252b..a09d4002b 100644
--- a/NEWS
+++ b/NEWS
@@ -15,6 +15,14 @@ Changes since 3.4.0beta1 release
          and also put in new version requirements
          (Jelte Fennema, Regina Obe)
+* Enhancements *
+  #5447, man pages for postgis_restore and postgis scripts
+* Breaking Changes *
+  #5447, postgis_restore.pl renamed to postgis_restore
 PostGIS 3.4.0beta1
 2023/07/14
diff --git a/doc/administration.xml b/doc/administration.xml
index 3eb2eb1a0..a839b9beb 100644
--- a/doc/administration.xml
+++ b/doc/administration.xml
@@ -272,7 +272,7 @@ ALTER EXTENSION postgis_topology UPDATE TO "&last_release_version;next";</progra
 	  </para>
 	  <para>
-		The dump/reload process is assisted by the postgis_restore.pl
+		The dump/reload process is assisted by the postgis_restore
 		script which takes care of skipping from the dump all
 		definitions which belong to PostGIS (including old ones),
 		allowing you to restore your schemas and data into a
@@ -341,12 +341,12 @@ ALTER EXTENSION postgis_topology UPDATE TO "&last_release_version;next";</progra
 	  <para>
 		Restore your backup into your fresh
 		<varname>newdb</varname> database using
-		postgis_restore.pl.
+		postgis_restore.
 		Unexpected errors, if any, will be printed to the standard
 		error stream by psql. Keep a log of those.
 	  </para>
-	  <programlisting>perl utils/postgis_restore.pl "/somepath/olddb.backup" | psql -h localhost -p 5432 -U postgres newdb 2> errors.txt</programlisting>
+	  <programlisting>postgis_restore "/somepath/olddb.backup" | psql -h localhost -p 5432 -U postgres newdb 2> errors.txt</programlisting>
 	</listitem>
@@ -412,10 +412,10 @@ ALTER TABLE spatial_ref_sys ADD PRIMARY KEY(srid));
     <para>
 		In this case, you can try following steps : first throw
 		out completely the IGN from the sql which is resulting
-		from postgis_restore.pl. So, after having run :
+		from postgis_restore. So, after having run :
     </para>
-		<programlisting>perl utils/postgis_restore.pl "/somepath/olddb.backup" > olddb.sql</programlisting>
+		<programlisting>postgis_restore "/somepath/olddb.backup" > olddb.sql</programlisting>
     <para>
 		run this command :
diff --git a/liblwgeom/lwutil.c b/liblwgeom/lwutil.c
index 5f63acfa8..affeac731 100644
--- a/liblwgeom/lwutil.c
+++ b/liblwgeom/lwutil.c
@@ -342,7 +342,7 @@ clamp_srid(int32_t srid)
 	} else if ( srid > SRID_MAXIMUM ) {
     newsrid = SRID_USER_MAXIMUM + 1 +
       /* -1 is to reduce likelyhood of clashes */
-      /* NOTE: must match implementation in postgis_restore.pl */
+      /* NOTE: must match implementation in postgis_restore */
       ( srid % ( SRID_MAXIMUM - SRID_USER_MAXIMUM - 1 ) );
 		lwnotice("SRID value %d > SRID_MAXIMUM converted to %d", srid, newsrid);
diff --git a/regress/run_test.pl b/regress/run_test.pl
index cb391df4c..8a118af0f 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -179,7 +179,7 @@ sub raster2pgsql
 our $POSTGIS_RESTORE;
 sub postgis_restore
-    $POSTGIS_RESTORE = findOrDie 'postgis_restore.pl', @_ unless defined($POSTGIS_RESTORE);
+    $POSTGIS_RESTORE = findOrDie 'postgis_restore', @_ unless defined($POSTGIS_RESTORE);
 if ( $OPT_UPGRADE_PATH )
@@ -2107,7 +2107,7 @@ sub restore_db
         print "Restoring database '${DB}' using pg_restore\n";
         $rv = system("pg_restore -d ${DB} ${DBDUMP} >> $REGRESS_LOG 2>&1");
     } else {
-        print "Restoring database '${DB}' using postgis_restore.pl\n";
+        print "Restoring database '${DB}' using postgis_restore\n";
         my $cmd = postgis_restore() . " ${DBDUMP} | psql --set ON_ERROR_STOP=1 -X ${DB} >> $REGRESS_LOG 2>&1";
         $rv = system($cmd);
diff --git a/utils/Makefile.in b/utils/Makefile.in
index 4e72d51b4..386c2afe2 100644
--- a/utils/Makefile.in
+++ b/utils/Makefile.in
@@ -30,7 +30,7 @@ VPATH := @srcdir@
 SHELL = @SHELL@
 INSTALL = $(SHELL) @top_srcdir@/build-aux/install-sh
-SCRIPTS_built = postgis_restore.pl
+SCRIPTS_built = postgis_restore
 SCRIPTS = \
 	create_uninstall.pl \
@@ -69,7 +69,7 @@ $(top_builddir)/raster/rt_pg/uninstall_rtpostgis.sql:
 $(top_builddir)/topology/uninstall_topology.sql:
 	$(MAKE) -C ../topology/ uninstall_topology.sql
-postgis_restore_data.hardcoded: postgis_restore.pl.in Makefile
+postgis_restore_data.hardcoded: postgis_restore.in Makefile
 	sed -e '1,/^__END__/d' $< \
 		| sort -u \
@@ -79,13 +79,13 @@ postgis_restore_data.generated: $(DROP_FILES) Makefile create_skip_signatures.pl
 		| sort \
-postgis_restore.pl: postgis_restore.pl.in postgis_restore_data.hardcoded postgis_restore_data.generated Makefile
+postgis_restore: postgis_restore.in postgis_restore_data.hardcoded postgis_restore_data.generated Makefile
 	cat $< \
 		| sed '/^__END__/q' \
 		| sed 's, at SRID_MAXIMUM@,$(SRID_MAXIMUM),g;s, at SRID_USER_MAXIMUM@,$(SRID_USER_MAXIMUM),' \
-		> postgis_restore.pl
 	cat postgis_restore_data.hardcoded postgis_restore_data.generated \
-		| sort -u >> postgis_restore.pl
+		| sort -u >> $@
 	chmod +x $@
 postgis_restore_data.needlessly-hardcoded: postgis_restore_data.hardcoded postgis_restore_data.generated
@@ -93,15 +93,15 @@ postgis_restore_data.needlessly-hardcoded: postgis_restore_data.hardcoded postgi
 postgis_restore-check: postgis_restore_data.needlessly-hardcoded
 	@if test -s $<; then { \
-		echo "Needlessly hardcoded signatures found postgis_restore.pl.in:"; \
+		echo "Needlessly hardcoded signatures found postgis_restore.in:"; \
 		sed 's/^/  /' $<; \
 		echo "Use 'make postgis_restore-clean' to fix that"; \
 	} >&2 && false; fi
 postgis_restore-clean: postgis_restore_data.needlessly-hardcoded
-	mv $(srcdir)/postgis_restore.pl.in $(srcdir)/postgis_restore.pl.in~
-	grep -Fxvf $< $(srcdir)/postgis_restore.pl.in~ > $(srcdir)/postgis_restore.pl.in
+	mv $(srcdir)/postgis_restore.in $(srcdir)/postgis_restore.in~
+	grep -Fxvf $< $(srcdir)/postgis_restore.in~ > $(srcdir)/postgis_restore.in
 clean:
 	rm -f $(SCRIPTS_built) postgis_restore_data.*
diff --git a/utils/README b/utils/README
index c8b4cc165..4d567585b 100644
--- a/utils/README
+++ b/utils/README
@@ -1,7 +1,7 @@
 test_estimation.pl
 	test selectivity estimator for the && (overlap) operator
-postgis_restore.pl
+postgis_restore
 	restore a spatial database dump to a (possibly updated)
 	new spatial database.
diff --git a/utils/create_skip_signatures.pl b/utils/create_skip_signatures.pl
index 81696964e..05c6bbea3 100644
--- a/utils/create_skip_signatures.pl
+++ b/utils/create_skip_signatures.pl
@@ -12,7 +12,7 @@
 # This script is aimed at generating a list of objects
-# signatures used by postgis_restore.pl to decide
+# signatures used by postgis_restore to decide
 # which objects belong to PostGIS
diff --git a/utils/postgis_restore.pl.in b/utils/postgis_restore.in
similarity index 100%
rename from utils/postgis_restore.pl.in
rename to utils/postgis_restore.in
Summary of changes:
 .gitignore                                          |  2 +-
 NEWS                                                |  8 ++++++++
 doc/administration.xml                              | 10 +++++-----
 liblwgeom/lwutil.c                                  |  2 +-
 regress/run_test.pl                                 |  4 ++--
 utils/Makefile.in                                   | 16 ++++++++--------
 utils/README                                        |  2 +-
 utils/create_skip_signatures.pl                     |  2 +-
 utils/{postgis_restore.pl.in => postgis_restore.in} |  0
 9 files changed, 27 insertions(+), 19 deletions(-)
 rename utils/{postgis_restore.pl.in => postgis_restore.in} (100%)
hooks/post-receive
