[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0beta1-72-g45d1967b7
Thu Jul 27 08:34:24 PDT 2023
the project "PostGIS".
       via  45d1967b73a989e748ce4be30a858f7667c9e04c (commit)
      from  a76b581b7ca37a35ae8f170c19231afe6d7154ad (commit)
revisions in full, below.
commit 45d1967b73a989e748ce4be30a858f7667c9e04c
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jul 27 17:34:09 2023 +0200
    Add man page for postgis_restore
    Closes #5447
diff --git a/doc/Makefile.in b/doc/Makefile.in
index f0336707e..2e612910c 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -493,7 +493,7 @@ endif
 comments-uninstall:
 	$(MAKE) -f Makefile.comments uninstall
-man-install: man/shp2pgsql.1 man/pgsql2shp.1 man/pgtopo_export.1 man/pgtopo_import.1 man/postgis.1
+man-install: man/shp2pgsql.1 man/pgsql2shp.1 man/pgtopo_export.1 man/pgtopo_import.1 man/postgis.1 man/postgis_restore.1
 	mkdir -p $(DESTDIR)$(mandir)/man1
 	for f in $^; do \
 		$(INSTALL_DATA) $$f $(DESTDIR)$(mandir)/man1/`basename $$f`; \
@@ -505,6 +505,7 @@ man-uninstall:
 	rm -f $(DESTDIR)$(mandir)/man1/pgtopo_export.1
 	rm -f $(DESTDIR)$(mandir)/man1/pgtopo_import.1
 	rm -f $(DESTDIR)$(mandir)/man1/postgis.1
+	rm -f $(DESTDIR)$(mandir)/man1/postgis_restore.1
 html-install: $(html_builddir)/postgis$(DOCSUFFIX).html
 	mkdir -p $(DESTDIR)$(htmldir)
diff --git a/doc/man/postgis_restore.1 b/doc/man/postgis_restore.1
new file mode 100644
index 000000000..b5d333deb
--- /dev/null
+++ b/doc/man/postgis_restore.1
@@ -0,0 +1,52 @@
+.TH "postgis_restore" "1" "" "" "PostGIS"
+.SH "NAME"
+.LP
+postgis_restore - restore a PostGIS database from an archive file created by pg_dump
+.SH "SYNTAX"
+.LP
+postgis_restore [\fI-v\fR] [\fI-L TOC\fR] [\fI-s schema\fR] \fIdumpfile\fR
+.SH "DESCRIPTION"
+.LP
+The postgis_restore command allows extracting SQL statements to re-create objects
+found in a custom dump of a PostGIS-enabled database while skipping the PostGIS
+specific objects.
+This is only useful for dumps of databases in which PostGIS was enabled by
+loading the postgis.sql script. Dumps taken from databases in which PostGIS was
+enabled via \fICREATE EXTENSION\fR will not have PostGIS objects in them so can
+safely be restored directly using \fIpg_restore\fR.
+Note that this command only works with dumps using the custom format, which are
+those crated with \fIpg_dump -Fc\fR.
+.SH "USAGE"
+.LP
+Usage information is printed when the script is invoked with no
+arguments.
+.SH "EXAMPLES"
+.LP
+Create a custom dump from \fIolddb\fR:
+	pg_dump -Fc olddb > olddb.dump
+Create a new database \fInewdb\fR:
+	createdb newdb
+PostGIS-enable the new database:
+	psql -c 'CREATE EXTENSION postgis' newdb
+Restore your data:
+	postgis_restore.pl olddb.dump | psql newdb
+.SH "AUTHORS"
+.LP
+Originally written by Sandro Santilli <strk at kbt.io>.
+More information is available at http://postgis.net
Summary of changes:
 doc/Makefile.in           |  3 ++-
 doc/man/postgis_restore.1 | 52 +++++++++++++++++++++++++++++++++++++++++++++++
 2 files changed, 54 insertions(+), 1 deletion(-)
 create mode 100644 doc/man/postgis_restore.1
hooks/post-receive
