[postgis-tickets] [PostGIS] #5392: Aggregate ST_Union fails to join some "circles" when radius is too large - lwgeom_unaryunion_prec: GEOS Error: TopologyException
PostGIS trac at osgeo.org
Tue Jun 6 14:38:25 PDT 2023
  Reporter:  rotten   |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 3.3.4
 Component:  postgis  |    Version:  3.3.x
Resolution:  invalid  |   Keywords:
Comment (by robe):
 @rotten,
 ST_Buffer for geometry is generally fine it's the transforms that
 ST_Buffer(geography..) is doing that converts your valid geometry to an
 invalid one.  There are so many operations that can result in converting a
 valid geometry to an invalid one that we don't bother checking.  The
 exercise is left up to the user.
 The issue is with ST_Buffer(geography ...). As noted
 https://postgis.net/docs/ST_Buffer.html  it does a transform (at least 2)
 under the hood to guess at an appropriate spatial ref for your data and
 then convert what it came up with to the 4326 you started with.  If your
 radius is big enough it goes beyond what one can pretend is flat.
 Note how the below is invalid
     select
        ST_Isvalid( ST_Buffer(
             ST_Point(-177.2519031::float8, -18.5973127::float8,
 4326)::geography,
             290086::integer
         )::geometry)
 If you look under the hood of ST_Buffer(geography... is doing)
 You will see the hack that pramsey is referring to:
 it's determining that this hidden srid 999101 is the best meter based
 spatial ref sys for the point you presented
 SELECT _ST_BestSRID(ST_Point(-177.2519031::float8, -18.5973127::float8,
 4326));
 -- now take that and buffer it by 290,086 meters
 -- still valid right yeh
 SELECT ST_IsValid(ST_Buffer(ST_Transform(ST_Point(-177.2519031::float8,
 -18.5973127::float8, 4326), 999101),290086)) ;
 Now try to transform it back to 4326, it's invalid
 I know it's sad, at a certain point our pretend that the world is flat
 goes hay wire when we try to convert it to another flat representation and
 the bounds of our flatness stretch beyond what the flat world we picked is
 suitable and so the transformation function does its best for and every
 flat world eventually reduces to a wraparound
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5392#comment:8>
