[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-958-g4c776d418
Thu Jun 1 09:07:11 PDT 2023
the project "PostGIS".
       via  4c776d4180768aa12354c26a50dd8cee09a81f98 (commit)
       via  6a175c5413ba0376b9c22045850c5cab8e2b4dce (commit)
      from  57cbcb9424065edaf070c65ccc4377824dd94271 (commit)
revisions in full, below.
commit 4c776d4180768aa12354c26a50dd8cee09a81f98
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jun 1 18:00:36 2023 +0200
    Never rely on tolerance-based point equality for topology code
    It sounds pretty dangerous and unwanted
diff --git a/liblwgeom/lwgeom_topo.c b/liblwgeom/lwgeom_topo.c
index f83c4a9f9..df573fdde 100644
--- a/liblwgeom/lwgeom_topo.c
+++ b/liblwgeom/lwgeom_topo.c
@@ -864,7 +864,7 @@ lwt_AddIsoEdge( LWT_TOPOLOGY* topo, LWT_ELEMID startNode,
         /* l) Check that start point of acurve match start node geoms. */
         getPoint2d_p(geom->points, 0, &p1);
         getPoint2d_p(n->geom->point, 0, &p2);
-        if ( ! p2d_same(&p1, &p2) )
+        if ( ! P2D_SAME_STRICT(&p1, &p2) )
           _lwt_release_nodes(endpoints, num_nodes);
           lwerror("SQL/MM Spatial exception - "
@@ -877,7 +877,7 @@ lwt_AddIsoEdge( LWT_TOPOLOGY* topo, LWT_ELEMID startNode,
         /* m) Check that end point of acurve match end node geoms. */
         getPoint2d_p(geom->points, geom->points->npoints-1, &p1);
@@ -1738,8 +1738,8 @@ _lwt_GetInteriorEdgePoint(const LWLINE* edge, POINT2D* ip)
   for (i=1; i<pa->npoints-1; ++i)
     getPoint2d_p(pa, i, &tp); /* pick next point */
-    if ( p2d_same(&tp, &fp) ) continue; /* equal to startpoint */
-    if ( p2d_same(&tp, &lp) ) continue; /* equal to endpoint */
+    if ( P2D_SAME_STRICT(&tp, &fp) ) continue; /* equal to startpoint */
+    if ( P2D_SAME_STRICT(&tp, &lp) ) continue; /* equal to endpoint */
     /* this is a good one, neither same of start nor of end point */
     *ip = tp;
     return 1; /* found */
@@ -1749,7 +1749,7 @@ _lwt_GetInteriorEdgePoint(const LWLINE* edge, POINT2D* ip)
   /* interpolate if start point != end point */
-  if ( p2d_same(&fp, &lp) ) return 0; /* no distinct points in edge */
+  if ( P2D_SAME_STRICT(&fp, &lp) ) return 0; /* no distinct points in edge */
   ip->x = fp.x + ( (lp.x - fp.x) * 0.5 );
   ip->y = fp.y + ( (lp.y - fp.y) * 0.5 );
@@ -2424,7 +2424,7 @@ _lwt_AddEdge( LWT_TOPOLOGY* topo,
       pa = start_node_geom->point;
       getPoint2d_p(pa, 0, &pn);
-      if ( ! p2d_same(&pn, &p1) )
+      if ( ! P2D_SAME_STRICT(&pn, &p1) )
         if ( num_nodes ) _lwt_release_nodes(endpoints, num_nodes);
         lwerror("SQL/MM Spatial exception"
@@ -2445,7 +2445,7 @@ _lwt_AddEdge( LWT_TOPOLOGY* topo,
       pa = end_node_geom->point;
-      if ( ! p2d_same(&pn, &p2) )
+      if ( ! P2D_SAME_STRICT(&pn, &p2) )
@@ -2962,9 +2962,9 @@ _lwt_FindNextRingEdge(const POINTARRAY *ring, int from,
     LWDEBUGF(1, "Edge %" LWTFMT_ELEMID " 'first' point is %g,%g",
                 isoe->edge_id, p2.x, p2.y);
     LWDEBUGF(1, "Rings's 'from' point is still %g,%g", p1.x, p1.y);
-    if ( p2d_same(&p1, &p2) )
+    if ( P2D_SAME_STRICT(&p1, &p2) )
-      LWDEBUG(1, "p2d_same(p1,p2) returned true");
+      LWDEBUG(1, "P2D_SAME_STRICT(p1,p2) returned true");
       LWDEBUGF(1, "First point of edge %" LWTFMT_ELEMID
                   " matches ring vertex %d", isoe->edge_id, from);
       /* first point matches, let's check next non-equal one */
@@ -2974,12 +2974,12 @@ _lwt_FindNextRingEdge(const POINTARRAY *ring, int from,
         LWDEBUGF(1, "Edge %" LWTFMT_ELEMID " 'next' point %d is %g,%g",
                     isoe->edge_id, j, p2.x, p2.y);
         /* we won't check duplicated edge points */
-        if ( p2d_same(&p1, &p2) ) continue;
+        if ( P2D_SAME_STRICT(&p1, &p2) ) continue;
         /* we assume there are no duplicated points in ring */
         getPoint2d_p(ring, from+1, &pt);
         LWDEBUGF(1, "Ring's point %d is %g,%g",
                     from+1, pt.x, pt.y);
-        match = p2d_same(&pt, &p2);
+        match = P2D_SAME_STRICT(&pt, &p2);
         break; /* we want to check a single non-equal next vertex */
 #if POSTGIS_DEBUG_LEVEL > 0
@@ -3000,7 +3000,7 @@ _lwt_FindNextRingEdge(const POINTARRAY *ring, int from,
       getPoint2d_p(epa, epa->npoints-1, &p2);
       LWDEBUGF(1, "Edge %" LWTFMT_ELEMID " 'last' point is %g,%g",
         LWDEBUGF(1, "Last point of edge %" LWTFMT_ELEMID
@@ -3011,12 +3011,12 @@ _lwt_FindNextRingEdge(const POINTARRAY *ring, int from,
           LWDEBUGF(1, "Edge %" LWTFMT_ELEMID " 'prev' point %d is %g,%g",
                       isoe->edge_id, epa->npoints - j, p2.x, p2.y);
@@ -3281,7 +3281,7 @@ lwt_ChangeEdgeGeom(LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, LWLINE *geom)
   getPoint2d_p(oldedge->geom->points, 0, &p1);
   getPoint2d_p(geom->points, 0, &pt);
-  if ( ! p2d_same(&p1, &pt) )
+  if ( ! P2D_SAME_STRICT(&p1, &pt) )
     _lwt_release_edges(oldedge, 1);
@@ -3307,7 +3307,7 @@ lwt_ChangeEdgeGeom(LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, LWLINE *geom)
     return -1;
   getPoint2d_p(geom->points, geom->points->npoints-1, &pt);
-  if ( ! p2d_same(&pt, &p2) )
+  if ( ! P2D_SAME_STRICT(&pt, &p2) )
commit 6a175c5413ba0376b9c22045850c5cab8e2b4dce
Date:   Thu Jun 1 17:15:08 2023 +0200
    Improve robustness of finding distinct vertices in topology edges
    Fixes #5394
    Includes regression test.
    Also augments precision in debug messages.
index d85ed6847..f83c4a9f9 100644
@@ -43,6 +43,12 @@
 # define LWTFMT_ELEMID PRId64
 #endif
+/* This is a non-tolerance based 2d equality for points
+ * whereas the p2d_same function is tolerance based
+ * TODO: move in higher headers ?
+#define P2D_SAME_STRICT(a,b) ((a)->x == (b)->x && (a)->y == (b)->y)
  * Backend iface
@@ -1425,7 +1431,7 @@ _lwt_FirstDistinctVertex2D(const POINTARRAY* pa, POINT2D *ref, int from, int dir
     LWDEBUGF(1, "testing point %d", i);
     getPoint2d_p(pa, i, op); /* pick next point */
-    if ( p2d_same(op, &fp) ) continue; /* equal to startpoint */
+    if ( P2D_SAME_STRICT(op,&fp) ) continue; /* equal to startpoint */
@@ -1575,7 +1581,7 @@ _lwt_FindAdjacentEdges( LWT_TOPOLOGY* topo, LWT_ELEMID node, edgeend *data,
       LWDEBUGF(1, "edge %" LWTFMT_ELEMID
                   " starts on node %" LWTFMT_ELEMID
-                  ", edgeend is %g,%g-%g,%g",
+                  ", edgeend is [%.15g %.15g,%.15g %.15g]",
                   edge->edge_id, node, p1.x, p1.y, p2.x, p2.y);
       if ( ! azimuth_pt_pt(&p1, &p2, &az) ) {{
         LWT_ELEMID id = edge->edge_id;
@@ -1587,7 +1593,7 @@ _lwt_FindAdjacentEdges( LWT_TOPOLOGY* topo, LWT_ELEMID node, edgeend *data,
       azdif = az - data->myaz;
       LWDEBUGF(1, "azimuth of edge %" LWTFMT_ELEMID
-                  ": %g (diff: %g)", edge->edge_id, az, azdif);
+                  ": %.15g (diff: %.15g)", edge->edge_id, az, azdif);
       if ( azdif < 0 ) azdif += 2 * M_PI;
       if ( minaz == -1 ) {
@@ -1636,7 +1642,7 @@ _lwt_FindAdjacentEdges( LWT_TOPOLOGY* topo, LWT_ELEMID node, edgeend *data,
         return -1;
       LWDEBUGF(1, "edge %" LWTFMT_ELEMID " ends on node %" LWTFMT_ELEMID
@@ -1648,7 +1654,7 @@ _lwt_FindAdjacentEdges( LWT_TOPOLOGY* topo, LWT_ELEMID node, edgeend *data,
         minaz = maxaz = azdif;
diff --git a/topology/test/regress/topogeo_addpoint.sql b/topology/test/regress/topogeo_addpoint.sql
index 155db91af..da3d60add 100644
--- a/topology/test/regress/topogeo_addpoint.sql
+++ b/topology/test/regress/topogeo_addpoint.sql
@@ -64,3 +64,10 @@ SELECT 'tt2033', 'N' || topogeo_addpoint('t', 'POINT(0.2 1 1)', 0.5);
 SELECT 'tt2033', 'NC', node_id, ST_AsText(geom) FROM t.node ORDER BY node_id;
 SELECT 'tt2033.end' || DropTopology('t');
+-- See https://trac.osgeo.org/postgis/ticket/5394
+SELECT NULL FROM CreateTopology ('t');
+SELECT 'tt5394', 'E1', TopoGeo_addLinestring('t', 'LINESTRING(5.803580945500557 59.26346622,5.8035802635 59.263465501)' );
+SELECT 'tt5394', 'E2', TopoGeo_addLinestring('t', 'LINESTRING(5.8035802635 59.263465501,5.8035809455 59.26346622,5.803580945500557 59.26346622)' );
+SELECT 'tt5394', 'V', * FROM ValidateTopology('t');
+SELECT 'tt5394', 'N', TopoGeo_addPoint( 't', 'POINT(5.803646305 59.263416658000004)' );
+SELECT NULL FROM DropTopology('t');
diff --git a/topology/test/regress/topogeo_addpoint_expected b/topology/test/regress/topogeo_addpoint_expected
index fdc50c387..28dfbd31e 100644
--- a/topology/test/regress/topogeo_addpoint_expected
+++ b/topology/test/regress/topogeo_addpoint_expected
@@ -27,3 +27,6 @@ tt2033|NC|1|POINT Z (0 0 0)
 tt2033|NC|2|POINT Z (0 2 1)
 tt2033|NC|3|POINT Z (0 1 1)
 tt2033.endTopology 't' dropped
+tt5394|E1|1
+tt5394|E2|2
+tt5394|N|3
Summary of changes:
 liblwgeom/lwgeom_topo.c                         | 48 ++++++++++++++-----------
 topology/test/regress/topogeo_addpoint.sql      |  7 ++++
 topology/test/regress/topogeo_addpoint_expected |  3 ++
 3 files changed, 37 insertions(+), 21 deletions(-)
hooks/post-receive
