[postgis-tickets] [PostGIS] #5400: GHA ci is failing on PG15-clang-geos311-gdal35 C compiler works... no
PostGIS trac at osgeo.org
Sat Jun 17 10:30:52 PDT 2023
  Reporter:  robe        |      Owner:  robe
      Type:  defect      |     Status:  assigned
  Priority:  blocker     |  Milestone:  Website Management, Bots
 Component:  management  |    Version:  3.3.x
Resolution:              |   Keywords:
Comment (by robe):
 Confirmed the new one failing is bookworm
 PRETTY_NAME="Debian GNU/Linux 12 (bookworm)" NAME="Debian GNU/Linux"
 VERSION_ID="12" VERSION="12 (bookworm)" VERSION_CODENAME=bookworm
 ID=debian
 The old one working is bullseye
 PRETTY_NAME="Debian GNU/Linux 11 (bullseye)" NAME="Debian GNU/Linux"
 VERSION_ID="11" VERSION="11 (bullseye)" VERSION_CODENAME=bullseye
 ID=debian
 However it's not just the LD_LOAD at fault.  There are some of these flags
 that the new clang doesn't like:
 # Enable undefined behaviour sanitizer using traps
 CFLAGS_USAN="-g3 -O0 -mtune=generic -fno-omit-frame-pointer
 -fsanitize=undefined,implicit-conversion -fsanitize-undefined-trap-on-
 error -fno-sanitize-recover=implicit-conversion"
 LDFLAGS_STD="-Wl,-Bsymbolic-functions -Wl,-z,relro"
 # Sanitizer options to continue avoid stopping the runs on leaks (expected
 on postgres binaries)
 export
 ASAN_OPTIONS=halt_on_error=false,leak_check_at_exit=false,exitcode=0
 export
 MSAN_OPTIONS=halt_on_error=false,leak_check_at_exit=false,exitcode=0
 ./configure CC=clang CFLAGS="${CFLAGS_USAN}" LDFLAGS="${LDFLAGS_STD}"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5400#comment:3>
