[postgis-tickets] [PostGIS] #5389: ST_Transform broken with PROJ 9.2.0
PostGIS trac at osgeo.org
Fri Jun 9 01:56:27 PDT 2023
  Reporter:  tjay     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.1.10
 Component:  postgis  |    Version:  3.1.x
Resolution:           |   Keywords:  proj
Comment (by tjay):
 with {{{ PROJ="9.2.1" }}} the PosGIS-Test above, does not fail with wrong
 coordinates but with an Exception:
 ERROR:  transform: File not found or invalid (1029)
 So basicly better but still not comprehensible to the results of {{{ cs2cs
 }}} that does not fail and transforms correctly.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5389#comment:5>
