[postgis-tickets] [PostGIS] #5387: ST_Transform(geom, str, str) is very slow
PostGIS trac at osgeo.org
Sun Jun 18 23:16:46 PDT 2023
  Reporter:  cdestigter  |      Owner:  pramsey
      Type:  defect      |     Status:  new
  Priority:  medium      |  Milestone:  PostGIS 3.4.0
 Component:  postgis     |    Version:  3.3.x
Resolution:              |   Keywords:
Comment (by cdestigter):
 I also find this a bit surprising (I'm not sure if it's related):
 dbname=# select st_asewkt(st_transform('point(0 0)'::geometry,
 'EPSG:7844', 'EPSG:4283'));
  POINT(-0.000009040658614 0.000009514196768)
 dbname=# select st_asewkt(st_transform('srid=7844;point(0 0)'::geometry,
 'EPSG:4283'));
  POINT(0 0)
 (our proj.db has an overridden custom transformation for these CRSes,
 which might explain the differences here - maybe one of these calls is
 using the custom pipeline and the other is not.) I'll try and dig into
 that behaviour a bit more tomorrow.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5387#comment:6>
