[postgis-tickets] [PostGIS] #5400: GHA ci is failing on PG15-clang-geos311-gdal35 C compiler works... no
PostGIS trac at osgeo.org
Mon Jun 12 08:16:34 PDT 2023
 Reporter:  robe     |      Owner:  robe
     Type:  defect   |     Status:  assigned
 Priority:  blocker  |  Milestone:  Website Management, Bots
Component:  postgis  |    Version:  3.3.x
 Keywords:           |
 https://github.com/postgis/postgis/actions/runs/5242404014/jobs/9465763896
 Now you are ready to run './configure'
 checking for a BSD-compatible install... /usr/bin/install -c
 checking build system type... x86_64-pc-linux-gnu
 checking host system type... x86_64-pc-linux-gnu
 checking how to print strings... printf
 checking for gcc... clang
 checking whether the C compiler works... no
 configure: error: in `/src/postgis':
 configure: error: C compiler cannot create executables
 See `config.log' for more details
 Error: Process completed with exit code 77.
 This started failing last week, so guessing it's most likely something
 wrong with the ci docker build than anything wrong with our code
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5400>
