[postgis-tickets] [PostGIS] #5460: Upstream changes for geography ST_LineLocatePoint to use spheroid, and interpolation fix
PostGIS trac at osgeo.org
Sat Jul 29 04:40:19 PDT 2023
interpolation fix
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 3.4.0
 Component:  postgis  |    Version:  master
Resolution:  fixed    |   Keywords:
Changes (by robe):
 * status:  reopened => closed
 * resolution:   => fixed
Comment:
 I'll move the 32-bit and rounding issue to a different ticket and will
 keep the test out for now. The tests that are failing is a more complex
 one that uses data from mobilitydbs tests.  I'll add that test back after
 beta2 release.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5460#comment:6>
