[postgis-tickets] [PostGIS] #5401: ST_Difference silently giving us wrong results
PostGIS trac at osgeo.org
Thu Jun 15 06:56:41 PDT 2023
  Reporter:  Lars Aksel Opsahl  |      Owner:  pramsey
      Type:  defect             |     Status:  new
  Priority:  medium             |  Milestone:  PostGIS 3.3.4
 Component:  postgis            |    Version:  3.3.x
Resolution:                     |   Keywords:
Comment (by strk):
 Lars this ticket is best used to tackle the unexpected precision
 reduction, so the aim here would be to reproduce the issue, not to work
 around it by using a different SQL statement.
 As neither me nor Paul are able to reproduce the issue it isn't easy for
 us to check if the this bug was already fixed or it depends on some other
 characteristic on those systems that are still affected.
 It would help in trying to reproduce the issue to first of all avoid
 movable parts, so for example you could save the two operands of the
 ST_Difference call in a table have some static data to work with. This
 could be done as such:
 CREATE TABLE t5401 AS SELECT
 ( SELECT ST_Collect(distinct pt.geo) FROM all_area pt WHERE
 ST_IsValid(pt.geo)) g1,
 ( SELECT ST_Union(geo) AS geo FROM used_area u WHERE ST_IsValid(geo) ) g2;
 The check if you can reproduce the bug with something like:
 SELECT ST_Difference(g1,g2) FROM t5401;
 Then attach a dump of that table in this ticket.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5401#comment:15>
