[postgis-tickets] [PostGIS] #5316: Regress failure with in-develop proj
PostGIS trac at osgeo.org
Mon Jun 12 13:10:10 PDT 2023
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.4.0
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:
Changes (by Bas Couwenberg):
 * cc: Bas Couwenberg (added)
Comment:
 The grids are not available in Debian where postgis (3.3.3+dfsg-1) fails
 to build with proj (9.2.1-1), the package build environment also doesn't
 have network which prevents downloading the grids from the CDN.
 Ideally there is a subset of tests which require network that can easily
 be skipped in environments where the network is not available.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5316#comment:8>
