[postgis-tickets] [PostGIS] #5447: No manual page for /usr/bin/postgis nor /usr/bin/postgis_restore.pl
PostGIS trac at osgeo.org
Tue Jul 25 21:43:39 PDT 2023
  Reporter:  Bas Couwenberg  |      Owner:  pramsey
      Type:  defect          |     Status:  new
  Priority:  medium          |  Milestone:  PostGIS 3.4.0
 Component:  postgis         |    Version:  master
Resolution:                  |   Keywords:
Comment (by Bas Couwenberg):
 Replying to [comment:4 strk]:
 > Bas: are you willing to give your view about why dropping the .pl seems
 important to you ?
 It triggers script-with-language-extension lintian issues for the Debian
 package, from the tag description:
 > When scripts are installed into a directory in the system `PATH`, the
 script name should not include an extension such as `.sh` or `.pl` that
 denotes the scripting language currently used to implement it. The
 implementation language may change; if it does, leaving the name the same
 would be confusing and changing it would be disruptive.
 > Please refer to [https://www.debian.org/doc/debian-policy/ch-
 files.html#scripts Scripts (Section 10.4)] in the Debian Policy Manual for
 details.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5447#comment:7>
