[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0beta1-73-gd42235a60
Thu Jul 27 11:34:52 PDT 2023
the project "PostGIS".
       via  d42235a6066343cad2b633a3ccb37f79b07fb488 (commit)
      from  45d1967b73a989e748ce4be30a858f7667c9e04c (commit)
revisions in full, below.
commit d42235a6066343cad2b633a3ccb37f79b07fb488
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Jul 27 11:34:48 2023 -0700
    Add cunit version of test for #5448
diff --git a/liblwgeom/cunit/cu_algorithm.c b/liblwgeom/cunit/cu_algorithm.c
index 67f3822a5..44e2187d0 100644
--- a/liblwgeom/cunit/cu_algorithm.c
+++ b/liblwgeom/cunit/cu_algorithm.c
@@ -1167,6 +1167,14 @@ static void test_lwgeom_remove_repeated_points(void)
 	char *ewkt_exp;
 	int modified = LW_FALSE;
+	g = lwgeom_from_wkt("LINESTRING(0 0,1 1,1 1,1 1,1.707 1.707)", LW_PARSER_CHECK_NONE);
+	modified = lwgeom_remove_repeated_points_in_place(g, 0.001);
+	ASSERT_INT_EQUAL(modified, LW_TRUE);
+	ewkt = lwgeom_to_ewkt(g);
+	ASSERT_STRING_EQUAL(ewkt, "LINESTRING(0 0,1 1,1.707 1.707)");
+	lwgeom_free(g);
+	lwfree(ewkt);
 	g = lwgeom_from_wkt("MULTIPOINT(0 0, 10 0, 10 10, 10 10, 0 10, 0 10, 0 10, 0 0, 0 0, 0 0, 5 5, 0 0, 5 5)", LW_PARSER_CHECK_NONE);
 	modified = lwgeom_remove_repeated_points_in_place(g, 1);
Summary of changes:
 liblwgeom/cunit/cu_algorithm.c | 8 ++++++++
 1 file changed, 8 insertions(+)
hooks/post-receive
