[postgis-tickets] [PostGIS] #5455: update-po and update-pot result in different output from different machines
PostGIS trac at osgeo.org
Sat Jul 29 01:35:23 PDT 2023
  Reporter:  strk    |      Owner:  robe
      Type:  defect  |     Status:  new
  Priority:  medium  |  Milestone:  PostGIS 3.4.0
 Component:  l18n    |    Version:  master
Resolution:          |   Keywords:
Comment (by robe):
 Replying to [comment:2 strk]:
 > We should maybe avoid line wrapping as a whole.
 > Incidentally it looks like weblate at some point used to remove line
 wrapping, I'm not sure this is still the case. Commit with no line
 wrapping from weblate: [a0db0dbf4afab21b67d534bb9fff53fe4751f3d3/git]
 > The above commit is the last one coming from weblate, maybe a component
 was disabled ?
 Yah there is a component add-on in weblate that controls line wrapping.
 https://weblate.osgeo.org/addons/postgis/postgis/
 It's called "Customize gettext output" and is set to break after 77.
 I think when we started we didn't have that add-on enabled and WEblate's
 default behavior was to not linewrap.  I think you were the one that
 suggested we install this plugin to force line wrapping at 77.
 Should we disable it.  I think we might need to disable for each
 individual component, cause the add-ons I think are only copied via the
 component discovery add-on when they are first created.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5455#comment:5>
