[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0beta1-78-ga847694bc
Fri Jul 28 03:04:15 PDT 2023
the project "PostGIS".
       via  a847694bcfb3f2c685069aaaf8d36fa3d6048dfa (commit)
       via  7ebbf7c651da2cadee66339c203ecde00e7a0f04 (commit)
       via  16049a78d6cc8abe74ffa9690bc2597d86895380 (commit)
      from  2588af6ee728774dd8cef0f2460e93d6746c2818 (commit)
revisions in full, below.
commit a847694bcfb3f2c685069aaaf8d36fa3d6048dfa
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Jul 28 12:03:48 2023 +0200
    Update release procedure (based on just made experience on 3.3.4)
diff --git a/HOWTO_RELEASE b/HOWTO_RELEASE
index 02d7a0d2f..db3ef753a 100644
--- a/HOWTO_RELEASE
+++ b/HOWTO_RELEASE
@@ -120,7 +120,12 @@ Release procedure
   - Documentation should also have been built and should be in https://postgis.net/stuff
      (this sometimes takes sometime so wait 15 minutes)
   - Test generated tarball (including extension upgrade)
-  - Copy tarball, md5, pdf, doc-html to https://upload.osgeo.org/postgis/ .
+  - Copy tarball and md5 files to ssh://upload.osgeo.org/osgeo/download/postgis/source
+    $ scp postgis-${rev}.tar.gz postgis-${rev}.tar.gz.md5 upload.osgeo.org:/osgeo/download/postgis/source
+  - Copy pdf, epub and doc-html files to ssh://upload.osgeo.org/osgeo/download/postgis/docs
+    $ scp doc-html-${rev}.tar.gz postgis-${rev}.epub postgis-${rev}.pdf upload.osgeo.org:/osgeo/download/postgis/docs/
+  - Ensure md5 file is ALSO in https://postgis.net/stuff, if needed:
+    $ scp postgis-${rev}.tar.gz.md5 debbie.postgis.net:/var/www/postgis_stuff
   - PostGIS doc release versioned doc - http://postgis.net/documentation/
     - On postgis.net server, change /etc/nginx/sites-enabled/postgis.net (Versionless URL line )
@@ -129,9 +134,9 @@ Release procedure
       Verify the documentation is up to date (might need to change the nginx config)
   - Post on website:
-      - https://git.osgeo.org/gitea/postgis/postgis.net/src/branch/website/config/_default/params.toml#L132
+      - https://git.osgeo.org/gitea/postgis/postgis.net/src/branch/website/config.toml#L155
         Fix latest version pointers.
-      - https://git.osgeo.org/gitea/postgis/postgis.net/src/branch/website/content/post
+      - https://git.osgeo.org/gitea/postgis/postgis.net/src/branch/website/content/news
         a) create a new Post for current year making sure the page name starts with mm-dd
           Since hugo move, the mm-dd isn't absolutely necessary anymore
           as it uses the slug or title and date to determine the permalink.  But for now lets keep the same convention.
commit 7ebbf7c651da2cadee66339c203ecde00e7a0f04
Date:   Fri Jul 28 12:03:37 2023 +0200
    More detailed log about what's being run
diff --git a/make_dist.sh b/make_dist.sh
index 4a2a30b27..22106c9da 100755
--- a/make_dist.sh
+++ b/make_dist.sh
@@ -63,10 +63,12 @@ echo "Removing ci files"
 rm -rfv "$outdir"/ci "$outdir"/.gitlab-ci.yml "$outdir"/.github "$outdir"/.dron*.yml "$outdir"/.cirrus.yml "$outdir"/.clang-format
 # generating configure script and configuring
-echo "Running autogen.sh; ./configure"
+echo "Running autogen.sh"
 owd="$PWD"
 cd "$outdir"
 ./autogen.sh || exit 1
+echo "./configure ${CONFIGURE_ARGS}"
 ./configure ${CONFIGURE_ARGS} || exit 1
 # generating postgis_revision.h for >= 2.0.0 tags
 if test -f utils/repo_revision.pl; then
commit 16049a78d6cc8abe74ffa9690bc2597d86895380
Date:   Fri Jul 28 10:40:23 2023 +0200
    Add git2cl requirement for release
index 368052ce5..02d7a0d2f 100644
--- a/HOWTO_RELEASE
+++ b/HOWTO_RELEASE
@@ -50,6 +50,7 @@ documentation -- that means having the required software:
   - protobuf-c
   - GDAL (for raster)
   - json-c (for GeoJSON load support)
+  - git2cl (for ChangeLog generation)
 * For the docs:
   - xsltproc
   - DocBook XSL scripts
Summary of changes:
 HOWTO_RELEASE | 12 +++++++++---
 make_dist.sh  |  4 +++-
 2 files changed, 12 insertions(+), 4 deletions(-)
hooks/post-receive
