[postgis-tickets] [PostGIS] #5458: Redefine postgis.gdal_datapath not allowed when going from no minor-lib version --with-minor-lib-version
PostGIS trac at osgeo.org
Wed Jul 26 19:02:18 PDT 2023
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  3.3.x
Resolution:  wontfix                |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => wontfix
Comment:
 Okay interestingly I was able to upgrade the nyc database on
 demo.postgis.net which also has postgis_raster on it.
 and when I closed out my original connection and tried again to upgrade
 the database I was trying to upgrade, it went thru this time.
 So maybe it's only an issue with if the old .so is loaded in the same
 connection as the new one you are trying to load.
 I'm going to close this out as a won't fix.  Feel free to reopen if you
 think anything can be done about this.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5458#comment:1>
