[postgis-tickets] [PostGIS] #5316: Regress failure with in-develop proj
PostGIS trac at osgeo.org
Fri Jun 16 06:22:58 PDT 2023
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.4.0
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:
Comment (by robe):
 That last change fixed the proj 8 failures, but sadly proj 9.0 and higher
 are still failing. So I guess there is at least one more of those.  I'll
 compile against proj 9 to see if I can root out that last one.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5316#comment:13>
