[postgis-tickets] [PostGIS] #5399: address_standardizer compile time warnings
PostGIS trac at osgeo.org
Mon Jun 12 07:52:03 PDT 2023
 Reporter:  strk     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.4.0
Component:  postgis  |    Version:  master
 Keywords:           |
 I get many:
 ../.././../../extensions/address_standardizer/address_standardizer.c:207:7:
 warning: unused variable 'ruleref' [-Wunused-variable]
                 KW *ruleref = __cur_stz__->build_key;
 ../.././../../extensions/address_standardizer/address_standardizer.c:68:26:
 warning: unused variable 'values' [-Wunused-variable]
     char               **values;
 2 warnings generated.
 gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-
 statement -Werror=vla -Wendif-labels -Wmissing-format-attribute
 -Wimplicit-fallthrough=3 -Wformat-security -fno-strict-aliasing -fwrapv
 -fexcess-precision=standard -Wno-format-truncation -Wno-stringop-
 truncation -g -g -O2 -flto=auto -ffat-lto-objects -fstack-protector-strong
 -Wformat -Werror=format-security -fno-omit-frame-pointer -fPIC -std=gnu99
 -O2 -g -Wall -fno-math-errno -fno-signed-zeros -Wall -flto
 -I/usr/local/include -I/opt/proj-9.1/include -I/usr/include/x86_64-linux-
 gnu  -I/usr/include/libxml2 -I/usr/include -I/usr/include/json-c  -DNDEBUG
 -DPCRE_VERSION=2 -I. -I./ -I/usr/include/postgresql/13/server
 -I/usr/include/postgresql/internal  -Wdate-time -D_FORTIFY_SOURCE=2
 -D_GNU_SOURCE -I/usr/include/libxml2   -c -o address_standardizer.o
 ../.././../../extensions/address_standardizer/address_standardizer.c: In
 function ‘debug_standardize_address’:
 ../.././../../extensions/address_standardizer/address_standardizer.c:94:17:
 warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-
 statement]
    94 |                 int                  err;
 ../.././../../extensions/address_standardizer/address_standardizer.c:151:5:
 warning: this ‘if’ clause does not guard... [-Wmisleading-indentation]
   151 |     if (!std)
 ../.././../../extensions/address_standardizer/address_standardizer.c:155:9:
 note: ...this statement, but the latter is misleadingly indented as if it
 were guarded by the ‘if’
   155 |         STAND_PARAM *ms = std->misc_stand;
 statement]
 ../.././../../extensions/address_standardizer/address_standardizer.c:160:9:
 statement]
   160 |         DEF *__def__ ;
 ../.././../../extensions/address_standardizer/address_standardizer.c:168:9:
 statement]
   168 |         int started = 0;
 ../.././../../extensions/address_standardizer/address_standardizer.c:205:17:
 statement]
   205 |                 STZ *__cur_stz__ = __stz_list__[stz_no] ;
 ../.././../../extensions/address_standardizer/address_standardizer.c:207:21:
 warning: unused variable ‘ruleref’ [-Wunused-variable]
   207 |                 KW *ruleref = __cur_stz__->build_key;
 warning: unused variable ‘values’ [-Wunused-variable]
    68 |     char               **values;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5399>
