[postgis-tickets] [PostGIS] #5400: GHA ci is failing on PG15-clang-geos311-gdal35 C compiler works... no
PostGIS trac at osgeo.org
Mon Jun 19 06:30:28 PDT 2023
  Reporter:  robe        |      Owner:  robe
      Type:  defect      |     Status:  closed
  Priority:  blocker     |  Milestone:  Website Management, Bots
 Component:  management  |    Version:  3.3.x
Resolution:  fixed       |   Keywords:
Comment (by Regina Obe <lr@…>):
 In [changeset:"9025c770776beb6bf90ab04fd3a4656be32d10fa/git" 9025c77/git]:
 {{{#!CommitTicketReference repository="git"
 revision="9025c770776beb6bf90ab04fd3a4656be32d10fa"
 FIX GHA clang failures for clang 14
 - remove  explicit conversion, seems to cause clang 14 to fail
 - base path of LD_PRELOAD based on major version of clang
   instead of hard-coded 11
 Closes #5400 for PostGIS 3.3.10
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5400#comment:5>
